SMD Resistor
  • jimmyplumb
    • Mar 2013
    • 23
    • England
    SMD Resistor
    I would be grateful for a little help identifying & obtaining a smd resistor it has (271) on the top which I think is a 2.7K ohms I don't know what make it is or where to purchase one in the Uk.
    The resistor is from a 240v Danfoss C/Heating programmer any help would be welcome
    Any Help would be most welcome
    Jim
    Re: SMD Resistor
    That will be 270 Ohms:
    http://www.marsport.org.uk/smd/res.htm
    Good clear pictures of the board, both sides, and the problem with the board.
    • selldoor
      Slow Learner
      • 7870
      Re: SMD Resistor
      It is 270 ohms see here http://www.marsport.org.uk/smd/res.htm
      I will see if I can find someone who sells them
      cpc sells them - what size is it
      http://cpc.farnell.com/jsp/search/br...questid=204439
      Best bet is here
      http://www.ebay.co.uk/itm/SMD-SMT-Re...45229871&rt=nc
      BUT answer Budm first he is wondering why the resistor has gone
      • jimmyplumb
        • Mar 2013
        • 23
        • England
        Re: SMD Resistor
        The programmer is approximately 6 years old then stopped working on inspection I found 1 100uf x 50v capacitor down & a 470uf x 310v capacitor down on changing these the unit was still not turning on after checking all resistor's I found one that was showing OL
        this is the one I intend to change.
        Jim
        • selldoor
          Slow Learner
          • 7870
          Re: SMD Resistor
          A picture might have helped - replacing a resistor is a bit like changing a fuse - it may just fail again or may take something out with it. I was going to cpc today but by the time I have bought a pack and posted it you can buy them off ebay as cheap. (you will have 99 spares . Do you have any old boards you can salvage one off - even a standard wired one for testing. No need to remove the old one if it is open just solder the new on on top.
          • jimmyplumb
            • Mar 2013
            • 23
            • England
            Re: SMD Resistor
            Many thanks for your assistance selldoor I have now bought 100 on ebay using the link you gave me as soon as they come I will install one & let you know of the outcome
            Jim
            • gica69
              Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
              by gica69
              I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
              Resistor shows orange range silver gold and green lines.
              Thanks in adv...
              07-21-2025, 09:49 PM
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • mikey5791
              Need help to replace burned resistor in 350w atx psu
              by mikey5791
              Hi to all forum members,
              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
              12-26-2024, 04:55 AM
            • artvandalai
              What resistor ohm will work better to repair this waterpik?
              by artvandalai
              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
              01-05-2025, 04:10 PM
            • chth96
              Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
              by chth96
              I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
              Since then, This AC/DC adaptor have been out of order.
              But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
              After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
              And Is there any possibility that it will suddenly explode as well as to be out...
              12-03-2023, 04:40 AM
