diode question / identify
  • eradz
    • May 2010
    • 20
    Attached is a crappy pic of a bad diode on tv board which the HDMI port stopped working. The other diodes test fine for the other HDMI port. What type of diode is this? I cant see any numbers on it or anything.
    Eradz
    Re: diode question / identify
    What is the make and model of this TV? Did you test it off the board yet? The picture is way out off focus to see clearly.
    • eradz
      • May 2010
      • 20
      I have not tested it off the board but I am 99% sure its bad. I tested the other HDMI diodes and that one diode tests bad. I know its out of focus and will try to get a better pic. I will have to use a magnifying glass to see anything on it.
      • selldoor
        Slow Learner
        • 7870
        If as you say you are sure its bad then you may as well take it off the board - it will have to come off whatever.
        If it is paralleled on another section of the board it may be easier to read the part number
        on its twin.
        Is the other hdmi port working ok?
          I can see that it is connected in series with the diode on the left, so it can be the TVS protection diode. If we can get the make and model, then we can locate the service manual for the TV. Did the TV get hit by the surge?
          • eradz
            • May 2010
            • 20
            I will get the make / model when I get home. The other HDMI port is working which makes me think that one diode is bad. It looks like 2 diodes per port so I test them all and the one diode that is bad, the port doesnt work. A service manual would be great! Ill post the info asap.
            • eradz
              • May 2010
              • 20
              Vizio VX32L HDTV 10A - I will post another pic here soon.
                Good pictures from SJ:
                http://www.shopjimmy.com/media/catal...50-top_1_1.jpg
                Can you get the P/N as printed on u23, u25? I found the service manual but it does not have any diagram.
                http://76.254.74.102/manuals.html
                  • 31013
                  if in doubt, try a LS4148
                  • eradz
                    • May 2010
                    • 20
                    Nice pic budm. I cant read U23 and U25 because I cant find my mag glass but I will have one tomorrow. Ill post what they say on here.
                    • eradz
                      • May 2010
                      • 20
                      stj, if I replaced it with the LS4148, there is no possible way for me to kill it? No over voltage or anything crazy before identifying the diode?
                        • 31013
                        if it's a normal diode and not a zener type then the 4148 is a generic fit for most.
                          • 31013
                          looking at the foto's again, a 4148 may be a bit small to fit on the pads - i'd have to check.
                          • eradz
                            • May 2010
                            • 20
                            I can get a measurement if you want.
                              • 31013
                              the ls4148 is 3.5mm long.
                                For temporary test you can use axial leads type to try out.
                                • eradz
                                  • May 2010
                                  • 20
                                  Budm, ill give that a try. I think radioshack might have some til I can order more off mouser or digikey.
                                  • tvguy12012012120
                                    by tvguy12012012120
                                    02-07-2025, 05:13 PM
                                  • caspian
                                    What Zener Diodes on a Linear Power Supply
                                    by caspian
                                    Dear members,
                                    I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                    Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                    In addition, I discovered that its zener diodes are defective.
                                    I can replace the burned transistors.
                                    But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                    Therefore, I cannot replace the zener diodes.
                                    I do not want to test the zener diodes in a test circuit to discover their model or value.
                                    no schematics are available...
                                    05-26-2025, 12:38 PM
                                  • magneh
                                    Motorbike PCB - burned Diodes ( PJ78) - help to identify identical or equivalent
                                    by magneh
                                    Hello everyone
                                    Got a motorbike PCB that had 3 burned diodes.
                                    The smaller ones have the marking PJ78 GS1M
                                    And one larger one PJ78 GEX
                                    Can someone help me identify them so I can be able to replace with same or equivalent?
                                    Photos attached
                                    Apreciate !
                                    Thank you...
                                    05-19-2025, 07:38 AM
                                  • hobostove
                                    Corsair RM1000e - Help identify 5VSB Zener diode
                                    by hobostove
                                    Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                    Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                    There's a 22ohm resistor that's melted and open, but it still has the bands.
                                    The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                    It looks like the diode connects the source and drain of a TNY284...
                                    03-27-2025, 02:25 PM
                                  • dj8452000
                                    How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                    by dj8452000
                                    I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                    02-18-2025, 08:28 AM
