lightning rods
  • Poor Flick
    Of sound mind
    • Jun 2014
    • 3167
    • U.S.S.A. The flophouse of the world.
    lightning rods
    AFAIK this would be where to ask this.
    Anyone know the real facts about lightning rods on buildings? We had a direct or very nearby hit last spring. It damaged two TVs and a surround sound system. With all of the reading I've done it seems the theory is to give lightning a very low resistance path to ground around structures to prevent lightning from using wiring outside and inside the building to find ground. There are differing viewpoints all over the internet and here to the point its now confusing. Also I've been working on my house for some time making it into a sort of country type farmhouse style and some decorative lightning rods would look good and hopefully serve a purpose.
    One thing I can't understand is if lightning is on its way down from thousands of feet up, how are some conductors at the last 20 feet of travel going to alter its course?
    From my favoritest movie ever!:
    Cledus Snow: Can I ask you a question?
    Bo Darville: Sure, ask me what?
    Cleedus: What the Hell do we want to go to Texas for and haul beer back here? What is that?
    Bo: For the good old American life. For the money, the glory, and the fun. Mostly for the money.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: lightning rods
    IIRC, what a lightning rod does is remove change from the air. i can connect a little neon light to my 100ft antenna and it will light on a cloud to cloud strike or cloud to ground.
    Follow the white rabbit.
    • Poor Flick
      Of sound mind
      • Jun 2014
      • 3167
      Re: lightning rods
      goontron,
      I have read similar where the idea is to equalize the charge difference between the ground and the air through the rods. The writer also stated these equipped buildings rarely are struck. Before reading that I first thought they were designed to attract and safely route it to ground. That would be a noisy and dangerous scenario! I didn't know what to believe.
      So you agree that the air terminals are constantly working to equalize the charge difference to reduce the chances of a strike?
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Re: lightning rods
        Originally posted by Poor Flick
        goontron,
        thats what im lead to believe. though if a strike is to occur it would rout lightning to ground aswell.
        • Poor Flick
          Of sound mind
          • Jun 2014
          • 3167
          Re: lightning rods
          Thanks, goontron!
          If anyone else has input I'm listening!
          • redwire
            • Dec 2010
            • 3902
            Re: lightning rods
            I took a course on lightning protection and was surprised to learn it does not always take the shortest path.
            It zig-zags and can go around a lightning rod and then nail the brick on a building! There are dozens of different arrestor designs out there but it is not easy to test them.
            There is also the National Lightning Detection Network, NLDN which records the location and strength of all major strikes in the USA. It is useful if major damage happens and you want to know how strong the strike was. But I think it is a pay-per-use database.
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              Re: lightning rods
              One thing to take into account is 30000Amps if you catch one.
              Need good grounding and large conductor with no sharp bends.
              My pc
              CPU : AMD PHENOM II x4 @ 3.5Ghz
              MB : ASUS M4A89TD PRO USB3
              RAM : Kingston ValueRAM 16gb DDR3
              PSU : Cooler Master 850W Silent Pro
              GPU : ATI Radeon HD 6850
              • Longbow
                • Jun 2011
                • 623
                Re: lightning rods
                Fortunately there are volumes of information on lightning research and recommendations free for the asking. Tons of articles relating to lightning here at NLSI: http://www.lightningsafety.com/index.html
                Some discussion of grounding here:
                http://www.solacity.com/grounding.htm
                Of greatest importance with lightning protection is grounding. The rod has to look like a more attractive path than anything in the surrounding area, and making it so is more difficult than it appears. I would especially recommend reading material on the Ufer grounding system.
                Home electronics will easily smoke even without a direct lightning strike. Usually a pulse enters a residence on cable shields and tries to flow to the service ground whilst traveling across the p.c. board. This is because cable service entrances are rarely bonded to the electrical service ground. Or, the grounds are at multiple sites making them useless for lightning or for electrical shock protection. My opinion is that protectors with gas discharge tubes are the best insurance for protecting home electronics, but nothing is 100%.
                Is it plugged in?
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  Re: lightning rods
                  my 100ft antenna has neon bulbs for the low power corona (streamers), and gas discharge tubes for the higher power nearby strikes.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Re: lightning rods
                    One question might be was the damage caused by the lightning or by a surge in the mains voltage?
                    If the latter then protecting your building from a lightning strike using rods is
                    unlikely to make any difference?
                    If lightning is forecast in your area unplugging the sets (mains and antenna/cable) would seem the safest action ?.
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      Re: lightning rods
                      one bit of advice i always live by: "Ground your antenna when not in use!"
                      even indirect strikes can cause enough voltage to kill things.
                      i have a switchboard that uses RCA jacks, one to my Yamaha, one to my TV, one to my Panasonic RF-3100, one to ground. i had it grounded when lightning struck the light pole down the street and the strike dispersed enough current to weld the RCA plug to the socket and make the wire smoke.
                        master hoarder
                        • May 2008
                        • 12170
                        Re: lightning rods
                        It is usually the former that causes the damage. Whenever a lighning strikes, 1000's of Amps can get discharged in a vey short amount of time (i.e. large di/dt). This can induce substancial currents and corresponding voltages in any nearby conductors. So any non-ferrous, non-shielded wires (i.e. from the mouse, keyboard, ethernet, speakers, etc.) will act like little antennas and pick up current (think of this as a large, open-air, "core-less" transformer). If the lightning struck fairly close, those induced voltages and currents can be large enough to do damage.
