Questions about PicKit 3.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I'm interested in buying a PicKit 3 programmer, like the one located here:
    http://www.microchip.com/Development...paign=PICkit+3
    I've modified a circuit that has a pre-progammed PIC (16F628A) and added an ICSP 6-pin header. I noticed though, that the kit only comes with the PicKit 3 and a USB cable. Does anyone know where I can get the 6-pin cable at? Also, I've seen talk about an RJ-11 connector. Is that just for debugging in-circuit or am I supposed to be using RJ-11 connectors instead of ICSP 6-pin male headers? If so, that'd really suck.
    Finally, I see talk of some special header for in-circuit debugging. It appears to be a circuit board. But there's a few different "header" packages. How useful is in-circuit debugging and do I really need to purchase one of these special "headers"?
    Here's a link to a PDF that talks about the various headers. https://cdn.badcaps-static.com/pdfs/...9062dabff9.pdf
    This is all new to me so I apologize if some of my questions sound a bit naive. Thank you.
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • 31007
    Re: Questions about PicKit 3.
    got a pk3 here.
    the pk3 uses a socket-strip 2.54mm pitch 6pin
    i make cables using pinstrips.
    btw, the design is open and the chinese have nice clones.
    http://www.ebay.com/itm/141774464184
    this one comes with cables and a programming board!
    (my next upgrade )
      • 31007
      btw, make sure you use MPLAB-X and not the old mplab software.
      • Spork Schivago
        • Mar 2012
        • 4734
        Originally posted by stj
        got a pk3 here.
        (my next upgrade )
        Thanks Stj! I've seen some of the clones but I think because this is my first time playing around with programmable ICs, I'm going to stick with an official PicKit3, just to rule out possible problems.
        So the official PicKit3 doesn't come with the cable and I need to make one myself or find a good site that sells them? For the pins on the board, I used MA06-1 from the con-lstb library in Eagle. I don't know what the pitch is though.
        • Spork Schivago
          • Mar 2012
          • 4734
          Okay, and MPLAB-X comes as a free download or do I have to pay that? I seen a few different MPLABs and weren't sure what was what. Haven't really looked into it too much but one was MPLAB REAL ICE I think, another one was X and then finally MPLAB ICD 2 and MPLAB ICD 3.
          • Spork Schivago
            • Mar 2012
            • 4734
            I was thinking for the cable, maybe something like this:
            http://www.ebay.com/itm/5pcs-of-Dupo...YAAOSwm8VUr37w
            What do you think Stj?
              • 31007
              the pin pitch is the same as stripboard or a chip, .1"
              it's intentional so you can put a pin-header on the board and just drop the programmer onto it without a cable!
              (providing you leave clearance around the pin header for the programmer casing)
              mplab-x is free.
              http://www.microchip.com/pagehandler...family/mplabx/
              and the chinese clones dont have issues because microchip made the original schematics and board layout public!
              the ebay link will work, but it's a lot of money when you can just get a strip of 30pins that you snap to size for next to nothing.
              http://www.ebay.com/itm/281784762715
              • Spork Schivago
                • Mar 2012
                • 4734
                mplab-x is free.
                Thanks! On this design, there's no way to fit the PicKit on the board. I should've thought of that before but when I was looking at PicKit's on ebay, I didn't realize they where clones and I thought all of them came with a cable. I might try to just make a cable myself if I can find a cheap enough female header / socket that goes into the PicKit. I really appreciate all the help.
                If you're certain the chinese ones are of high quality, I could save some cash and buy one that comes with the cable and one of those nifty ZIF sockets.
                  • 31007
                  it's male - with pins that goes into the pk3
                  i would 100% go for that chinese one with the chip-socket adapter.
                    • 31007
                    pic
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      pic
                      Thanks! No idea why I said female. I need female end for the board, the male end for the PicKit3. I'm going to order the one you linked to me. It's not in the states so it might take a little bit to get here, but it seems to come with everything.
                      On a side note,
                      The original design has a PIC 16F628A and a 16x2 HD44780 LCD screen. The PIC is using 4 data lines, not 8. That'd mean it's communicating with the LCD screen using 4-bits, right? Also, if I wanted to upgrade the screen to something a bit more fancier, maybe at the very minimum a 16x4 type screen, if I picked out a similar LCD screen, would I have to change the circuit at all or just the code on the PIC? Eventually, I'd like to add a real nice screen. Maybe even touch screen or something like what my Weller WX2 has.
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        Tried to order it Stj, but got an error message :'( Contacted the seller about it. Error message was:
                        This seller didn't include shipping costs to your location. Please contact the seller or change your address.
                        Also, I see the US dollar isn't as strong as GBP. 1.00$ = 0.64 GBP's. That's okay though. I think GBP's are British Pounds but the item says it's shipping from Shenzhen , Guangdong, China. I thought the Chinese used yen's.
