Hello!!!
I have 2 parts for identification (marked with red dots in the photos), if you may help.
The first is from an old HDD PCB, and it is probably a fuse (?), blown ( checked with my dmm) and as far as i know ( by the circled "M" symbol) by Murata.I may be wrong (i could not find any Murata fuses, only capacitors) but anyone who knows can share the info.
The second part is probably a PNP FET transistor, marked P06 with a vertical 14, it is also blown as you can see in the second photo. I tried to trace down the part, and the best i could do is the attached datasheet. I may be wrong again, if someone knows, you're welcome.
If someone has information on the above, i would appreciate if he could share it.
Thank you in advance.
