Internal trickle charger for a Scooter
    Re: Internal trickle charger for a Scooter
    @steve, I do not think so.
    http://batteryuniversity.com/learn/a...d_acid_battery
    http://www.autos.com/car-maintenance...-float-charger
    http://www.bdchargers.com/trickle.php
    Once fully charged through saturation, the battery should not dwell at the topping voltage for more than 48 hours and must be reduced to the float voltage level. This is especially critical for sealed systems because these systems are less able to tolerate overcharge than the flooded type. Charging beyond what the battery can take turns the redundant energy into heat and the battery begins to gas. The recommended float voltage of most low-pressure lead acid batteries is 2.25 to 2.27V/cell. (Large stationary batteries float at 2.25V at 25°C (77°F.) Manufacturers recommend lowering the float charge at ambient temperatures above 29°C (85°F).
    Not all chargers feature float charge. If your charger stays on topping charge and does not drop below 2.30V/cell, remove the charge after 48 hours of charge
      • 31138
      Originally posted by SteveNielsen
      So, is 2amp considered a trickle charge or not?
      stupid question without knowing the capacity of your battery!!
      • delaware74b
        • Apr 2009
        • 628
        I have the Schumacher 1.5 amp trickle charger for my '74 MG-B. It has a 6" grounded power cord and 15" battery leads. $22 on Amazon, free ship with prime.
        Link: http://www.batterychargers.com/Produ...Name=94026501A
        Stupidity should be a crime, especially for drivers. I have NO patience for them.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          When I said trickle charger, I intended to imply a float charger or a battery maintainer. Let me guess, the terms aren't interchangeable?
          sigpic
          (Insert witty quote here)
          • SteveNielsen
            Retired Tech
            • 2327
            Hey now, be nice there buddy. I didn't call your answer stupid. It didn't really answer my question very well or I would not have re-asked it. I understand what you answered but it was a yes/no question, not a request for a math assignment.
            • SteveNielsen
              Retired Tech
              • 2327
              Thanks Bud. I don't think this $50 battery charger does the float charging. I think the charge capacity meter in it just shows the charge current, which changes as the battery charges. and I haven't taken voltage measurements while it is charging. It is only switchable from 6 or 12 volt and 2 or 6 amps.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                OK, here's what I'm thinking:
                Install a relay between the 7A Fused 12V supply wire for everything but the starter (which obviously uses an unfused heavy gauge to the battery/starter relay) and headlights (which are powered off the charging sytem directly), connecting the 7A Fuse end to the NC terminal and the common to the battery. Next, I'd ground one end of the relay coil and the other end would connect to NO (though a resistor if required) and go to the positive charger connection (the negative going to ground). Doing this would isolate the connector when the charger isn't connected and when it is, isolates the charger from the rest of the scooter and prevent an accidental overload of said charger.
                My only question is whether or not the relay would cause charger issues by being an extra (albeit small) load...
                sigpic
                  • 31138
                  dont bother.
                  the charger is current-limited and cant be damaged by turning on the lights etc.
                  anyway, most relays arent rated to be held constantly on like that, the coil heats up slowly.
                  there are relays that are designed for it, but they cost a bit more.
                    • 31138
                    hey, RD:
                    http://www.cliffuk.co.uk/products/cliffcon/ip68.htm
                    http://electronics.mcmelectronics.co...fcon68&x=0&y=0
                    any help?
                      • 31138
                      forget that, they only sell the cable-end!
                      • motormayhem
                        Lenovo T460 Only Charges on One Charger
                        by motormayhem
                        Laptop Question
                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                        05-12-2023, 01:46 PM
                      • Golden2000
                        42v xiaomi scooter charger
                        by Golden2000
                        I have 42v charger , it outputs about 14v not 42v what i can check to start repairing it ?
                        09-30-2024, 05:42 AM
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
                      • Johndill
                        Dell Inspiron 7567 LA-D993P odd charger issue
                        by Johndill
                        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                        Here are the tested scenarios:
                        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                        2. With the laptop off, plug in charger (LED says on) & the front charging...
                        11-16-2022, 10:55 PM
                      • exerion5000
                        DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                        by exerion5000
                        Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                        below normal, as if it were operating in an extreme energy...
                        10-15-2023, 02:12 PM
