Identifiy Inverter Please
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Got this one, but I am wondering if anybody has seen this type and knows brand, model, quality, wattage, etc. Thanks!
    If it's not a piece of junk I want to put it in my truck.
    • 31150
    Re: Identifiy Inverter Please
    open it, lets see what the board says.
    and dont put the power in like that.
    if those are socket-posts for a 4mm banana plug then get a pair of plugs and solder them to the wires.
    using posts like that at hgh current is asking for trouble.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I'm using a cut apart pci-e signle molex adapter connected to some old seasonic psu. it works ok but input voltage drops to a bit above 11 and the wires are certainly quite toasty
      not a good solution permanently but ok to test. running an hp desktop without a hard drive and a random dell laptop ok... but if i put a hard drive in the hp desktop the laod is too high and it starts to beep. either that or the input voltage drops too low.
      will open it up and check. anything in particular i should be looking for?
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Not world's most inspiring photography, but this looks cheap inside (not that I know what I'm looking at)...
          • 31150
          general inspection really.
          soldering quality, cap quality,
          part numbers on power transistors can be used to calculate maximum theoretical wattage.
          obviously anything printed on the pcb could be searched.
            • 31150
            it looks pretty good for what it is.
            all parts soldered flat down, wires well soldered etc.
            even uses a microcontroller.
            i'v seen much worse.
            does it have an input fuse/breaker?
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              It has three 35A fuses.
                All fuses in parallel? They do that a lot.
                Single input fuse 12V @35A is 420W, but if the fuses are parallel then it sure does not look like 1000W unit, the input wires are small and connected in parallel.
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  So it's either a great 300W unit or a terribly over-rated 1000W unit? lol
                  Should be fine to charge the occasional laptop. What gauge wire do I need to bring 12V from the battery? I want to put an inline fuse near the battery, then bring some decently thick wires through a pre-drilled hole somebody made in the cab from the engine bay, then break it into a sort of 12v "power strip" if you will... two cigarette lighter sockets, a 5v usb, and the inverter.
                    • 31150
                    probably a 600 - 750w
                      10AWG at least to have less loss in the wires.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        Yeah. You can use thinner wire to a certain degree, but you will have more losses.
                        Yeah, I was thinking somewhere in that range. I'd probably say 500W to be safe xD
                        Looks generic to me, no manufacturer labels anywhere that I can see.
                        Cheap looking caps.
                        Also, some of the chips are in sockets, not sure that I like that, but they don't look corroded (from what I can see). So they are probably fine.
                        LOL!!! Look how they removed the dust cap/tab thing from the buzzer/speaker and stuck it on the transformer! Lazy workers! xD
                        Also, I'm not sure why the input power wires go to the side with the small heatsink. I would think that the other side, with a whole bunch of transistors, would be the input side. Plus, I would also think that the input side transistors would have more losses, so they should be on the case, where they can have more heat dissipated.
                        Muh-soggy-knee
                        • x_orange90_x
                          by x_orange90_x
                          01-29-2025, 09:24 PM
                        • lostone
                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                          by lostone
                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                          05-19-2024, 11:40 AM
                        • Gentian
                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                          by Gentian
                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                          03-06-2023, 07:07 AM
                        • valvashon
                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                          by valvashon
                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                          01-04-2024, 01:44 PM
                        • eccerr0r
                          A modified sine wave inverter + a grid tie inverter?
                          by eccerr0r
                          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                          Next thing is trying to charge the batteries using solar power, but that's another issue ...
                          08-31-2023, 09:14 PM