                        Also, for this reason, lightning rods and their grounding wires should be routed as far away as possible from any house wiring. And most definitely avoid running the grounding wire for the lightning rod parallel to any other wires.
                        • Poor Flick
                          Of sound mind
                          • Jun 2014
                          • 3167
                          Re: lightning rods
                          Wow, everyone! Thank You! I've been reading up on the links and putting that together with your advice. I'm coming to the conclusion this is going to be one of those projects where lack of knowledge could be a very dangerous thing. I'm going to study on this further before I just go and put up some air terminals, cables and ground rods. For now I think I'll look into some whole house surge protection to go with my plug in protection at my tv etc. I'm thinking now the damage came through the cable line as the main and logic boards on the tv were damaged and my surge protector, Acoustic Research 3420 joule, 65 db seems fine. Although, the small kitchen flip down tv, also on cable, had a damaged switching power adapter. I also seen after the incident where one of the two house ground leads that the tv cable ground was attached to was broken loose from its ground rod, even though they both are connected to the same bar in my electrical panel. It also seems to me a high quality lightning rod system won't be cheap at all, so if I'm to do it right I'll need to save up a bit. After more studying, I'll revive this thread with more questions for you all.
                          Thanks again!
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            Re: lightning rods
                            Thanks again!
                            yes, put up ground rods so my poor little longwire antenna won't get blasted!
                              master hoarder
                              • May 2008
                              • 12170
                              Re: lightning rods
                              Indeed, that is what our professor told us as well (in one of my classes, we had a brief chapter on noise generation, prevention, ESD, and other similar circuit design concerns). He said, this stuff is best left to professionals with experience, and he is the type of teacher that always encourages DIY and related discussions.
                              • Poor Flick
                                Of sound mind
                                • Jun 2014
                                • 3167
                                Re: lightning rods
                                Hmm, I'll need to save up even more then.
                                In regards to the word professional!
                                • tester272001
                                  • 91
                                  Re: lightning rods
                                  One thing to consider regarding your electronic equipment that got HIT. Do you know the hit came from antenna ? I have seen lightning enter in the AC Mains more often and the GROUND at the service entrance panel is more important for that situation. If your hits were not via the AIR (antenna) and cam in on the AC lines then a whole home surge suppressor (from a home center) is a great thing to have. Will help protect against the Utility company surges as well as lightning flash over hits. Good luck.
                                  • redwire
                                    • Dec 2010
                                    • 3902
                                    Re: lightning rods
                                    Dr. Nikola Tesla's lightning arrestor patent is interesting, because he was against Benjamin Franklin's approach- to attract the lightning via a pointed rod.
                                    Tesla said it's better to repel the strike, push it away from a building. That man was the King of Lightning IMHO.
                                    If your soil is low (geological) conductivity, i.e. igneous rock, then popular grounding solutions are pretty much useless.
                                    If this is your case, I've seen conductive concrete used to make a huge star-ground. Substations also suffer and use resistors to reference the (floating) Wye ground. It's another reason to get a professional to survey the site.
                                    • barry101
                                      Apple 820-3662 VCore shorted to ground.
                                      by barry101
                                      Hi, Would appreciate some help.
                                      I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                      Get charger light but no fan spin or chime. No liquid damage.
                                      Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                      Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                      With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                      Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                      06-24-2025, 07:34 AM
                                    • Chaks
                                      Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
                                      by Chaks
                                      TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
                                      The specs says ...
                                      High antenna efficiency 868MHz ISM Band
                                      5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
                                      The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
                                      1. Should I Fix it with a glue.
                                      2. Should I fix it with a double side adhesive tape
                                      3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
                                      12-09-2024, 11:06 AM
                                    • Rolin
                                      Dell Laptop - over 14V between Chassis Ground and Circuit Ground?
                                      by Rolin
                                      Someone brought me a Dell laptop that had a loose power jack inside (power jack on a cable, not soldered to motherboard). Once disassembled found one of the wires was broken off the power jack. I replaced the jack and it won't turn on, but the metal shell of the jack inadvertently touched the metal hinge and suddenly it got power. I checked voltage from the metal chassis ground and the circuit ground and I get over 14V ? Has anyone seen this before? Typically is it some kind of filter cap that shorted? Very strange...
                                      10-30-2022, 10:18 PM
                                    • Bardou Kari
                                      HP EliteBook 840 G6 – no power after lightning strike
                                      by Bardou Kari
                                      I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                      – Charger is OK and 19V is present at the motherboard.
                                      – No charging LED, no fan, no reaction.
                                      – I don’t see any 3.3V or 5V near the coils.
                                      – Battery is unplugged.
                                      – I’m new to board repair but can use a multimeter.
                                      I added a clear photo of the board.
                                      Any idea where to start or what to check next?
                                      Thanks a lot for your help!...
                                      07-01-2025, 10:45 AM
                                    • loopster
                                      645 G9 with Ryzen 5 PRO 5675U | Resistance to ground of CPU?
                                      by loopster
                                      Hello everyone, I have a 645 G9 here with a Ryzen 5 PRO 5675U.
                                      This board has a blown inductor component above the driver chip to the CPU coil, and I am wondering whether the CPU is shorted/dead.
                                      Could anyone please measure the resistance to ground on the leftmost coil/inductor to the CPU?
                                      My resistance value is 2.2 Ohms, which doesn't look good to me.
                                      Thanks to everyone willing to give a value.​
                                      06-05-2025, 02:33 PM
