Questions for Fusible Resistors
  • cbr600rr_blue
    • Apr 2014
    • 14
    • Malaysia
    Hope that experts can share their views here
    I have a blown fusible resistor labeled as W1/2J 2.2 ohm FU985. I interpreted it as 0.5 Watt, +/-5% tolerance. I can't read out further information. The dimension of this blown fusible resistor is 10mm in length and 5mm in diameter as the attached photo. It is relatively big.
    When I tried to order this online, tyco FRN50 seems to have same specification. But the dimension of FRN50 is much smaller.
    It is 6.3mm in length 2.3mm in diameter.
    It is only about half of the size of the blown one. Will this replacement work?
    I have attached the specification for FRN50. Does size matter especially the heat and thermal concerns?
  • cbr600rr_blue
    • Apr 2014
    • 14
    • Malaysia
    Re: Questions for Fusible Resistors
    no one can share the knowledge?
      If you look at the spec, the withstand voltage after fusing (after blown open) is one of the important number to compare to the old one. It is similar to the fuse voltage rating, I.E. you do want to 5A 32V car fuse to replace the 5A 250V fuse used in the line operate equipment.
      Do you know where this fusible resistor is used in the circuit and how high is the voltage it is being used in?
      • Longbow
        • Jun 2011
        • 623
        Application? A fusible resistor is not a fuse, it is a resistor that is usually made of fireproof material, and designed to smoke at a certain current level. The wattage of the resistor will determine if the resistor smokes or just gets warm. Even if you can't find a reference for those numbers, look at your circuit to see what is required.
        Is it plugged in?
          There is FLAME PROOF resistor, and then there is FUSIBLE resistor/FLAMEPROOF fusible resistor that serves 3 functions.
          http://www.interfacebus.com/Electron...r-terms-F.html
          When it goes open, it must not allow the voltage to jump over the open circuit, thus the the withstand voltage after fusing rating is provided.
          FRN series is the Flame proof Fusible resistor.
          EMC and ULW are aimed chiefly at mains input protection for
          small power supplies and battery chargers. Here it performs
          three circuit protection functions:
          1. Providing protection against supply line voltage transients,
          often in conjunction with a shunt element such as a Varistor
          or Transient Voltage Suppressor (TVS). This enables the
          designer to achieve the required level of immunity to
          conducted lightning induced surges.
          2. Restricting the peak inrush current at switch-on to levels
          suitable for the rectifier bridge and consistent with good
          EMC design.
          3. Preventing fire by fusing safely under fault conditions such
          as rectifier or capacitor breakdown.
          • cbr600rr_blue
            • Apr 2014
            • 14
            • Malaysia
            This is for Sharp AQUOS LCD TV power supply board DPS-226-AP-1. It's at primary circuit so it must be 230volts AC.
            So can this replacement fusible resistor FRN50 be used but with a much smaller dimension?
            • redwire
              • 3910
              Size of a resistor and it's temperature rating determine the wattage. That resistor is the size of a 2W part.
              I would not use the 1/2 part as a replacement.
              Most power resistors are rated at 70°C, so their size determines the wattage.
              Yageo Flame-Proof type_RSF.pdf
              • cbr600rr_blue
                • Apr 2014
                • 14
                • Malaysia
                Hi
                I thought that W1/2J is 1/2Watt (0.5Watt) because J is tolerance.
                • cbr600rr_blue
                  • Apr 2014
                  • 14
                  • Malaysia
                  This is the photo for the blown fuse before desoldered.
                    More likely to be for main B+ line which will be around 330VDC. Trace out the circuit to see if one end is connected to the + terminal of the main filter cap (450VDC rating). There must be shorted out components that you need to checked out.
