Toshiba Blu-Ray Player - No Power
  • caphair
    • Nov 2011
    • 1249
    All the voltages are present even standby but there is no standby light and unit doesn't respond to any keys.
    Ps_on has 1.4v and does not change when power button pressed. I've tried grounding that pin and still nothing happens.
    Mainboard issue?
  • ohmmy
    • 182
    Re: Toshiba Blu-Ray Player - No Power
    Does sound like a main board issue. Maybe someone else can be of more help
      So what voltages do have on the connector of the power supply (5V, 12V, 5VSTBY) as shown by the labeling on the board? Since the PS_ON signal does not toggle which will point to problem on the main board.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        he pulled the PSon on to ground, if the PSU was good wouldn't it have powered on?
        Follow the white rabbit.
          Since ps_on is sent from the main board to turn on the switched 5V and the switched 12V, if PS_ON is stuck high then he should see the switched 5V and switched 12V, he indicated all the voltages are present but did not say if they are correct voltage, and if he ground the PS_ON then the switched 5V and the switched 12V should go away. Most power supply uses active high, but he can find out by seeing if the switched 5V and switched 12V change state.
          • caphair
            • Nov 2011
            • 1249
            12.45v
            5.20v (vcc)
            5.20v (vcc)
            5.14v (standby)
            1.4v (ps_on)
            3.30v (open/close) - eject this goes down to 1.20v when pressed but disc tray does not react.
            Would the main board issue be the microprocessor? It feels pretty hot to the touch for such a small board and chip.
            • caphair
              • Nov 2011
              • 1249
              When I grounded ps_on I did not remeasure voltages but with the mainboard disconnected I don't get all the voltages at the output pins
                so it looks like the PS_ON is stuck high (that is why all the outputs are present), it should toggle HI/LO when power switch is toggle.
                "Would the main board issue be the microprocessor? It feels pretty hot to the touch for such a small board and chip."That is the possibility right now you are having main board problem. The IC should not be too hot to touch.
                "When I grounded ps_on I did not remeasure voltages but with the mainboard disconnected I don't get all the voltages at the output pins" That is normal since the power supply is no longer receiving the PS_ON to turn on the switched 5V, 12V; only 5VSTBY will be present.
                • caphair
                  • Nov 2011
                  • 1249
                  So it essentially can't be repaired without replacing the entire board?
                  If the ps_on is stuck high, shouldn't the unit just constantly be on and working? Lol
                  I tried spraying the chip with freeze spray to see if any changes occur and it didn't.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Not if it's more than just the pson signal. Sounds like there is no processing of any kind going on.
                      • 31267
                      find the reset circuit on the mainboard.
                      dont ask, find a schematic or learn what it is.
                      start at the cpu's reset pin
                      *and make sure the oscillator/crystal is running.
                      • caphair
                        • Nov 2011
                        • 1249
                        Is this different than unplugging the unit and holding down the power button for 30 seconds?
                        I can't find a schematic anywherefor this. Only a user's manual. Is there something I can try without one?
                          • 31267
                          get a datasheet for the cpu.
                          • caphair
                            • Nov 2011
                            • 1249
                            I couldn't find one for it. I searched "Mediatek MT8551"
                              This Philips uses the same MT8551, see SCH for pinout.
                              • caphair
                                • Nov 2011
                                • 1249
                                Thanks a lot! Looks very similar. So I found the reset pin, how do I actually do that? Ground it?
                                  • 31267
                                  meter or scope it to see what it does when you connect the power.
                                  what it *should* do is go to ground for a fraction of a second, then go to the main voltage - that i assume is 3.3v
                                  if it stays grounded then you need to find out why,
                                  if not, you can connect it to ground for a second to see if he cpu starts.
                                  and check the clock crystal / oscillator.
                                  • caphair
                                    • Nov 2011
                                    • 1249
                                    Ok so I thought I found the reset pin but in fact there are two spots on underside of the main board labeled test1 and test2 which I misread as "reset1 reset2"
                                    That schematic doesn't give a detailed look at what pin exactly is reset on the cpu
                                      • 31267
                                      well i took a quick look, it does have the reset circuit together with a 5v to 3.3v regulator that's related.
                                      i dont know how similar yours is though.
                                      did you check any crystals or oscillators?
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        I found a similar circuit like that 5v to 3.3v its labeled 3.3v and has a white border to distinguish the components within it.
                                        I did try grounding one end of a resistor that had 3.3v on it in that circuit similar to the schematic but nothing happened. No change.
                                        I don't have an oscilloscope to test the crystal unfortunately
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                        • SkishyIshy
                                          Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                                          by SkishyIshy
                                          Hey All,
                                          I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                                          I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                                          I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                                          03-17-2021, 11:44 AM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • OMWANA1966
                                          Toshiba Satellite C850-B888 Standby Power Blinking
                                          by OMWANA1966
                                          I have the above toshiba which worked on by another technician with blinking light on the caps lock dvd rom drive and the standby power upon insertion of the charger.
                                          what i have done
                                          cleaned the mb
                                          used hot air
                                          disassembled the board but the problem is same
                                          anybody with similar problem which has been solved can assist
                                          thanks
                                          04-13-2023, 12:04 AM
