What is the end called on this wire?
This topic has been answered.
  • Jackching
    • May 2017
    • 127
    Anyone know what the end is called on this gps wire?
    https://www.amazon.ca/dp/B01N3QHLDE
    I see you can buy gps antennas that have wires exposed and no cable ends. I need this end for my hondex plotter.
  • Answer selected by Jackching at 09-29-2024, 03:09 PM.
    redwire
    • 3907
    TOPGNSS antenna wiring is different, for some reason I thought you had the SCU-31. I think no big difference if RX- is connected to ground or TXB.
    *Note the thin/skinny black wire is special and not a ground but NMEA OUT-/TXB(-). The thick black wire is GND.
Name:	TOPGNSS GPS antenna wiring to Hondex draft.png
    • Jackching
      • May 2017
      • 127
      Possibly a GX16/6?
        • 31015
        without dimensions it could be a GX - often called an aviation connector, but it could also be a variant of a DIN socket.
        • harp
          • Jun 2022
          • 598
          • Planet Earth
          Maybe some info on link, or contact seller
          https://jgtech.com/gps-6pin-connector.html
          https://www.bluebottlemarine.com/pro...cx-106-6g.html
          Searching for simmilar pictures, see the nut is placed on different depth and may not be compatibile as well.
          • Jackching
            • May 2017
            • 127
            I still didn't find out the actual name to this plug. It plugs into the Hondex plotters. Here is a better picture:
            https://auctions.c.yimg.jp/images.au...msy1224021.jpg
              • 31015
              it's not a GX - the holes are too small and the notch is off-center
              it's not a DIN again because the keying is not centered.
              • CapLeaker
                Leaking Member
                • 8146
                Maybe similar like a ZC series 6 pin made by Cliffcon? They do make custom stuff... maybe give them a call.
                • Jackching
                  • May 2017
                  • 127
                  It does look like this but im not finding any difference when i look at this and the GX
                  • CapLeaker
                    Leaking Member
                    • 8146
                    Thats the only thing I could come up with that is the closest match. Probably the locking mechanism is different. On that ZC series the locking mechanism like a pilot or ham radio mic and the outer ring screws on to the receptacle until tight, I am not sure but I think yours you plug in and give something like a 90 degree twist on the outer ring?
                    In any case… give these guys a call and send them your picture. Maybe they have something or can make you something.
                    If push comes to shove, you can always change out the receptacle on the plotter with something more common like a “normal” 6 pin configuration.
                      • Jul 2011
                      • 6039
                      On a couple of my battery testing machines they have aviation type but what I found out is that there several different sizes and it is hard to determine which size you have because I ordered some that I thought were the right size it turns out that it was one size bigger than the ones I bought so had to reorder the right size the second time so it might be a hit and miss to find the right one or just change it out for one that is not too hard to find one note buy it big enough size that it is easy to solder on because they make some really small ones I had to once replace one on a machine for a company that I used to work for and I can tell you it was not fun
                      • Jackching
                        • May 2017
                        • 127
ID:	3468018 Click image for larger version
                        So i received the GX16-6 and they do indeed fit. I may need help wiring it now though. Would the two ground wires on the antenna go to pin 1 of the connector? I'm also wondering why there is a data input - and + on the connector. Im pretty sure red would go to pin 6 and maybe RX to pin 5?
                          • 31015
                          data input +/- is probably RS485 differential signalling
                          • CapLeaker
                            Leaking Member
                            • 8146
                            One may be chassis ground, while the other is power ground. Just look at it with your DMM. Just start populating the pins you know for sure, then the rest isn’t that daunting. Also make sure you look at the wiring picture the correct way.
                            Happened to me just a couple of months ago ago, that I had to make a custom cable. Once picture was seen from the front of the connector. However the other connector was seen from the back side. Needless to say, I effed it up and had to redo the connector.
                            • Jackching
                              • May 2017
                              • 127
                              I'm not really understanding the way you are explaining to go about this.
                              • redwire
                                • 3907
                                The problem is confusing wire labels, poor translation, and some are TTL RS-232 others are RS-422. Then there are mistakes. What a mess!
                                Let's all curse Yaesu for being jerks about their technical data.
