Transistor identification
  • Behemot
    • 4845
    • CZ
    I got troubles identificating a TO251 transistor. There is 2663, than K and 83. I found 2SK2663 but that is SMD not through-hole. High voltage may be, I don't know how this works but it is basically embedded tiny PSU for charging NiMH battery. There is input, rectified and filtered, than small transformer and after the transformer is this transistor.
    It is from Philips HQ 2830 shaver, there also was burned one SMD transistor (which I think I have identified and replaced) but this seems also bad with 004 voltage drop between electrode 1 and 3. And also two SMD resistor which I have some trouble identifying, one is posibly 680 ohm, the other one who knows…
    • 31140
    Re: Transistor identification
    2sk series would be a fet.
    got any foto's off the board?
    • selldoor
      Slow Learner
      • 7870
      Does it look like these?
      http://www.ibuyla.com/Product/134064...ity_assurance/
      They seem to think they are 2SK2663
      • Behemot
        • 4845
        • CZ
        Yep, exactly. So 1A/900 V N-FET, good, I'll look after replacement and take the foto, maybe we'll get aproximate value of the resistors…
        • Behemot
          • 4845
          • CZ
          Here it is. I have already replaced the SMD transistor which was burned, I identified it as some SMD NPN, replaced with BCW66H.
          Now also this N-FET in question is bad and also two resistors. Resistor 1 seems like 6x0 so I will guess 680 ohm. The blue one is 4-digit but I have no idea what. It goes from GND/- of the battery to base of the NPN transistor.
            • 31140
            is the black diode o.k. ?
            • Behemot
              • 4845
              • CZ
              Measures normal diode drop so I would say so…
              • selldoor
                Slow Learner
                • 7870
                Sorry no idea - assume you have tried to clean it up.
                • Behemot
                  • 4845
                  • CZ
                  The resistors?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    please ignore
                    • selldoor
                      Slow Learner
                      • 7870
                      Hi - yes the blue resistor - I guess someone somewhere will have seen this circuit but what chance on here? how about another thread with the
                      Philips HQ 2830 shaver in the title- might jog someones interest. May even have one in a drawer
                      they could look at for you.
                      • Behemot
                        • 4845
                        • CZ
                        May be good to just rename this one?
                          It looks like non-isolated 2-transistor switching power supply.
                          When that power MOSFET is shorted out, it will take many parts with it.
                          • Behemot
                            • 4845
                            • CZ
                            I thought something like that, now I see it more clearly, ty
                            Would 3A/800V N-FET be OK? And do you have any idea what the blue resistor may be?
                            Input rectifiers seemed good, I'll check the resistor in there…
                              The ratings looks OK.
                              I cannot clearly read the numbers on the resistors, are they 4 digits?
                              http://www.hobby-hour.com/electronics/smdcalc.php
                              • Behemot
                                • 4845
                                • CZ
                                The black one which seems like something similar to 680 is 3 digit, so I see it is 68 ohm, not 680. The blue ones are 4 digits, yes. Unfortunately it is burned just through the print so I have no idea, I think we will have to guess it's value.
                                And the fusible input resistor is also bad, I'll replace it as well. Rectifying diodes all survived it.
