Questions about PicKit 3.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    Re: Questions about PicKit 3.
    Originally posted by stj
    microchip has a parametric search you can use,
    what else does the chip need? how much flash, ram, i/o pins?
    Wouldn't I need to pick a screen first before I knew how many i/o pins it needed? Instead of an SPI interface, could I use a Parallel interface? Like the screen here?
    http://www.digikey.com/product-detai...3-T-ND/4429445
    I kinda like that one. Looks nice. I know I'm not ready to build something like that yet, but I can save up and while I'm learning, I can work on it. It'd be a project but ultimately, I want something like that.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • Spork Schivago
      • Mar 2012
      • 4734
      If I can't use that touch screen, I guess I'd probably go for a QVGA type setup and could settle for a smaller resolution and everything. Maybe something like 320 x 240. I don't know how well that'd look though. But if I did that, I'd probably use a 16-bit interface. 5 for red, 5 for blue, 6 for green. That'd be 320 x 240 x 16 / 8 = 153,600 bytes of RAM or 150KB. I don't know how to tell how much flash I'd need because I don't know how large the program would be.
        • 30965
        forget the digikey stuff.
        http://www.ebay.co.uk/itm/261582968498
        keep it cheap
          • 30965
          or bigger
          http://www.ebay.co.uk/itm/221831832114
          • Spork Schivago
            • Mar 2012
            • 4734
            Okay. So I won't buy from digikey, but I have been physically looking at the various touch screens in the house and have decided I want 3.5". Maybe 4.5". Even though I won't buy it from Digikey, here's the screen I'm thinking about now:
            http://www.digikey.com/product-searc...ATXL%23-T-1-ND
            I was thinking of controlling it with maybe a PIC24FJ256GB106 PIC.
            http://www.microchip.com/wwwproducts...IC24FJ256GB106
              • 30965
              and again, you cant use it.
              those digikey displays have no controller and no easy way to even connect to them.
              this is a bit of a jump from a 2line crap-character display!!
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                takes 1-2weeks to europe.
                Yeah? It only takes 1 - 2 weeks for stuff to get here from Europe too. I don't know why it takes so long for China. Last time, it was over a month!
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #28
                  Okay. Yeah, it is a big jump and I'm definitely not knowledgeable enough in the subject to successfully do it. But that's what I want in the end. A real nice touch screen type display. Maybe down the road when I get my programmer I can start playing around more and while I'm waiting, continue to learn.
                    • 30965
                    what's it actually for?
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #30
                      A UV LED Exposure unit to make PCBs. But I want to make more than just that. I figured I could use the experience gained from interfacing a touch screen screen to this unit towards building an IR Reflow machine for BGA type stuff.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        #31
                        So, I've been on NewHaven's website, and for that display, they do seem to sell a controller board ( )
                        Well, they actually sell two. One for 8-bit and one for 16-bit. They're listed as being compatible with that 3.5" display. Could I not just use that controller board to interface the display with a PIC? I see the pinouts for J1 on that 16-bit board are as follows:
                        Code:
                        [FONT="Courier New"]J1 (SSD1963 input from user's MPU):
                        Pin No.    Symbol   External    Function Description
                                     Connection
                        1       VSS   Power Supply   Ground
                        2       VDD   Power Supply   Power supply for LCD and logic (3.3V)
                        3       B/L   Enable      Power Supply Backlight Enable
                        4        RS   MPU       Register Select.
                                             RS=0: Command, RS=1: Data
                        5       /WR   MPU       8080 mode: Active LOW Write
                        6       /RD   MPU       8080 mode: Active LOW Read
                        7-22    DB0-DB15  MPU       8‐bit bidirectional data bus
                        23       NC*    -        No Connect
                        24       NC*    -        No Connect
                        25       /CS   MPU       Active LOW Chip Select
                        26       /RST   MPU       Active LOW Reset
                        27-32     NC*    -        No Connect[/FONT]
                          • 30965
                          i'm thinking you should maybe forget pic's
                          they are designed for simple stuff.
                          either use AVR or as you like C/C++ go directly to using ARM-core.
                          look at this:
                          http://www.st.com/web/catalog/tools/...S1532/PF259090
                          http://stm32f4-discovery.com/stm32f429-discovery/
                          or without the addons:
                          http://www.st.com/web/catalog/tools/...N1847/PF262063
                          https://developer.mbed.org/platforms/ST-Nucleo-F446RE/
                          these things are sold at cost (next to nothing) to encourage developers.
