What is a mechanical solder sucker?
  • johnnyh55
    • Oct 2015
    • 44
    Re: What is a mechanical solder sucker?
    Well according to post #4 in this thread, it's perfectly fine to replace the aluminum electrolytic caps with solid polymer ones:
    https://www.badcaps.net/forum/showpo...40&postcount=4
    Is that true?
      • 31003
      yes, if you select it carefully.
      • johnnyh55
        • Oct 2015
        • 44
        Ok, can you elaborate on select carefully? I was only going by 680uf and 4volts.
          • 31003
          what is the original cap details?
          • johnnyh55
            • Oct 2015
            • 44
            from what i can res 680uf 4volts 105c TMJ and on the top its written 67 c7
            • lookimback
              • Aug 2013
              • 1489
              I've used the spring loaded ones for years and never damaged a board. I used to really hate them, but then I discovered that a bit of silicon grease injected into the tip prevents the solder from sticking and makes them work pretty good.
              ------------signature starts here------------
                • 31003
                that sounds like a poly already - got a foto?
                • johnnyh55
                  • Oct 2015
                  • 44
                  They are exactly like this
                  • johnnyh55
                    • Oct 2015
                    • 44
                    Actually I guess it's a poly since it doesn't have the vents on top. So my question is can I replace this capacitor with a sleeveless capacitor? It basically looks like an all metal cap but it has the same values.
                    • johnnyh55
                      • Oct 2015
                      • 44
                      If anyone could help me choose some 680uf 4v capacitors below:
                      http://www.digikey.ca/product-search...=0&pageSize=25
                      I don't know exactly what ESR value to look for but I would like the capacitors to be close to 8mmx8mm although there is not much choice in those dimensions. I would need the width to be as close to 8mm as possible so they don't touch each other side by side.
                      • johnnyh55
                        • Oct 2015
                        • 44
                        Well I got all the capacitors in, not sure if I should power up the board, i'm not confident in skills. Do you guys think it looks ok or some things might be shorted once power is applied?
                        • corrize
                          Best way to solder LVDS connector for beginner (and qfn) ?
                          by corrize
                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                          See the test :
                          https://youtu.be/bNAzC-EvqHs?t=1767
                          With hot air from bellow the board, that's...
                          03-09-2023, 02:57 AM
                        • myth77
                          UV solder mask - high temp resistent, recomendation?
                          by myth77
                          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                          Is there any solder mask...
                          03-28-2022, 04:04 AM
                        • petemanuk
                          BGA solder balls not connecting - help pls
                          by petemanuk
                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                          11-16-2022, 05:21 AM
                        • flat-earther
                          Hoover FM216LI cordless vacuum refuses to charge
                          by flat-earther
                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                          06-06-2025, 03:14 AM
                        • acedogblast
                          by acedogblast
                          11-02-2024, 05:13 PM