                          • 31007
                          try these:
                          http://www.ebay.com/itm/391241142618
                          http://www.ebay.com/itm/351488697372
                          if those dont work,
                          go to ebay.com
                          then search "pickit3" and sort by price-inc-postage
                            • 31007
                            if you want a nice display, forget parallel character displays.
                            use a pic with an SPI serial interface,
                            then you can use a colour graphic display.
                            the chinese sell surplus graphic displays - presumably intended for fones & mp3 lpayers for less than character displays.
                            if you do use a 44780 display, the interface is the same regardless of number of lines or characters.
                            btw, it's standard to put pins on the board, and use a female end on the programming cable.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              Okay, good to know I'm following a bit of standard with the pins there.
                              So, the PIC I'm using doesn't have an SPI serial interface? I'd like to do what you're suggesting. Stop using the parallel character display and use a colour graphic display.
                              Do you know any PICs that have an SPI serial interface? I see MicroChip says a bunch of their devices support it. How hard would it be to implement something like this? Is it a lot more work than what I currently have? Thanks.
                              • Spork Schivago
                                • Mar 2012
                                • 4734
                                Looks like maybe the PIC18F8722 would work.
                                  • 31007
                                  u.s. ebay link
                                  http://www.ebay.com/itm/141752941245
                                    • 31007
                                    microchip has a parametric search you can use,
                                    what else does the chip need? how muh flash, ram, i/o pins?
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      Thanks. Made an offer for one located in the states that doesn't come with a ZIF adapter (I'll buy one separately if the guy accepts my offer). If not, I'll try ordering that one. The other two you posted won't ship to the USA either. Kinda sucks ordering from China and Hong Kong because it takes for ever!!! for the stuff to get here.
                                        • 31007
                                        takes 1-2weeks to europe.
                                        • tommy1331
                                          hp envy 15t k000 debugging
                                          by tommy1331
                                          Hi, I'm quite new to this, I am trying to debug a faulty motherboard (DAY31AMB6C0). There was a fault in the DC input circuit with a faulty TVS diode after the first MOSFET shorting the VAD rail to ground. I was able to clear that fault by removing the diode and now the input section seems to be working correctly and I get the V3PCU power rail.
                                          But trying to start the board still fails, I put some RAM in it and shorted the power button to start it up but it only blinks the power LED in the DC jack assembly 3 times. Maybe the AC detect circuit is broken? Or is this more likely to be...
                                          04-28-2025, 08:12 AM
                                        • Ihandyrepair
                                          ID smd 6pin chip - GM2 for electric scooter display
                                          by Ihandyrepair
                                          Hi
                                          working on a not turning on Wheelspeed WS1 scooter.
                                          diagnosed - issue is the display/power button
                                          on the board, with the multimeter I noticed there is a short to ground. as the red wire has 0 ohm to ground.
                                          with infrared camera, this chip (photo circled) would heat up if I push power button on.
                                          but I can't find any replacement or online info of this chip.
                                          on the chip you can see it has a label GM2H, I have another good working display with the same chip but it has label GM2C
                                          could anyone help me id this chip and guide me to...
                                          05-08-2024, 06:59 PM
                                        • seppde
                                          Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                                          by seppde
                                          I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                                          ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                                          The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                                          In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                                          02-09-2024, 05:19 AM
                                        • belalmondeo
                                          Car code scanner OBD1 adapter enquiry
                                          by belalmondeo
                                          Hello everyone there
                                          If You do remember me then I am Belal who posted an issue of his J2534 pass-thru Multi-Diag 2015 OBD II device a while ago and aside from my thanks that show my gratitude to all of those who have given me help with my issue I just wanted to go straight into my question which is whether using the OBD II to OBD I adapter to diagnose an older model vehicle like a GM 12 adapter safe enough and not gonna cause any catastrophic failure to my device and if it still can perform scanning with no issues?
                                          there's a link for the adapter: https://ebay.to/2UCWDDx
                                          04-05-2019, 06:00 PM
                                        • thrinrot
                                          Zotac GTX 960 2GB- 6pin PCIE Power not recognized
                                          by thrinrot
                                          Hi all!
                                          A friend of mine brought me a defective Zotac GTX 960 with a failing power detection.
                                          Even though the 6 pin PCIe power cable is plugged in, the card says "Plugin PCIe power cable and reboot".
                                          Since I have no schematics it is hard to find out the NVVDD_PGOOD trace.
                                          I checked if the Controller (NCP81174) sends a Power good signal and the signal VR_RDY at pin 3 is high. So I assume the controller is not sending a bad signal (?).
                                          I appreciate your help! :-)
                                          09-25-2021, 12:29 PM