                          dont buy them from ebay - use the distributors like element14 / mouser etc.
                            • 30965
                            Code:
                                         Connection
                            23       NC*    -        No Connect
                            24       NC*    -        No Connect
                            that's clearly going to need atleast 13pins.
                            the thing to remember when using microcontrollers is pincount - keep track of your pins or you can run out real fast!
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #34
                              look at this:
                              Okay Stj. I'm familiar with Element14. I like them. I really appreciate all the help and information you've provided. I thought the PIC would work because I saw a lot of posts on MicroChip about using pic24f's and pic32's to control the various LCD screens out there. Again, thank you for the links. I'll definitely be looking into AVR and ARM based processors. Always kinda liked ARMs.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                #35
                                Gotcha. I was also thinking maybe I should work on some simpler projects first, when I get my PicKit3 clone (Thanks for the link! Ordered from the link you provided!!!). Like perhaps trying to control an LED or something like that. Can you recommend any good free resources (or even paid ones) that go into details on how to program / use PICs? I see some have global interrupts, some don't, etc. I know a lot of my questions are probably novice type questions and I do appreciate you taking the time to help.
                                  • 30965
                                  for pic,
                                  mplab-x contains or can download a c-compiler,
                                  you can find loads of info and example code at microchip.com
                                  or things like this:
                                  http://gcbasic.sourceforge.net/
                                  for the ST stuff, they have links to free tools and examples.
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #37
                                    I got my PicKit3 clone today!!!! But now I have a bunch of questions! Nothing came with any manuals or anything. I got a nifty ZIF socket but I'm not 100% sure how to use it. The back has some words:
                                    Code:
                                    [FONT="Times New Roman"]
                                    DIP28, 40: J1:3 / J2, J3, J4, J5, J6, J7: 2-3
                                    DIP8, 14, 18, 20: J1:2 / J2, J3, J4, J5, J6, J7: 2-3
                                    PIC10FXXX: J1:1 / J3: 1-2 / J2, J4, J5, J6, J7: 2-3
                                    PIC16F57: J1:3 / J2:1-2 / J3, J4, J5, J6, J7: 2-3
                                    PIC16F59: J1:2 / J2, J3: 2-3 / J4, J5, J6, J7: 1-2
                                    [/FONT]
                                    I have a PIC16F628A, which is 18 pins, so I'd want the DIP18 settings. Setting J1 is easy because it's a two pin header and there's three options, 1, 2 and 3.
                                    It's J2 - J7 where I'm a bit confused. There's five three pin headers there but it doesn't tell me which of the three pins are pin 1 or pin 3. They just say J2, J3, J4, J5, J6, J7. Should I assume that the pin closest to the ZIF socket is pin 1? I'll post a picture so you guys can see what I'm talking about.
                                    • mariushm
                                      • May 2011
                                      • 3799
                                      #38
                                      Each J2 to J7 has 3 pins, pin 1 is the one closest to the ZIP socket.
                                      So when it says J* set to 1-2, it means pull out the jumper and set it on the first two pins on that J jumper. Where it says 2-3, put it on the last two pins.
                                      Sounds complicated, especially without documentation. Honestly, you could have bought an original Pickit3, you only buy it once after all.
                                      As for LCD displays, there's all kinds of them .. There's the old character only 2x16, 2x20, 4x16-20 character, which use a 4bit or 8bit data bus and 2-3 command wires.
                                      Then there's some graphical displays which use controllers with same commands as the ones above but wire the lcd pixels in such a way that there's no blank lines between character rows, so you can basically make any graphic by "uploading" a custom character font to the lcd display's memory (all have room for custom characters in them) and then when you send a command to print a character, it basically draws 8x8 pixels or something like that.
                                      Then there's displays which use i2c or spi to make connection between them and mcu, which means less wires but not necessarily more speed (i2c is especially slow), it just reduces wires.
                                      Then there's displays that use 8-16 bit data buses and some control lines to let you control large amount of rgb pixels or whatever...
                                      You already saw http://newhavendisplay.com/ , I'd suggest browsing through the various models and downloading the datasheets, you'll see how they connect.
                                      First learn to program a microcontroller, do some basic stuff like working with easy 2x16 character displays, then think about 320x240 pixel displays and so on.
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        #39
                                        Thank you! I knew how to read the jumper settings and when it says 1-2 or 2-3, I knew what that meant, just wasn't sure if pin 1 was closest to the ZIF socket or if pin 3 was. Thank you so much!
