Sony Bluray Player problem
  • caphair
    • Nov 2011
    • 1249
    So I have this smart bluray player that when a disc is loaded says "no disc" however if I keep ejecting and loading real quick it'll eventually read the disc and play fine, no skipping, freezing etc.
    If the disc is removed and another loaded it's always a gamble if it'll read it initially. Most times I have to keep quickly pressing eject to get it to load.
    I tried cleaning the lens, there aren't any pots on it to try adjusting the power.
    What I'm curious about though is if it's a weak laser issue if sometimes it does detect a disc and play flawlessly. Wouldn't a weak laser have trouble reading all the time?
    • 31258
    Re: Sony Bluray Player problem
    what does it do with dvd's or audio cd's?
    • caphair
      • Nov 2011
      • 1249
      Same thing happens with various disc types
        • 31258
        then it's not the laser, because there are different lasers for each disc type in the assembly.
        have you opened it to do a visual check?
        • caphair
          • Nov 2011
          • 1249
          I have nothing looks out of the ordinary and I tried moving the lens forward, back etc to see if it alters the operation. But it didn't do anything.
          Any ideas?
            • 31258
            poor psu smoothing effecting focus?
            • caphair
              • Nov 2011
              • 1249
              Hmm I wonder. I have noticed that if it has been playing a disc, if I change it it'll read it almost first time every time. But if it hasn't been used, it gives the no disc error.
              • vinceroger69
                • Mar 2012
                • 6714
                maybe a slightly worn/sticking motor that spins the disk up to speed?
                • caphair
                  • Nov 2011
                  • 1249
                  I think the way this one works is the motor spins after laser detects a disc. It's the same laser in the slim ps3s
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    whats the model number of the player?
                    • caphair
                      • Nov 2011
                      • 1249
                      Sony BDP-BX37
                      • caphair
                        • Nov 2011
                        • 1249
                        I've also noticed the lens shifts a quick three movements/jerks before it says no disc, when it works it either doesn't shift or shifts one or two times before disc spins up and loads
                          Did you try audio CD or regular DVD?
                          • caphair
                            • Nov 2011
                            • 1249
                            I tried both and same issue
                            • caphair
                              • Nov 2011
                              • 1249
                              It's just strange that once it loads a disc, and has been playing for a good 20 min it'll easily detect another one until the unit has been turned off for a while then it's constant "no disc"
                              • ChaosLegionnaire
                                HC Overclocker
                                • Jul 2012
                                • 3266
                                • Singapore
                                hmm that sounds like a bad solder joint issue. it doesnt work when its cool cuz the solder contracts and doesnt make contact. then when it heats up the solder expands and contact is restored. could also be badcaps in the psu of the player, mainboard or bluray drive.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  There are two smd electrolytic caps that provide 12v and 5v to the motor and lens, I replaced them out of curiosity and no change in operation.
                                  Caps on PSU all look good, no esr meter to know for sure though.
                                  Here's a pic:
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Could check if it's temp related by hosing it down with a hair dryer. Don't the lasers in the ps3's fail quite a bit ?
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      Maybe the heat thing was a fluke, tried it this morning after itd been unplugged all night. Read disc first attempt, then nothing for a while after that.
                                      If it's the laser, just don't understand why it'd work randomly and read six perfectly until it's removed.
                                        • 31258
                                        the laser in the ps3 is pretty reliable, they just dont like being dropped or banged around - it makes the optics come loose.
                                        • ahmedtou
                                          HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                          by ahmedtou
                                          help me please
                                          I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                          When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                          I will share all the details with you, including the disc information.
                                          Code:
                                          HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                          Current Profile: BD-R
                                          Disc Information:
                                          Status: Empty
                                          State of Last Session: Empty
                                          Erasable: No
                                          Free Sectors: 12,219,392
                                          Free Space: 25,025,314,816 bytes
                                          Free Time: 2715:27:17 (MM:SS:FF)
                                          Next
                                          08-27-2025, 08:49 AM
                                        • dkneyle
                                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                          by dkneyle
                                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                          02-01-2022, 02:08 AM
                                        • bogosort
                                          Sony DVD player stuck tray (DVP-SR310P)
                                          by bogosort
                                          I have a Sony DVD player with a stuck tray. It seems that moving or pressing on the tray makes it work.
                                          Anyone knows why?
                                          Thank you....
                                          05-11-2024, 04:29 PM
                                        • Junior††
                                          PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                                          by Junior††
                                          Good Afternoon fellas,
                                          Issue:
                                          Disc is showing as not supported when a disc is put in.
                                          Here's what I've done, you can skip this if you just wanna know the question:
                                          - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                                          - reflowed the disc drive connector
                                          -reflowed the chip in question (shown on image)
                                          - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                                          Question:
                                          I...
                                          02-19-2025, 12:48 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
