hp envy 15t k000 debugging
  • tommy1331
    • Apr 2025
    • Ireland
    Hi, I'm quite new to this, I am trying to debug a faulty motherboard (DAY31AMB6C0). There was a fault in the DC input circuit with a faulty TVS diode after the first MOSFET shorting the VAD rail to ground. I was able to clear that fault by removing the diode and now the input section seems to be working correctly and I get the V3PCU power rail.
    But trying to start the board still fails, I put some RAM in it and shorted the power button to start it up but it only blinks the power LED in the DC jack assembly 3 times. Maybe the AC detect circuit is broken? Or is this more likely to be an EC issue? I see in the schematics the EC handles the IO for the power button so it seems it's not completely dead, but it's also keeping MAINON low.
    3v seems to be missing along with the S5 power states, I think S5 should be available even when the laptop is off right? HWPG seems to also be lower but maybe that's expected when the laptop isn't on.
    I tried measuring the voltages on the different rails while pressing the power button to see if anything changes when it blinks the LED but it happens really quickly so it's a bit difficult to measure.
    EDIT: v3 seems to be generated by APL3523A only if MAINON is high, so that explains why it's missing at least.
  • tommy1331
    • Apr 2025
    • Ireland
    I went back and checked everything again and actually the board boots fine from battery now, and the adapter I was testing it might be the actual issue, the AD_ID seems disconnected in it. Looking at the schematics it looks like that would result in the 90W power supply being detected as a 65W power supply. Is there a way to force boot off of a power supply ignoring the AD_ID check or do I need to fix the power supply plug before debugging further?
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • reessi
      HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
      by reessi
      I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
      It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
      What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
      I have checked these lines in diode mode and they seam normal -> 600.
      I have checked to see if they come on for even a fraction of a second...
      Yesterday, 09:14 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • themosttogain
      HP Envy 13-BA1565na with intermittent power button
      by themosttogain
      Hope someone can give me some suggestions on this because i'm at my wits end with it...
      I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
      Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
      07-12-2024, 03:03 AM