                    • cbr600rr_blue
                      • Apr 2014
                      • 14
                      • Malaysia
                      Actually this is related to another post few days ago where a TNY264PN IC crack. At that time, U only replace the IC but didn't know that this fusible resistor also blown.
                      see the link:
                      https://www.badcaps.net/forum/showth...264#post436087
                        So it is the fusible resistor for feeding the B+ which is around 330VDC. So the fusing withstand voltage should b e more than 330v
                        • redwire
                          • 3910
                          Looks like it is made by Futaba. They have some funny names for their resistors: "ANTI-BURST FUSIBLE RESISTOR", "HEAT ENERGY SURGE WIRE WOUND FUSIBLE RESISTOR" etc. Take a look under "fusible" category.
                          Note a fusible resistor has two voltage ratings - the max. working voltage, and the max. fuse voltage. This is a 2.2R beast, so it would normally never seen more than a few volts.
                          Why it is so big and really a 1/2W? I guess its a high-voltage type, or non-inductive if used as a snubber.
                            Lets stick to one thread.
                            • cbr600rr_blue
                              • Apr 2014
                              • 14
                              • Malaysia
                              Followed by the replacement of 2.2 ohm fusible resistor, the LCD TV powers up nicely now.
                              Thanks everyone help.
                              • cbr600rr_blue
                                • Apr 2014
                                • 14
                                • Malaysia
                                You are great! The FU is FUTABA.
                                It's Taiwanese maker.
                                It's antiburst no wonder the size is bigger than usual.
                                Other makes are usually flame-proof only
                                • steinless
                                  • Aug 2013
                                  • 37
                                  • singapore
                                  Hey all would like to ask, if i replace it with a 4.7 ohm fusuable, would it affect anything?
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    You should always replace a fusible resistor with the same value.
                                    • jeremykum
                                      • Feb 2012
                                      • 95
                                      • Malaysia
                                      Just wish to say thank you for the people sharing here.
                                      Now trying to fix a Sharp DSP-174AP board from 40", owner claims lightning strike.
                                      Initially located a Toshiba K3256 N channel FET shorted. Circuit not shorted. Replace it but still not powering up.
                                      Now notice this W1/2J 2.2 ohm should be dead. This board have 2 pcs of these at the main cap 320V. The R7910 input 320V, while output only 1.5V. Will try to order and replace it.
                                      Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
                                      • nickgronk
                                        • Apr 2021
                                        • 32
                                        Does anyone know of a suitable replacement for this resistor. I am having a hard time finding a good replacement.
                                        • reessi
                                          20v / 2A SMPS for a Battery Charger - Explanation of Blown Resistors Please..
                                          by reessi
                                          My friend asked me to replace the wire going from this SMPS 20v adapter to the charger for a 18v Lithium Battery for a drill.
                                          The cable had frayed and been touching, as a result the 5 Paralleled R200 (0.2 ohm) resistors had blown O/C, they are connecting the main -ve rail to the output wire.
                                          The output was jumping around 13v and dis-appeared when a load like the charger was connected, they measured 900ohms.
                                          I experimented by replacing at first a single 0 ohm and then a 2.2ohm in and the output was restored at 21.62v and 21.65v respectively...
                                          08-22-2024, 08:12 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • Widget
                                          Blown heated blanker controller. Trying to figure out these smd resistors
                                          by Widget
                                          We have one of those heated throw blankets you plug into AC power. The other day it went *bzzzbzzzbbzz... pop*, so I opened it up to find what appears to be two resistors gone *poof*. (R7 & R14 in picture)
                                          luckily, we have a second blanker with what appears to be identical controller, so I opened it up to take a picture
                                          According to the good controller PCB, R7 = 9531, & R14 = 103
                                          Online SMD resistor calculator says
                                          R7 - 9531 = 95.3kohm
                                          R14 - 103 = 10kohm
                                          Is this correct? Would all I need is a 10k...
                                          06-30-2024, 11:22 AM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • kahlil88
                                          Displaced tiny resistors on Dell Dimension 8300 board
                                          by kahlil88
                                          Had some difficulty removing the caps off my Dimension 8300 board. My cheap soldering iron just couldn't seem to melt the solder so I flipped over the board and used hot air. They all popped out fine but halfway thru wicking up the remaining solder, I noticed several tiny resistors near the CPU had been bumped out of place! ...
                                          08-29-2022, 05:46 AM
