lg psu
    lg psu
    hi does anyone know what caps i need to buy for lg50 pc1da i did take caps out but they only say 3300uf 16v on them and 3300uf 63v ect and when i ring up to buy they say they need part number lol
    Re: lg psu
    Its probably so you get the correct physical size - they may have those values
    in several sizes. Have you looked at cpc - they have free delivery on internet orders - no min order.
    Why have you started a second thread??
      Re: lg psu
      yer looked on there got lost lol i was hopping somone with same tv would know or somone on this site could sell them to me
        Re: lg psu
        hes pm d me selldoor i suggested he started a new thread so that we can try to help with his fault finding as it may not be only just bad capacitors i said its probably best to open a thread so we can all try to help sort the problem out maybe a moderator will remove the other thread for him and keep it all in one this is the site i use
        http://cpc.farnell.com/
          Re: lg psu
          so does it matter on hight width ? if there room for bigger or smaller
            Re: lg psu
            tony post up the height and width of the caps that you need then you can see whats suggested with low esr etc you need 3300uf 16 volt and 3300uf 63 volt its ok found the size from the pm the ones in psu r 25mm high and 15mm wide
            maybe EEUFR1C332S for the 16 volt ones
            whats the measurements of the 3300uf 63 volt on your board
              Re: lg psu
              63v is 15.5 w 25mm high
                Re: lg psu
                what make of capacitor have you removed
                  Re: lg psu
                  its a 680uf 63v
                  then 3300uf 16v
                    Re: lg psu
                    Eeufc1j681 - capacitor, 680uf 63v
                      Re: lg psu
                      OK Vince - probably also need to ask if they are snapin or leaded unless you know? cpc dont appear to have any that value that size.
                      Well it helps when you have the right values eh
                        Re: lg psu
                        thats great thanks
                          Re: lg psu
                          yes a late edit there i got confused as well but hope the ones chosen will do the job for him.
                            Re: lg psu
                            done recap today tv been on for over 2hours and not turned off
                            thanks for all the help
                              Re: lg psu
                              glad its sorted for you hope all ok with it.
                                Re: lg psu
                                was on all day with no probs so gues its fixed im sure it would of turned off if not what do you think ?
