Internal trickle charger for a Scooter
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I'm currently fixing up a scooter and one thing I'd like to add to it is some sort of built-in trickle charger.
    Presently, the only way to trickle charge the battery is by removing the floor mat and a bunch of screws on the battery cover... But what I'd like to do is make some way to make this less tedious, as keeping the battery on a trickle charger is reccommended for scooters.
    I had a couple of ideas:
    1. add some sort (weatherproofed) connector that an off-the-shelf trickle charger could connect to, with a matching connector added.
    2. (even better IMHO) add a weatherproofed male NEMA connector for an extension cord (or other 120V weatherproofed conenctor for a long modular cord) and a status LED or 2 and internally mount an off the shelf or homebrew trickle charger.
    Has anybody actually done this mod? Do higher end scooters have these built in?
    What do you all suggest as an approach?
    Larry
    sigpic
    (Insert witty quote here)
  • popeye
    • May 2011
    • 155
    Re: Internal trickle charger for a Scooter
    Hi
    What type of scooter are we talking about? If it is a mobility scooter like mine the charger enters trickle charge when batteries are full.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Originally posted by popeye
      Hi
      If you saw the link, it's a 50CC Scooter for road use. Well, 72CC now (installed a big bore kit since the existing upper motor was trashed).
      sigpic
        • 31283
        well if nothing is across the battery constantly - like a clock or alarm for example.
        then either is an option - only space is the limiting factor.
        an internal charger could be a safety issue, unless it's in a waterproof case inside the bike though - driving rain, morning condensation etc can get into a lot of places.
        if you need waterproof locking connectors, there are loads of those too - again, it's down to available space.
        dont forget to use the right colour cable (yellow) and "arctic" rated if it's outdoors.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Sounds like external is the way to go. Weatherproof connector suggestions?
          sigpic
          • ron350
            • Feb 2014
            • 296
            I would suggest a battery maintainer like the Battery Tender or Battery Minder that matches your specific battery. I think walmart sells the Battery Tender brand.
            http://batterytender.com/products.html
            http://www.batteryminders.com/catego...otorcycle.html
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              I already have a harbor frieght charger. This is more about making it less tedious once the scooter is rebuilt, not finding a charger per se.
              sigpic
                • 31283
                re waterproof connectors.
                any idea on maximum current?
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  I did see this:
                  The one bummer is that the plug is only rated for 5A while it would be cool if the internal NC switch could do the 7A (based on a fuse spec) the non-starter circuitry handles. the reason being that I could route the power wire past the fuse to the switch, and make it so one couldn't overload the the charger by powering up the scooter... if that's even a good idea.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    The issue I saw with those is that they are waterproof at the wrong time... I want it waterproof(resistant) with nothing connected (when I'm on the road riding through a storm)...when the maintainer is hooked up, I could care less (as it's in the garage or otherwise protected).
                    sigpic
                      • 31283
                      a lot of those have a sprung cap with a gasket in them.
                      but they are for mains - i assume we are now looking at 12v?
                        • 31283
                        these look both pretty good, and cheap.
                        http://www.rapidonline.com/cables-co...nectors-538679
                        and you may find this handy.
                        btw, if you get the 3pin, you can use the 3rd pin for other stuff, like feedback so the charger knows it's connected.
                        or a loopback to trip an alarm if it's unplugged.
                        loads of uses.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Yes, more like 13V more or less but yeah, not mains.
                          I only need 2 pins btw, but I may get as many as 5+ if the cost is the same... if I wanted to use it as a multiuse connector or something... not so much an alarm as the scooter has locking steering... I was thinking more along the lines of a tach or relay for the 7a line... but whatever, I'll look into the ip68 rated connectors listed.
                          sigpic
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            I'm curious, what is considered a trickle charge for a lead-acid battery? For example I have a battery charger that is switchable from 2A to 6A, is the 2A setting a trickle charge?
                              • 31283
                              i would say a 50th of the battery capacity at most.
                              so it would take 2 days to charge a flat battery.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                loads of uses.
                                Not avail. in the USA apparently... and UK shipping is $$$... damn it.
                                Now to find a USA sourceable equivlent...
                                sigpic
                                  • 31283
                                  Cliff is a top brand,
                                  i'm sure you can find a source in the u.s.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    from what I saw the only US seller was Newark, which listed it as UK stock only (at $20 per ounce to ship to the US). I did look.
                                    sigpic
                                      • 31283
                                      well maybe bulgin bucaneer series has something.
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        So, is 2amp considered a trickle charge or not?
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • Golden2000
                                          42v xiaomi scooter charger
                                          by Golden2000
                                          I have 42v charger , it outputs about 14v not 42v what i can check to start repairing it ?
                                          09-30-2024, 05:42 AM
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                        • Johndill
                                          Dell Inspiron 7567 LA-D993P odd charger issue
                                          by Johndill
                                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                          Here are the tested scenarios:
                                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                                          11-16-2022, 10:55 PM
                                        • exerion5000
                                          DELL Alienware 17 R3 (LA-C912P) only work with 120w charger in mode low CPU clock
                                          by exerion5000
                                          Hello, I received this laptop with the following condition: When I turn it on, it shows the ALIENWARE light and the Alien button lights up, then it does not show an image and it restarts constantly, as the customer had already informed me that the battery was dead, I connected an original charger that I had it for testing, the machine turned on normally and I was able to enter Windows without problems, after a while of testing I noticed that it is very slow (like a Cyrix 425...), and after performing a CPU test the frequency is
                                          below normal, as if it were operating in an extreme energy...
                                          10-15-2023, 02:12 PM
