Asus C423N motherboard - trying to identify diode
  • rddube
    Aspiring Expert
    • Jun 2013
    • 954
    Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
    Many thanks!
    Ray
  • Sephir0th
    • Oct 2020
    • 1289
    Re: Asus C423N motherboard - trying to identify diode
    ESD protection diode on USB-C data lines. Probably something like AZ5B8S-01F
    FairRepair on YouTube
    • rddube
      Aspiring Expert
      • Jun 2013
      • 954
      Thank you Sephir0th! That is exactly where they are situated, I found 2 of them shorted is that usual?
      • Sephir0th
        • Oct 2020
        • 1289
        It is simply because a USB-C port from where you can charge and also plug in almost any Peripheral you can think of is a big nightmare. Failures like that are pre-programmed if the owner is not careful with plugging things into this jack.
        • rddube
          Aspiring Expert
          • Jun 2013
          • 954
          Oh, ok, but this is the charging port also, so does it have the same issues? Or worse?
          • rddube
            Aspiring Expert
            • Jun 2013
            • 954
            Sorry, just realized that you were referring to the charging port. Thanks again!
            • rddube
              Aspiring Expert
              • Jun 2013
              • 954
              Those protection diodes come in a few voltages, i.e. 3.3V, 5V, 7V, 12V...what do you think is the voltage I should get? Tks!
