Diode identification for data rescue
  • MrBojangles
    • Jul 2024
    • 49
    • Sweden
    Heyo
    I'm trying to perform data rescue on this drive and don't want to make a mistake. I've found a burned diode and a shorted capacitor right next to it. I've found a component on eBay that seems to match up. Can someone confirm please? Also I don't mind replacing it with a compatible component if it's easy to get hold of.
    https://www.ebay.de/itm/235070605065
    Have a nice day
  • m1ch43lzm
    • Mar 2019
    • 903
    • Peru
    It's a TVS diode rated 13V, across the +12V power supply rail
    Can be temporarily removed for data recovery as long as your PSU is working properly on the 12V rail, for long term use I would replace it with a similar diode from another dead HDD
    Common failure when a bad PSU delivers over voltage on that rail
    Also measure across both 0 ohm resistors
    • truclacicr
      • Apr 2019
      • 352
      • australia
      You can use an SMBJ12A or SMCJ12A, depending on the dimensions. The capacitor should be OK -- the shorted diode is making it look bad.
      • CapLeaker
        Leaking Member
        • 8340
        It’s just a TVS over volt protection diode. It’s not really needed if you have a good PSU, just for data recovery.
        • MrBojangles
          • Jul 2024
          • 49
          • Sweden
          Thank you all for the advice. You guys are very knowledgeable. I will remove the component and attempt data rescue again.
          Wish me luck!
          • adamok7
            • Feb 2023
            • 20
            • Kazakhstan
            It is a TB13A_V714, TBxxx_Vxxx - TFMBJ13A or SMBJ13A (TRANSIENT VOLTAGE SUPPRESSOR)
            • MrBojangles
              • Jul 2024
              • 49
              • Sweden
              Removing the diode kicked the disk alive and the data is safe now. Brilliant. Thank you all so much for the tips
