SFH6286 Optocoupler
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    SFH6286 Optocoupler
    Hi, please help me. I need to test this optocoupler but i am not sure if it is OK or not.
    I test diode test and got readings:
    between 1 and 2 = 0
    between 2 and 1 = 0
    between 3 and 4 = 1.28V
    between 4 and 3 = 1.28V
    shoud i have reading between 3 & 4? Resistance between 3 & 4 is 25 Mohm
    here is schematic
    ...the quieter you become the more you are able to hear...
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    Re: SFH6286 Optocoupler
    between 1 and 2 = 0
    between 2 and 1 = 0
    here is schematic
    that opto is shot,the diode led should have reading one way and not the other
    in my exp the led blows 1st.
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      There are two matched LEDs in that device, in inverse parallel, so reading both ways is OK.
      • selldoor
        Slow Learner
        • 7870
        That was my immediate thought but when you look at the picture it has two
        diodes ? so does that cancel the test out?
        Most diagrams for Optoisolators have only one diode?
        Ha - Thanks Tom beat me to it while I tried to spell optoisolator tho I wasnt sure.
        What about part two - reading between 3 & 4 - voltage reading?
        • rtstorm
          • Feb 2012
          • 971
          • Croatia
          it have 2 diodes on one side (1 and 2) i have reading in both way on other side (3 and 4)
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            i think part one (1 and 2) is ok, but second is i think bad. Should i have both reading between 3 and 4?
            • selldoor
              Slow Learner
              • 7870
              If I remember correctly it is difficult to test that 3/4 side. Look it up on google I think you need 2 analogue voltmeters. But you can test for a voltage on the board.
                "3 & 4 is 25 Mohm" that is just the Emitter-Collector leakage resistance.
                "between 1 and 2 = 0
                between 2 and 1 = 0"
                Do you mean 0 on you meter in Diode mode? It should show 1.1~1.5 (per spec of the Opto) reading. Note: in diode mode testing, the meter is actually showing the Vf (forward voltage) of the device.
                You can use 3V battery with 470 Ohms resistor in series to limit the current and connect it to pin 1 and 2, polarity does not matter since this is an AC input Opto (it does not care about the polarity of the input voltage due to dual LED inside). On the output side you can set your meter to 200 Ohms or 2K or in continuity mode (this will depend on the meter spec), you should see low resistance when the battery is connected to 1 & 2 with that resistor in series.
                • rtstorm
                  • Feb 2012
                  • 971
                  • Croatia
                  Do you mean 0 on you meter in Diode mode? It should show 1.5~1.8 reading. Note: in diode mode testing, the meter is actually showing the Vf (forward voltage) of the device.
                  I mean 0 like no connection, yes 0 in diode mode.
                    No, it should not show no connection, get 2 red LEDs and connect them back to back just as shown and test with your meter, that is about the reading it should show.
                    They are just 2 LEDs back to back inside.
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      i try this, and i do not have low resistance on output. So can we confirm that this optocoupler is bad?
                        I think it is bad due to 0 reading on pin 1 and 2 as you reported so the Phototransistor inside does not detect anything from the LEDs.
                        • khelane
                          test active pfc power with lamp test
                          by khelane
                          Hello
                          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                          Is there a way...
                          06-03-2025, 01:00 AM
                        • chronic519
                          Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                          by chronic519
                          Hello.
                          GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                          Found issue with a RAM block
                          Replaced, green lines gone.
                          Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                          Used a good card to test and same results low errors 32+.
                          I am just search for some form of command to do a full test on the GPU.
                          I just ran the mats command with my good GPU and passed after roughly 40 min.
                          The repaired one, ran...
                          05-20-2025, 07:56 PM
                        • hemant_2222
                          Yamaha 2064 No sound but Test audio working
                          by hemant_2222
                          Hello Guys,
                          Greetings!
                          Hope you all are doing well.
                          I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
                          PCM1681DBQR - IC263 and it worked fine.
                          Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
                          11-01-2025, 11:20 PM
                        • tvguy12012012120
                          by tvguy12012012120
                          02-07-2025, 05:13 PM
                        • alltvrepairs
                          Lg TCon test pins for screen test
                          by alltvrepairs
                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                          Appreciate your help....
                          06-13-2025, 06:33 AM
