SMD Fuse and Diode replacements.
  • felix
    • May 2008
    • 34
    Hello!!!
    I have 2 parts for identification (marked with red dots in the photos), if you may help.
    The first is from an old HDD PCB, and it is probably a fuse (?), blown ( checked with my dmm) and as far as i know ( by the circled "M" symbol) by Murata.I may be wrong (i could not find any Murata fuses, only capacitors) but anyone who knows can share the info.
    The second part is probably a PNP FET transistor, marked P06 with a vertical 14, it is also blown as you can see in the second photo. I tried to trace down the part, and the best i could do is the attached datasheet. I may be wrong again, if someone knows, you're welcome.
    If someone has information on the above, i would appreciate if he could share it.
    Thank you in advance.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: SMD Fuse and Diode replacements.
    the first is a clock crystal.
    try http://www.marsport.org.uk/smd/mainframe.htm
    to find the second
    • selldoor
      Slow Learner
      • 7870
      Second could be one of these DDTA123JCA is it definitely a SOT23 package?
      • felix
        • May 2008
        • 34
        Thank you both for your answers. Sorry for my late reply, i hadn't set my forum email account for active notification.
        to find the second
        So , my guess was totally off !!! A clock crystal!! Thank you!!!
        Yes, as far as i know it is a SOT23, but i will measure it to be sure.
        The item you said, is also a PNP SOT23 transistor, only difference is that it is pre-biased ? Am i correct ?
        Also seems that the marking on the DDTA123JCA would correctly be P06 but the date code on the burnt one is "14", the DDTA has a date code with letter for year and number for month,while the NXP one ( attached datasheet) does not specify anything about date marking.
        Tough one....
        I found one NXP on ebay, but it's ~1,5€ for one piece only, are they really that pricey ?
        • selldoor
          Slow Learner
          • 7870
          Does that include postage I would a have thought 20/25c would be about right.
          Have you tried looking in any old electronic stuff you could take one off?
            • 31046
            digital transistors arent cheap.
            i salvage them of scrapped boards because of it.
            and "20/25c" ?
            where do you get that from?
            your in the u.k. - you cant even buy a stamp for under 50p
            • selldoor
              Slow Learner
              • 7870
              Originally posted by stj
              and "20/25c" ?
              Well, the one I was looking at is here
              http://uk.mouser.com/ProductDetail/D...Qcq/wm7rImVA==
              Which is 14p - perhaps I am not comparing like with like?
              Or these
              http://cpc.farnell.com/on-semiconduc...20This%20Range
              FREE delivery in the uk - not that I need it as I live nearby.
              3p !!!!!!
                • 31046
                last time i looked, free delivery had a minimum order value - and it wasnt a resistor!!
                • selldoor
                  Slow Learner
                  • 7870
                  Ok stj - I have not looked for about a month , Min order is now £5 but prior to that for 6 to 8 months they would have sent a 2p resistor for free - I advised many members at the time and they were very pleased, not that many were looking for just a single resistor where abouts are you ?
                  • felix
                    • May 2008
                    • 34
                    The price i wrote in previous post is without shipping.
                    I stated that price in order to be easy to compare.
                    @selldoor, salvage from old boards is a very good idea....i'll try to find from someone that has boards for scrap
                    mouser/farnell/digikey are pricey as far as shipping to Greece is concerned
                    Next week i might have the opportunity to look at some shops @ the center of Athens, who knows...they might have...
                    Thank you again for your answers!!!!
                    • Duncanbest
                      • Jul 2012
                      • 81
                      • Taiwan
                      The first is not crystal. --->Murata's shock sensor
                      http://www.murata.com/corporate/busi...puter.html#a01
                      https://www.google.com/search?safe=o....0.Y5wJVpPybv4
                      • felix
                        • May 2008
                        • 34
                        Originally posted by Duncanbest
                        Where is the freakin' "Thanks" button ?????
                        Back to the board to diagnose the fault...
                        • felix
                          • May 2008
                          • 34
                          I ordered 10x the specific NXP transistor for 0.6$ each, along with other electronics.
                          Thank you all for your comments & help.
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            i thought about that a bit after i posted.got sidetracked and forgot to add that info as a possibility.
                            • felix
                              • May 2008
                              • 34
                              The motherboard with the burnt PNP was repaired in a few minutes and after that, the CPU Fan works like a charm.
                              The HDD board whose sensor is shown in the first photo, might be repaired with a replaecment PCB some time. It is not critical now...
                              • corrize
                                A funny fuse story – Lumix LX100 II
                                by corrize
                                Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                10-19-2023, 09:58 AM
                              • asr
                                Finding replacement diode iPad Pro 3rd gen A1701
                                by asr
                                Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                07-09-2024, 06:24 PM
                              • jshhh
                                Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                                by jshhh
                                Hi guys,
                                I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                                How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                                Anybody know how to remove this type of fuse?
                                (The fuse is toward the bottom of the image labeled F2)...
                                06-17-2025, 01:35 AM
                              • unimatrix93
                                TV backlight zener diode
                                by unimatrix93
                                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                The led strips has 9 6V leds.
                                02-10-2025, 12:13 PM
                              • drykid
                                Matsui 175S microwave fuse replacement
                                by drykid
                                I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
                                Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
                                12-21-2020, 01:15 PM
