What chip is the large sn0710031 ?
Help identifying this chip - battery controller chip ?
Re: Help identifying this chip - battery controller chip ?
I believe it's made by Texas Instrument and I couldn't find any datasheets on the chip. When I searched for it though, I found an Enhanced Product Hex Buffer/Driver With Open-Drain Outputs ( http://www.alibaba.com/product-detai...680448902.html ). SN74LVC07A-EP lists your sn0710031 as a related part number0. Here's a datasheet for the SN74LVC07A-EP https://cdn.badcaps-static.com/pdfs/...d50210e6ea.pdf
I've contacted TI to see if they can help identify it. Hopefully they'll respond soon with a link to a datasheet or something.
Hope this helps.Last edited by Spork Schivago; 11-17-2015, 01:50 PM.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full -
Yeah, before you replied, I thought the same and modified my statement. We must of been cross posting or whatever it's called. I still think it's made by TI though and hopefully they'll respond soon.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Got a response from TI. I'll just copy and paste what they said Gabriel...
You can look up part marking on a tool on our website. I have looked up the part and this is what I got: http://www.ti.com/packaging/docs/partlookup.tsp#divline
Part number | Marking | Package | pins Status | Description
LP38842T-1.2/NOPB LP38842T-1.2 KC | 5 ACTIVE 1.5A Ultra Low Dropout Linear Regulators
LP38842T-1.5/NOPB LP38842T-1.5 KC | 5 ACTIVE 1.5A Ultra Low Dropout Linear Regulators
TL4242TDRJRQ1 4242T DRJ | 8 ACTIVE Automotive Adjustable LED Driver
I know the formatting is a little hard to read. Couldn't figure out how to add a grid. It's | separated.
As you can see, none of them have 30 pins like your chip. So now I'm questioning whether it's actually TI or not. Sorry. Wish I could be more helpful.Last edited by Spork Schivago; 11-17-2015, 05:12 PM.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Yes it is a Dell raid battery - I have a Lsi 9260-8i and their battery cost 227$ here in Norway and as these Dell Perc 6 batteries has the same pinout and battery plug as Lsi and as the Perc 6 raid card is made by Lsi I thought I could swap them but 9260 card does not see the battery.
I was hoping that there was a small eprom that could be changed to match Lsi data.
Pinout is data,clock,-,T,+ see picture.Last edited by Gabriel; 11-21-2015, 08:38 AM.Comment
The date codes on the chips should tell you when the IC (controller?) was manufactured. The markings are consistent with TI markings, AFAICT.
I would determine the controller's supply and ground pins. I would also trace the data, clock, and T signals from the connector to the controller.
Also determine where the temperature sensor (thermistor?) goes. That would be an ADC input to the controller. In fact ISTM that the entire circuit should not be too difficult to trace.
Once you have this information, then we could go to the Wayback Machine and determine which ICs were available at that time.
http://web.archive.org/web/*/http://www.ti.comLast edited by fzabkar; 11-21-2015, 02:03 PM.Comment
http://web.archive.org/web/*/http://www.ti.com-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
As has already been suggested, the chip is probably "house marked". That is, the chip is probably a custom part made for Dell. ISTR that "SN" was a prefix that was commonly assigned to such custom parts. If it is a custom chip, then TI would be prohibited from releasing proprietary data to you, as such data would be the property of Dell.Comment
Oh! I understand now! When you said house mark, for some reason, I thought you meant it was marked in such a way where only the people who made it, TI, would know what the markings meant. Sorry for the confusion and thanks for the clarification!-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
I found a whole bunch of "SN0" ICs in the following TI list:
http://focus.ti.com.cn/cn/download/a...alldevices.txt
Strangely, Mouser lists a SN0708100P device. If it is a proprietary OEM part, then I can't understand why Mouser would be able to sell it.
http://au.mouser.com/ProductDetail/T...ts/SN0708100P/Comment
I finally got hold of two defect Lsi battery modules for free to play with.
