please help identify this diode
+ More Options
Posts
  • shaunbt123
    • Nov 2012
    • 119
    im working through my tv power supply board and i found a diode which appears shorted.the best way i can describe the diode is clear glass/plastic with a single yellow band.i have tried taking pics but cannot focus in clear enough.
    thank you.
  • selldoor
    Slow Learner
    • 7870
    Re: please help identify this diode
    Doubt if there is a chance better to post a picture of the board it came from with a close up of where it is and the board designator ZD??? can you find a schematic?
    There is no fixed marking agreed between manufacturers the yellow band just signifies cathode ( If I remember correctly)
    • shaunbt123
      • Nov 2012
      • 119
      thanks for your reply,on the board is just says.D830,however i de-soldered the diode then tested again, and it tested fine.
        It may be connected in parallel with a low ohm resistor.
        Make and Model of the TV?
        • shaunbt123
          • Nov 2012
          • 119
          thank you for your help, its from a toshiba 32AV504D power supply.
          • hobostove
            Corsair RM1000e - Help identify 5VSB Zener diode
            by hobostove
            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
            There's a 22ohm resistor that's melted and open, but it still has the bands.
            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
            It looks like the diode connects the source and drain of a TNY284...
            03-27-2025, 02:25 PM
          • jjne
            AUO M270QAN01 - identify diode?
            by jjne
            I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
            Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
            ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
            01-24-2024, 08:39 PM
          • jezzaaaa
            Identify replacement diode
            by jezzaaaa
            I'm trying to find a replacement diode for one that has gone short.
            I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
            I can't find the exact part number for sale. Similar...
            05-09-2023, 11:26 PM
          • gurj1979
            Ubiquitiu 24 port POE. Help Identify Diode 3pin)
            by gurj1979
            Hi again guys.
            Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
            I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
            Anyone help me identify the model of this Diode ?...
            08-23-2023, 08:39 AM
          • rddube
            Asus C423N motherboard - trying to identify diode
            by rddube
            Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
            Many thanks!
            Ray...
            06-24-2023, 08:08 PM