                                        I have a 2x16 display I believe, that I'm going to play around with. I bought the PIC pre-programmed but it came with source code. It's just in Pro BASIC. So I'm going to try to rewrite it in C. Then I'll try playing with the 320x240 pixel display like you suggest and then hopefully, I'll be ready for the touch screen stuff.
                                        I've seen PICs where there's some security bit that gets set. I've downloaded the MPLAB X and downloaded the XC8 compiler. I just want to make sure if I erase the original binary file on the PIC16F628A microcontroller and flash my C version on there, if I mess something up, I can just reprogram it with the original .hex binary file.
                                        Also, if my C program isn't correct, if I mess something up but it compiles fine, is there any chance I could actually damage the circuit board or the PIC? Or would it just not work?
                                        • mariushm
                                          • May 2011
                                          • 3799
                                          #40
                                          PIC16F628A is a relatively weak microcontroller, it has very few features, little memory and ram, there's much better chips out there with more built in features like hardware i2c and spi, which could be useful.
                                          My favourite goto for tests is PIC16F1519 : http://www.digikey.com/product-detai...2FP-ND/2651374
                                          It's wide dip so it's easy to put on prototyping board, it's dip40 so it has lots of i/o pins, has 28 KB of flash (16 kwords because each word is 14 bits) so you can just code without worrying about optimizations to reduce program size, built in 16 mhz oscillator so you don't need to use external oscillator to go above 4 Mhz (as it happens with your chosen pic)
                                          It's kinda hard to damage a pic just by programming it with bad code. MPLAB-X is pretty good about spotting mistakes so it would be kinda hard to create a broken binary and have mplab program it to a pic and damage the pic.
                                          • tommy1331
                                            hp envy 15t k000 debugging
                                            by tommy1331
                                            Hi, I'm quite new to this, I am trying to debug a faulty motherboard (DAY31AMB6C0). There was a fault in the DC input circuit with a faulty TVS diode after the first MOSFET shorting the VAD rail to ground. I was able to clear that fault by removing the diode and now the input section seems to be working correctly and I get the V3PCU power rail.
                                            But trying to start the board still fails, I put some RAM in it and shorted the power button to start it up but it only blinks the power LED in the DC jack assembly 3 times. Maybe the AC detect circuit is broken? Or is this more likely to be...
                                            04-28-2025, 08:12 AM
                                          • Ihandyrepair
                                            ID smd 6pin chip - GM2 for electric scooter display
                                            by Ihandyrepair
                                            Hi
                                            working on a not turning on Wheelspeed WS1 scooter.
                                            diagnosed - issue is the display/power button
                                            on the board, with the multimeter I noticed there is a short to ground. as the red wire has 0 ohm to ground.
                                            with infrared camera, this chip (photo circled) would heat up if I push power button on.
                                            but I can't find any replacement or online info of this chip.
                                            on the chip you can see it has a label GM2H, I have another good working display with the same chip but it has label GM2C
                                            could anyone help me id this chip and guide me to...
                                            05-08-2024, 06:59 PM
                                          • seppde
                                            Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                            by seppde
                                            I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                            ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                            The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                            In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                            02-09-2024, 05:19 AM
                                          • belalmondeo
                                            Car code scanner OBD1 adapter enquiry
                                            by belalmondeo
                                            Hello everyone there
                                            If You do remember me then I am Belal who posted an issue of his J2534 pass-thru Multi-Diag 2015 OBD II device a while ago and aside from my thanks that show my gratitude to all of those who have given me help with my issue I just wanted to go straight into my question which is whether using the OBD II to OBD I adapter to diagnose an older model vehicle like a GM 12 adapter safe enough and not gonna cause any catastrophic failure to my device and if it still can perform scanning with no issues?
                                            there's a link for the adapter: https://ebay.to/2UCWDDx
                                            04-05-2019, 06:00 PM
                                          • thrinrot
                                            Zotac GTX 960 2GB- 6pin PCIE Power not recognized
                                            by thrinrot
                                            Hi all!
                                            A friend of mine brought me a defective Zotac GTX 960 with a failing power detection.
                                            Even though the 6 pin PCIe power cable is plugged in, the card says "Plugin PCIe power cable and reboot".
                                            Since I have no schematics it is hard to find out the NVVDD_PGOOD trace.
                                            I checked if the Controller (NCP81174) sends a Power good signal and the signal VR_RDY at pin 3 is high. So I assume the controller is not sending a bad signal (?).
                                            I appreciate your help! :-)
                                            09-25-2021, 12:29 PM
