12v switch to 2 fans murders the smaller fan
  • xboxhaxorz
    • Jan 2011
    • 196
    I have a small switch that is connected to 2 fans the long wire from the switch is connected to the fan + wire, at that same exact point another wire is soldered which goes to the other fan + wire
    So the 12v wire from the switch is split into 2 which connects to both fans
    The ground is also done the same way
    When i had it wired this way, both fans would work via the switch after disconnecting power and reconnecting the small 60mm fan would no longer work but the 80mm fan did, i replaced the 60mm fan and the same thing happened and neither will work
    When i solder 2 different wires to the 12v switch and connect them to the fans, both fans work without fail
    I am not sure exactly why this is occurring, the amperage requirements are slightly different for the fans
    • 30910
    Re: 12v switch to 2 fans murders the smaller fan
    i dont understand your description.
    • SteveNielsen
      Retired Tech
      • 2327
      It sounds like the third fan is either shorted or otherwise drawing too much current in combination with the other two and dragging the 12v low. Either that or you wired something wrong.
      Edit: yeah, STJ is right, it's hard to understand exactly what you're doing. Are you trying to run 3 fans? 2 fans? Are they all 12v fans? How exactly have you wired them and the switch?
        Show us the pictures so we can see exactly how you wire them up.
        "The ground is also done the same way" and why do you have to hook up the ground wires to the switch?
        Your description of what you are doing is not very clear at all.
        • keeney123
          Lauren
          • Sep 2014
          • 2536
          This should help you. http://pcbheaven.com/wikipages/How_PC_Fans_Work/
          • RJARRRPCGP
            • Jul 2004
            • 6301
            I think it looks like this:
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • SteveNielsen
              Retired Tech
              • 2327
              That doesn't show how the power source is wired and the fans are in series, they should be in parallel if it's a 12v source and they are 12v fans. There is also no reason to switch the negative.
              • xboxhaxorz
                • Jan 2011
                • 196
                yea it was a terrible explanation so basically in the drawing the 12v wire from psu is going to a 4 pin male connector, a female connector is inserted and on the other end is the fan 60mm
                i wanted to install another fan so i basically soldered wires to the male connector on the inside of the chassis to the corresponding wires
                the new 80mm fan works just fine but and when i insert the female connector it works as well
                after a power cycle the 60mm fan no longer works, i tried 2 more fans and the same thing happened
                when i solder 2 long wires directly from the psu to the new fan, both of them work fine
                  So the two black wires of both fan are connected to the pin of the connector that goes to the power supply return wire, the RED positive wires are connected together to another pin of the connector which is then connected to a switch. What kind of switch is this?
                  Show us the pictures of your setup.
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    Can you post a picture of the actual switch, fans, and wiring? The drawings aren't very clear and confusing.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Yes if it an AC switch with a neon light it most likely will not work. If needs to be a 12 DC switch with a led light.
                        What happen if you bypass the switch terminals with wire (leave the switch in place)?
                        And what DCV do you get on the red and black wires of the fans when it is not working?
                          • 30910
                          that's not true, you just wont get any light from it.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6301
                            The negative wiring in my picture was hypothetical. That wasn't where it will return to exactly. LOL.
                            But, the description sounded just like that for the positive.
                            Arc A770 16 GB
                            • SteveNielsen
                              Retired Tech
                              • 2327
                              His drawing shows the fans in parallel, as they should be. What I wonder is what is the four pin connector going to? +12v and ground? If so then why is the switch connected to another +12v source? If he's getting +12v from the 4-pin connector then the switch belongs between the +12v at the connector and the two +12v leads to the fans. The ground goes directly to the negative leads for both fans.
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                Would it not depend on if the light is in series or parallel?
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  Should it not be just measure with a meter to see what one gets and then connect it up correctly?
                                    Per his drawing the two FANS are connected in parallel so all he has to do is to measure the DCV between the red and black wires of the FANS to see what he gets.
                                      • 30910
                                      maybe one fan draws more current and the connector is shit.
                                        Well I hope he will follow through with all of our request, I think he may have high resistance between the 12V power supply output and the junction where the two red wires are tied together or high resistance on the Ground wire to the power supply return.
                                          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                                          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 05:30 AM
                                        • JayPoorJay
                                          Hot Water Rad - A Few ECU Fans and a Timer Switch
                                          by JayPoorJay
                                          Good Afternoon, Good People.
                                          I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                                          I REALLY would appreciate y'alls help.
                                          This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                                          10-29-2024, 12:54 PM
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • Natob82
                                          Micro Momentary Push Switch?
                                          by Natob82
                                          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                          12-21-2022, 05:22 AM
                                        • grimacelord
                                          NEC TurboExpress On/Off Power Switch Replacement Help
                                          by grimacelord
                                          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                                          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                                          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                                          11-09-2023, 09:49 AM
