Fluke 179 won't tun on
    • 31161
    Re: Fluke 179 won't tun on
    the display is a matrix, but has no drive circuitry, the driver is integrated into the microcontroller usually.
    lcd requires a high frequency ac drive btw, if the mcu is dead or the crystal is dead you wont see anything.
      • 31161
      looking at page9, it can handle 2 crystals or clocks for some reason, and it has a reset/nmi pin that i would check is not stuck low.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        So I have attached the micro controller info that TI has. Right now we are interested in page 6 for the pinout, page 9 for block diagram function and pages16,17,18 for terminal functions. If you look at these you will know where to test the frequency and supply voltage. I love TI they tell you everything.
        • tibimakai
          • Jan 2012
          • 3680
          Later on, when I get home I will start measuring.
          • tibimakai
            • Jan 2012
            • 3680
            I have turned to Ohm scale, with the switched installed.
            I'm measuring pin #1&2 of the TI IC, which are the digital + and analog + and they are not getting any voltage. Basically, the TI IC is not getting turned on.
            There is a 5 pin VDO(I assume) at the bottom right of the TI IC which also not getting any voltage.
            The measurement,s should I take from the COM, right?
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Make sure the switch is actually making contact
              • tibimakai
                • Jan 2012
                • 3680
                I have placed the PCB in the case and that way I have turned the switch.
                I'm trying to measure DJ Ricoh's measurements, but I'm having problem seeing those small numbers.
                At pin #14 I have the battery voltage of 8.963V.
                At all the pins I'm measuring above 7V. That is normal?
                CD4069UBE
                • tibimakai
                  • Jan 2012
                  • 3680
                  Pin#
                  1 - 13= 7.6V and slowly drops
                  14= 8.8V and slowly drops.
                  This slow drop, happens at the battery as well, measured from the COM.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I'm noticing some kind of yellowish deposit inside the case, specially at the bottom of the meter around the plugs area.
                    Could be a spill victim?
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Originally posted by tibimakai
                      Pin#
                      Are you measuring right across the battery when in circuit?
                        • 31161
                        is the battery good? i know it's a stupid question.
                        start at the board where the battery lead is soldered - i'v had the battery clips fail on stuff before.
                        i suppose there is a voltage regulator circuit we need to find.
                        • dj_ricoh
                          • 2073
                          #52
                          CD4069UBE
                          Ill open it again check.
                          Tell me where to focus.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Thanks for opening yours, but I don't know where should be look for yet.
                            Maybe somebody else can point me what else to check first.
                            The battery has 8.963V.
                            When I measure and use the the battery's negative terminal, or the COM, it seems like the result is the same.
                            We need to find out, how the battery voltage reaches the TI IC.
                            • dj_ricoh
                              • 2073
                              #54
                              like i said mine got 5.7v
                              i`ll try to trace it down.
                              the sad part is that this is the only dmm at my home
                              • tibimakai
                                • Jan 2012
                                • 3680
                                That is not possible to trace it, if it's the only one dmm that you have. Thanks though, for you effort.
                                  • 31161
                                  you need a cheaper meter for "risky" work.
                                  most people i know have a good meter on the bench - usually fluke or UNI-T and a cheap meter for outside work incase it gets lost or damaged.
                                  the same with the soldering iron, good one on the desk, and a cheap one for "away" work.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    So we need to go back to the information sheet on the micro controller. The supplied voltage to this chip is measured from Vcc to Vss. You can see this on page 53 of the attachment I provide previously. The range of the low supplied voltage is from 1.8 Volt to 3.6 volts maximum this can be seen on page one. If this measurement is at or above 3.6 volts maximum the chip will be damaged. So if you can try to measure this voltage. If it is too hard to measure on the processor then follow the traces back to a component that would be easier to measure. So there are two possible available supplies voltages. One pair is DVcc1 the positive and DVss1 the negative. The other pair is DVcc2 the positive and DVss2 the negative. You will need to measure across each pair. Also, you want to measure the pin under pz terminal which is the 100 pin chip not the 80 pin chip
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #58
                                      Finally, the right question is being asked.
                                      The MSP430 maximum voltage is 3.6V. The Fluke 179 uses a 9V battery.
                                      So something has to drop the voltage down into the 3V range. If the photos weren't so bad, I would be able to see the 5V LDO that you are talking about.
                                      Thus, if the MSP430 isn't getting around 3V, check the 5V LDO. If there is no output on the 5V LDO, check the input voltage on the LDO. If there is no voltage on the input pin, check the trace from the 9V Battery positive terminal to see if the track/via is broken. If I found one broken track, there might be more.
                                      As I said, there are no schematics, but if you photograph the 179 PCB and use a very bright source like the sun from behind, you might be able to see the traces. For example, here is my photo of the UEI DM393
                                      http://www.eevblog.com/forum/repair/...-all-the-time/
                                      As you can see, the picture is focused and you can see all the writing even on the smd components. You can see all the traces despite it being a multilayer board.
                                      --- begin sig file ---
                                      --- end sig file ---
                                      • keeney123
                                        Lauren
                                        • Sep 2014
                                        • 2536
                                        I have cleaned the image up some. If you magnify it I think you will be able to see the runs.
                                        • keeney123
                                          Lauren
                                          • Sep 2014
                                          • 2536
                                          This is the best I can touch up of the picture for you retiredcaps.
                                          Tibimakai the way to take the picture would be to put a white light under it, somewhere around 5000 kelvin. Make sure the board is completely flat. If the light shines around the edges of the board use black paper from the board to the light to block this out just use scotch tape to secure the black paper. Next if your camera has a macro setting then set it to this. Get with-in 30" of the board aim down making sure the camera is completely parallel with the board. Fill up the entire camera view, however close the camera will let you get. Take pictures with flash off and then flash on. With flash off it is best to take picture outside if you can. Good luck.
                                          • chth96
                                            Is it possible bridging tiny broken trace
                                            by chth96
                                            When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                            cutting tiny trace.
                                            This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                            Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                            But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                            12-03-2022, 11:32 PM
                                          • re-atari
                                            Gigabyte GA-H110-D3A schematic/boardview needed
                                            by re-atari
                                            Hello all,
                                            Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                            This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                            02-24-2025, 06:45 PM
                                          • ugamazing
                                            820-02020 PPBUS_AON missing
                                            by ugamazing
                                            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                            02-05-2025, 04:21 PM
                                          • jpreza
                                            Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                            by jpreza
                                            I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                            Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                            It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                            Looking at the card, it appears to be missing the following:
                                            1x 1.0uH inductor - orange square
                                            2x...
                                            11-01-2024, 10:54 PM
                                          • gurj1979
                                            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                            by gurj1979
                                            Hey guys.
                                            Need help with this one.
                                            Fan not spinning due to missing PWN Fan signal.
                                            Also 5 seconds from powering up it freezes, unless in BIOS.
                                            But as soon as Windows starts to load, it will freeze.
                                            CPU is COLD / Room temp when it freezes.
                                            I've replaced the CPU, same problem.
                                            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                            Replaced fan - same problem.
                                            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                            08-19-2024, 05:22 PM
