Best replacement fuse
  • 73buick
    • Mar 2011
    • 41
    Just got in a huge HP color laser printer that was hit with a surge. I immedietly found a blown fuse in the power supply. Its a Hollyland 51MS (Medium slow blow) 125V/8A fuse. Its nominal melting I2T is 167. Blow times are 100%: 4hrs min., 135% 1hr max, 200%, 20sec. max. Looking on digikey, the closest I can find is a littlefuse 232 series. The 232 series has a melting I2T of 182, the blow times are the same at 100% and 135%, but 200% is 2.25sec max. Should that be close enough?
    • 31137
    Re: Best replacement fuse
    8a slowblow 125v minimum is all you need to be concerned with
    make sure it's ceramic NOT glass though
    • fzabkar
      • Mar 2009
      • 772
      Did you test the components downstream of the fuse? One or more may be shorted.
      • 73buick
        • Mar 2011
        • 41
        The original fuse wasn't ceramic, according to the hollyland spec of the 51MS.
          • 31137
          maybe, but if something shorts out and blows a glass fuse hard, the glass can shatter.
          you really should use ceramics on mains!
            'Just got in a huge HP color laser printer that was hit with a surge.' Is the MOV (surge protector device) which is connected after the main fuse OK?
            • clearchris
              • Dec 2013
              • 687
              MOVs get "used up". When they do finally fail, they tend to fail closed circuit and result in flames.
              If it did sustain a big strike, I'd probably replace it, but I'm overly cautious.
              • socketa
                Bestec ATX0300F5WA - fast,or slow blow, fuse?
                by socketa
                I bought a dead motherboard, and connected it to this PSU,
                Was checking the standby voltages on the motherboard, and, whilst doing so, the PSU made a loud bang with a flash of light.
                So now i truly got a bang for my bucks, and something else to try and fix.
                The fuse was blowen, and the top was blowen off of a TNY276PN chip
                The glass fuse didn't have any marking to say if it was fast or slow blow
                So i checked the marking on the PCB thinking that that would tell me,
                but it 's got a T/F8A printed on the board
                So should i get a fast blow fuse, or should...
                05-17-2022, 01:22 AM
              • drykid
                Matsui 175S microwave fuse replacement
                by drykid
                I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                12-21-2020, 01:15 PM
              • whc14765
                Replacement Fuse - 980TI Gigabyte
                by whc14765
                I have a GIGABYTE Windforce 980TI with a blown fuse. I have already found the root cause for the fuse blowing.
                I need help getting a replacement fuse - I'm fine with waiting some time for some cheap ones from China.
                The fuse says 10A on it. And I'm not sure what package size it is exactly. Also, how do I know if it is a fast or slow fuse?
                04-11-2022, 09:01 AM
              • corrize
                A funny fuse story – Lumix LX100 II
                by corrize
                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                10-19-2023, 09:58 AM
              • eidam655
                GPU 1206 SMD fuse markings & replacement fuses
                by eidam655
                I need to replace a fuse on one of the graphics cards I am working on. It is a 1206 SMD fuse, white in color and has a "10" written in a blue rectangle on it.
                How do I find a suitable replacement? What is the general rule to identifying fuses' parameters? I found something in an eshop near me (see photo) but am very hesitant to use this as a replacement....
                04-14-2022, 12:46 AM