                                Wiring of Standard Horizon SCU-31 GPS Antenna:
                                RED - DC POWER INPUT (+10 to 35 VDC)
                                BROWN - GPS DATA OUTPUT (+), connects to radio GPS RX+. This is TTL RS-232
                                BLACK/SHIELD - GND/COMMON
                                Not confirmed are:
                                GREEN - ???
                                BLUE -??? GPS DATA INPUT (+), connects to radio GPS TX+ or leave not connected.
                                What model is your Hondex plotter?
                                • Jackching
                                  • May 2017
                                  • 127
                                  HDX-121-BB
                                  • Jackching
                                    • May 2017
                                    • 127
                                    This diagram from the manual shows it a bit better.
                                    Here's what I did:
                                    Red - 6
                                    Yellow - 5
                                    Blacks - 1
                                    Green - 3
                                    The green I just kind of guessed. My other option for green was 2. I will test it tomorrow.
                                    • Jackching
                                      • May 2017
                                      • 127
                                      I tried green on prong 2 and 3 and neither worked so I'm not sure what to do next
                                      • redwire
                                        • 3907
                                        OK give me some time to draw a diagram. It's hard. The H and C (TXD H,C etc.) is hard to know what they are doing.
                                        *HEY what colour wires are there in the SCU-31 cable? The manual gives only 3 of the 6: red, green, brown, blk and I also find this pic for the SCU-31 GPS antenna/
                                        One youtube video shows a blue wire. Aaauurgh.
                                        Click image for larger version  Name:	SCU_31-wiring.webp Views:	0 Size:	20.7 KB ID:	3469886
                                        • redwire
                                          • 3907
                                          This is what I would try for wiring the SCU-31 GPS antenna to the Hondex HDX-121 plotter. Problem is the Standard Horizon SCU-31 GPS antenna seems to have unknown wires (blue, yellow) not in its manual.
                                          You must program the correct baud rate in the plotter for whatever port you are using:
                                          Menu 7.EXT TERMINAL – {not sure if you need to use the output feature, which is when the plotter can also send information to the GPS antenna).
                                          3.NMEA1 OUTPUT ON/OFF
                                          4.NMEA2 OUTPUT ON/OFF
                                          5.NMEA1 PORT BAUD RATE
                                          6.NMEA2 PORT BAUD RATE
                                          7.GPS PORT BAUD RATE. (4800, 9600,38400) {SC-31U is 4800} GP-16H: 4800, GP-17H(HD): 9600 AIS: 38400
                                          Reboot the unit after change of this set-up.
Name:	GPS antenna wiring draft.png
                                          • wnlewis
                                            New wire for my RDE3340 Whirlpool electric range
                                            by wnlewis
                                            OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                            Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                            This is a Whirlpool RDE3340 electric range.
                                            The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                            Where may I find parts...
                                            01-08-2025, 11:21 PM
                                          • emeskay
                                            Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                            by emeskay
                                            We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                            08-06-2024, 07:13 AM
                                          • technicalspecialist
                                            Vintage fan repair, copper wire question
                                            by technicalspecialist
                                            I currently have a customer's vintage fan on the work bench to repair.
                                            It uses an induction motor with 4 poles. One of the poles is open.
                                            I couldn't find the break so i cut off the original wire.
                                            I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                            I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                            The enamelled copper...
                                            03-16-2023, 12:54 PM
                                            Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                            by sam_sam_sam
                                            I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                            I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                            12-16-2023, 08:39 PM
                                          • GlenBrim
                                            1070 GPU. DVI port removed, wire in its place, why? Stuck on low clocks too.
                                            by GlenBrim
                                            I got this recently as-is. Gigabyte 1070 video card.
                                            DVI port is removed. I don't know why.
                                            A wire is soldered across two spots where it looks like the DVI port was. I don't know why.
                                            I've read of people simply ripping out DVI ports and the rest of the cards still working fine. Never read anything about soldering a wire in there for some reason.
                                            The card seems to work fine, except it's stuck in low clock speeds. While starting a game or benchmarking, the clocks may momentarily increase to around where they should be, then goes way back down and stays...
                                            02-14-2024, 02:08 AM