Boy howdy was I lucky, no sn0710031 on this board but a TI bq2060a using an external eeprom. So instead of trying to modify the Dell unit I will use the Lsi modules by replacing batteries and perhaps reprogram the eeprom.
The Dell and Lsi units use two different batteries, both batteries are Li ion but they have different capacities and the Samsung battery has a hard metal case as the Sony US503759 a8h has the regular softer package.
Sony battery is 1350mAh and Samsung is 2000mAh.
Can I use the Samsung ICP103450S battery on the Lsi board or will it catch fire ?
I can perhaps dump the eeprom content and I should perhaps be able to zero it out to make sure a new battery will be charged properly, if you see the pictures the defective battery has only 385mAh left,eeprom also holds serial number, manufacturer information and design capacity.
Anyone good at hex editing ?
Added some of the datasheets for you, could not find Sony battery datasheet.Last edited by Gabriel; 11-28-2015, 11:45 AM.Comment
or use a power supply to keep the controller alive and live swap the cell.most will recal on a full cycle.
btw the cell is cheap and easy to get in the form of a samsung blackjack extended battery.$4 on ebay.got a ton of em in my extended family in harbor freight magnet lights with a tp4056 board.Last edited by kc8adu; 11-28-2015, 02:19 PM.Comment
I got curious ...
FDW2511NZ, Fairchild, Dual N-Channel 2.5V Specified PowerTrench MOSFET, 20V, 7.1A:
24LC01B, Microchip, marking 4L1BI, 1Kbit, I2C, serial EEPROM, 2.5 - 5.5V:
https://cdn.badcaps-static.com/pdfs/...c3cf891b16.pdf
bq2060A, Texas Instruments, SBS v1.1-Compliant Gas Gauge IC:
https://cdn.badcaps-static.com/pdfs/...43804650eb.pdf
SN74LVC1G08, Texas Instruments, marking CEH, Single 2-Input Positive-AND Gate, 1.65V to 5.5V:
https://cdn.badcaps-static.com/pdfs/...b92049dee8.pdf
Si7108DN, Vishay Siliconix, N-Channel Fast Switching MOSFET, 20V, 14A:
https://cdn.badcaps-static.com/pdfs/...fb551f6ef1.pdf
MAX835EUK-T, Maxim, marking AAAY, Micropower Latching Voltage Monitor, SOT23-5:
https://cdn.badcaps-static.com/pdfs/...9619a44ad0.pdf
MAX1725EUK+T, Maxim, marking ADNK, SOT23, Adj 1.5V to 5.0V, 2.5V - 12V, Ultra-Low IQ, LDO Linear Regulator:
https://cdn.badcaps-static.com/pdfs/...8ac5ffd395.pdf
SFH-0412A, Sony, Self Control (SC) Protector, marking 12AH1, 12A, 4.0V/7.1V:
https://cdn.badcaps-static.com/pdfs/...715af27c24.pdfComment
Hehe I thought I had a msop adapter but I did not - got a few on its way, expect a week before I can upload bin file.
Anyone up to date on battery chemistry ? I'm worried about cut off voltage and charging current to be incompatible with the Samsung battery. Are they compatible ?Comment
Seems like the Lithium Ion and Lithium Polymer batteries are charged the same way, thumbs up.
Despite the structural differences, you should treat them similarly and consider them two
versions ('gentle and light' 'tough and strong') of the same kind of battery.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by mkdjHello everyone,
Mark and model: ASUS X571
Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
Tests already made:
- Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
- I have removed... -
I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
by AJ847.63ei all,
Cab anyone identify this chip? Pics attached. It's marked L8=6E 74L.
History: laptop came from a e-cycler. Dropped off a few laptops wanting to get rid of them so he asked if we wanted them, apparently he tried swapping the battery on this one and acidentally broke the tip of the battery connector and plugged the battery in upside down.
All readings on the battery pin seem normal though (comparing to a working same model board).
Connecting the charger you can see the above mentioned chip pulsing so it looks like its going into protection mode, but checking... - Loading...
