SMD Resistor
    SMD Resistor
    I would be grateful for a little help identifying & obtaining a smd resistor it has (271) on the top which I think is a 2.7K ohms I don't know what make it is or where to purchase one in the Uk.
    The resistor is from a 240v Danfoss C/Heating programmer any help would be welcome
    Any Help would be most welcome
    Jim
    Re: SMD Resistor
    That will be 270 Ohms:
    http://www.marsport.org.uk/smd/res.htm
    Good clear pictures of the board, both sides, and the problem with the board.
      Re: SMD Resistor
      It is 270 ohms see here http://www.marsport.org.uk/smd/res.htm
      I will see if I can find someone who sells them
      cpc sells them - what size is it
      http://cpc.farnell.com/jsp/search/br...questid=204439
      Best bet is here
      http://www.ebay.co.uk/itm/SMD-SMT-Re...45229871&rt=nc
      BUT answer Budm first he is wondering why the resistor has gone
        Re: SMD Resistor
        The programmer is approximately 6 years old then stopped working on inspection I found 1 100uf x 50v capacitor down & a 470uf x 310v capacitor down on changing these the unit was still not turning on after checking all resistor's I found one that was showing OL
        this is the one I intend to change.
        Jim
          Re: SMD Resistor
          A picture might have helped - replacing a resistor is a bit like changing a fuse - it may just fail again or may take something out with it. I was going to cpc today but by the time I have bought a pack and posted it you can buy them off ebay as cheap. (you will have 99 spares . Do you have any old boards you can salvage one off - even a standard wired one for testing. No need to remove the old one if it is open just solder the new on on top.
            Re: SMD Resistor
            Many thanks for your assistance selldoor I have now bought 100 on ebay using the link you gave me as soon as they come I will install one & let you know of the outcome
            Jim
