power relay number matching
+ More Options
Posts
    • 12206
    • U.S.
    having a little trouble figuring out what relay will substitute for my power relays on a pcb, I am replacing both that are side by side, thanks.
    • 12206
    • U.S.
    Re: power relay number matching
    example: G2R-1A-E-T130DC24, G2R-1A-T130DC24, GR2-1AE-DC24, GR2-1-E-DC24, all seem to look the same, the same, I guess I'm wondering what the numbers mean, and if I have to use the same exact ones I took out if I'm replacing both, thanks.
      • 31065
      get the datasheets to understand the meaning of the numbers.
      • mariushm
        • May 2011
        • 3799
        Have you tried to use GOOGLE with at least one of those names, or parts of those codes?
        I just entered G2R-1A-E in google and first result that shows up was G2R series of relays made by Omron.
        Then page gives you the datasheet which tells you the meaning of those digits right on the first page:
        https://cdn.badcaps-static.com/pdfs/...9eaaa0e2aa.pdf
        G2R-@-@@@@-@@
        1 2 3 4 5 6 7
        1. Relay Function
        None: Single-side stable
        K : Double-winding latching
        2. Number of poles
        1: 1-pole
        2: 2-pole
        3. Contact Form
        None: NO/NC
        A : NO
        4. Contact Type
        None: Single
        Z : Bifurcated contact
        5. Enclosure rating
        None: Flux protection
        (T-type is an enclosed
        relay)
        4 : Fully sealed
        6. Terminal Shape
        None: PCB terminals
        T : Quick-connect
        (upper bracket mounting
        #187)
        7. Classification
        None: Standard
        E : High-capacity
        H : High-sensitivity
        U : For ultrasonically
        cleanable
        Z : Full-wave rectifier
        etc etc etc
        Man, do some search before asking such questions
          • 12206
          • U.S.
          I did plenty of search, if you think you have to be RUDE "DO NOT RESPOND"!!!
            • 12206
            • U.S.
            will do stj, thanks for the reply, and THANKS for not being rude, some others could take a lesson.
            • mariushm
              • May 2011
              • 3799
              Well, you obviously didn't, or you don't know how to search.
              Here's the search results for the exactly first code you've written in your post :
              Any link on that first page will link to the datasheet, or tells you that it's made by Omron and you can then go on Omron's page and get the datasheet.
              And I can be as rude as I want to be, there's no rule saying I can't.
                • 12206
                • U.S.
                Looky here troll, if you can't help people without developing diarrhea of the mouth, then buzz off, as in go play in traffic.
                • redwire
                  • 3910
                  I bought G2R-1-E-T130 12VDC cheap on eBay but Google was not my friend, nor the Omron datasheet to figure out the "T130" portion of the part number.
                  Looking at it: SPDT (1C) high-capacity, PCB mount, flux protection, unsealed, but I have no idea what the "T130" suffix means.
                    • 31065
                    google is nobody's friend,
                    use duckduckgo or yandex
                    • mariushm
                      • May 2011
                      • 3799
                      T130 means it's rated for maximum 30V DC @ 16A.
                      If you bought it cheap on eBay, doesn't matter anyway, it's probably fake or was recycled from some device and you have no idea how many times it was turned on/off and how burned up/oxidized the contacts are inside.
                        Google works just fine.
                        From Omron master catalog:
                        Coil Class B insulation (130c).
                        5. Suffix T130 rated at 130°C
                        I myself use Class 'F' 155c rating in my products design, I use lots of Omron relays.
                        Page 1:
                        Note: 1. AgInSn and gold plated contacts available.
                        2. Bifurcated button available.
                        3. For individual product agency approvals consult factory.
                        4. Class B coil insulation available
                        G2R-1A-E is the HIGH CAPACITY which is 16A Contact rating, see Page 1 and Page 3.
                        • redwire
                          • 3910
                          Thanks budm, I couldn't find that number in the datasheets.
                          It seems to be for a UL Class B (130°C/265°F) standard for coil insulation.
                          The relays I got from a Ham radio operator on eBay, have a clear case and I can see they are new and look like Omron quality.
                          Actually, I use DuckDuckGo instead of Google because I dislike being tracked with search queries, websites visited and the analytics.
                            The standard coil insulation is <130c, 75~85c is typical.
                            I use Duck also but I get less hits than Google, and that is correct, Google does track your search info but for me at work I could not careless, they can track the company I work for all they want.
                              • 31065
                              duckduckgo has config bits.
                              by default it will search the country your originating from.
                              if you embed it in your browser then set it like this:
                              https://duckduckgo.com/?q=%s&kp=-1&kl=wt-wt&kv=1&kh=1
                              the q=%s is the search-string,
                              the rest of it is for global search, no localisation, no sensoring and no limitations.
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                by sam_sam_sam
                                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                Found shorted diodes on main controller relays there are 3 of them that...
                                01-07-2023, 05:43 PM
                              • Journey11
                                Samsung TV won't turn on ... keeps cycling the power relay on & off
                                by Journey11
                                Hi All,
                                First time posting here ... my name is Kevin but my friends call me Journey.
                                I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                07-04-2024, 02:44 PM
                              • valvashon
                                Repair Success! Middle Atlantic UPS2200R-IP
                                by valvashon
                                Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                02-06-2024, 12:54 PM
