5 band resistor
  • newtothis
    • Mar 2013
    • 1556
    • england
    5 band resistor
    Hi all, Been a while since i have been in...
    Ok I am used to 4 band resistors but have a 5 band here that doesnt make sense to me... Bands go :
    black - purple - silver - gold - green
    This is a power resistor pulled from a ATX switching PSU.
    Anyone shed some light onto what this is?
  • selldoor
    Slow Learner
    • 7870
    Re: 5 band resistor
    Almost a rainbow - what does it test at.
    Picture might help - as close up as you can get
    • newtothis
      • Mar 2013
      • 1556
      • england
      Re: 5 band resistor
      It tests as closed as its blown.
      Will upload pic shortly
      • newtothis
        • Mar 2013
        • 1556
        • england
        Re: 5 band resistor
        I would upload a pic but for the life of me can't figure where i put it?! :S Assuming the Mrs has been messing again! lol
        • pc7fan
          • Aug 2013
          • 52
          Re: 5 band resistor
          This is a very weird one! :p Never seen that before... Please correct me if I'm wrong.
          The black means 0 (not sure about that)
          The purple means 7
          The gold is a divider (10x maybe)
          The silver is another divider (100x??)
          The green band is the tolerance of ±0.5%
          So that means it's a 0.007 ohm ±0.5% resistor???? As well put a wire in it's place... I am not sure of that....
          • newtothis
            • Mar 2013
            • 1556
            • england
            Re: 5 band resistor
            mixed up the gold and silver there :p
            I am assuming the silver is actually grey though is shiny :S
            so would be
            0
            7
            8
            x10
            0.5
            • pc7fan
              • Aug 2013
              • 52
              Re: 5 band resistor
              It should be gray... impossible to have 2 shiny bands on a 5 band resistor.
              That would be a 0.78 ohm ±0.5 % resistor. That makes more sense now!
              • pc7fan
                • Aug 2013
                • 52
                Re: 5 band resistor
                And the gold band is a divider not a multiplier. If it were a multiplier it would be a colored one not a metallic colored one. Just to clarify things.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8662
                  Re: 5 band resistor
                  The other issue: I thought, except for 0 ohm resistors, the first band is never black?
                  In the 0 ohm resistor the black band is the only band... You make 0.xxx resistors by going down another decade with the multiplier. (black=x1, gold=x.1, silver=x.01)
                  The usual "common" resistors with the same metallic and purple patterns could be red-purple-silver-gold-green (0.27R 5%) or yellow-purple-silver-gold-green (0.47R 5%) but the green doesn't make too much sense either.
                  Usually 5-band resistors are precision resistors and have three color bands (first is still never black), multiplier, and tolerance band in that order.
                  • trebo
                    • 514
                    • Wales, UK
                    Re: 5 band resistor
                    can you post a picture of it?
                    my thoughts on it for what there worth
                    that first black band makes no sense, are you sure its black?
                    also I think it may be a 4 band resistor, you ignore the last, which in your case is green
                    • selldoor
                      Slow Learner
                      • 7870
                      Re: 5 band resistor
                      I asked for that early doors - its always a problem - silver could be grey or even white- gold could be orange or yellow- as another poster said black "0" for ring one doesnt make much sense. Resistors for " military" use seem to have random rings.
                      Time they got together and came up with a better system.
                        master hoarder
                        • May 2008
                        • 12160
                        • Bulgaria
                        Re: 5 band resistor
                        Perhaps the black is brown? I've been fooled more than once by some resistors color bands. Good light is a must.
                          Re: 5 band resistor
                          Good pictures and where it is used will be a clue, until we see the picture. I have seen burnt resistor that was over heat, the red band turns black.
                          • JenneDezaeger
                            5-band resistor starting with black?
                            by JenneDezaeger
                            Can anyone tell me how it's possible for a 5-band resistor to start with black?
                            If it really was a zero-ohm resistor it probably wouldn't have burned.
                            So if there are any ideas on the value of this resistor and how to read it, please let me know.
                            Greetings,
                            Jenne...
                            12-06-2022, 06:16 AM
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                          • mikey5791
                            Need help to replace burned resistor in 350w atx psu
                            by mikey5791
                            Hi to all forum members,
                            Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                            The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                            Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                            Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                            12-26-2024, 04:55 AM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                            Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                            This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                            09-07-2024, 12:40 AM
