resistor 5 band
  • jhonar
    Trying Hard
    • Jan 2014
    • 7
    • philippines and south korea
    resistor 5 band
    my multimeter is damage and i found an open resistor 10ohms .25% 1/2 watt 5 band resistor is it okey to replaced with 4band 10 ohms resistor resistor..
    SERVICE MODE
    http://www.badcaps.net/forum/showthr...t=service+mode
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: resistor 5 band
    What colour bands from left to right are you seeing???
    • jhonar
      Trying Hard
      • Jan 2014
      • 7
      Re: resistor 5 band
      its brown, black, black,gold,and blue
      SERVICE MODE
      • trebo
        • 514
        • Wales, UK
        Re: resistor 5 band
        the only difference is the tolerance, therefore the 4 band is a better quality resistor that you will be replacing
        • selldoor
          Slow Learner
          • 7870
          Re: resistor 5 band
          Is that right? he is replacing the 5band 0.25% with a 5% 4 band.
          • jhonar
            Trying Hard
            • Jan 2014
            • 7
            Re: resistor 5 band
            thanks for reply, now i have no more doubt for replacing..
            SERVICE MODE
              Re: resistor 5 band
              They may have use tight tolerance due to it is used for current sensing circuit such as the resistor connected to the Source pin of the MOSFET. So you need to find out how this resistor is being used, since it went open, that means the MOSFET or what ever it is connected to is shorted out.
              • jhonar
                Trying Hard
                • Jan 2014
                • 7
                Re: resistor 5 band
                @budm what do you think bro is it ok because i'm wondering because it maybe give me a defferent read out..from my multimeter after replacing...
                now im going to buy a resistor 10 ohms 4band to replaced...
                thanks for the replies and support..thanks BADCAPS.
                SERVICE MODE
                • selldoor
                  Slow Learner
                  • 7870
                  Re: resistor 5 band
                  Did you understand what Budm said?
                  In simple terms
                  Depending on where the resistor is being used it might be important to use one that has .25% tolerance
                  Testing with your multimeter makes no difference you cant measure tolerance
                  • jhonar
                    Trying Hard
                    • Jan 2014
                    • 7
                    Re: resistor 5 band
                    Thanks.. sir selldoor got it..
                    SERVICE MODE
                    • trebo
                      • 514
                      • Wales, UK
                      Re: resistor 5 band
                      not sure if I am missing something here, (apologies if I am), but this is how I see it
                      resistor 10 ohms 25% tolerance = could measure anywhere between 7.5 ohms to 12.5 ohms resistor
                      resistor 10 ohms 5% tolerance = could measure anywhere between 9.5 ohms to 10.5 ohms resistor
                      making the 5% tolerance the more accurate resistor
                      therefore I would replace with a 5% tolerance in place of a 25% tolerance
                      but would not put a 25% tolerance where a 5% tolerance was
                      put me out of my misery if I am seeing this wrong
                      and please tell me where I am going wrong with my view of this
                      BTW what budm is also saying is that it is probable that if you just replace that resistor it will fail again until you find out what took it down, so check a few things around it, and buy a couple, good luck
                      • selldoor
                        Slow Learner
                        • 7870
                        Re: resistor 5 band
                        Yes you are missing something - a decimal point or 2
                        Tolerance is nought point two five not twentyfive
                        • trebo
                          • 514
                          • Wales, UK
                          Re: resistor 5 band
                          what a plonker I am
                          thanks for putting me in the picture
                          good luck
                            Re: resistor 5 band
                            OK, it is used in the meter (I missed that in post 1), that is why it is high precision. Even if you put in new resistor, the meter will have to be re-calibrated or check the calibration to see if the meter is still within tolerance.
                            • selldoor
                              Slow Learner
                              • 7870
                              Re: resistor 5 band
                              heheheheheh I missed that as well - didnt realise the resistor was in the meter
                              must have been badly phrased.
                              missed in post 8 as well- Budm you did well to pick that up.
                              • retiredcaps
                                • Apr 2010
                                • 9271
                                Re: resistor 5 band
                                my multimeter
                                What brand and model? Sometimes there are schematics for your multimeter?
                                --- begin sig file ---
                                --- end sig file ---
                                • Snav
                                  • Jan 2014
                                  • 6
                                  Re: resistor 5 band
                                  In simple terms
                                  It is always important if it's .25% they don't spend $$ if it isn't needed. That being said, another consideration can be thermal coefficient. While you can make your own precision resistor you wouldn't be able to duplicate the thermal coef.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Re: resistor 5 band
                                    That's why many beginner's engineering and science books emphasize to always put a 0 (zero) in front of the decimal point. I've personally seen many fellow students make that mistake (especially when transferring hand-written data into Excel).
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Re: resistor 5 band
                                      When I first starting watching eevblog videos, Dave would always say "nought point".
                                      Since I live in Canada, I had no idea what the heck he was talking about. After a while I caught on.
                                      • Askic
                                        Reading resistor value by color band
                                        by Askic
                                        attached is a picture with two resistors. I wonder what values are based on color of the band.
                                        I have used this as a reference:
                                        https://www.electronics-tutorials.ws...tor/res_2.html
                                        Since there are 5 bands, the question is from where to start counting (what is the first band).
                                        Based on this info, I can conclude that thick band is the last one.
                                        Therefore the values are:
                                        Left resistor - red(2) yellow(4) black(0) black (x1) brown (1% tol) = 240 ohm, 1% tolerance
                                        Right resistor - brown(1) black(0) black(0) gold(x0.1)...
                                        02-10-2022, 12:26 AM
                                      • JenneDezaeger
                                        5-band resistor starting with black?
                                        by JenneDezaeger
                                        Can anyone tell me how it's possible for a 5-band resistor to start with black?
                                        If it really was a zero-ohm resistor it probably wouldn't have burned.
                                        So if there are any ideas on the value of this resistor and how to read it, please let me know.
                                        Greetings,
                                        Jenne...
                                        12-06-2022, 06:16 AM
                                      • jinu_j
                                        by jinu_j
                                        Hi
                                        05-03-2025, 10:51 PM
                                      • mikey5791
                                        Need help to replace burned resistor in 350w atx psu
                                        by mikey5791
                                        Hi to all forum members,
                                        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                        12-26-2024, 04:55 AM
                                      • MidnightRoller
                                        Can a resistor lose resistance after hot air?
                                        by MidnightRoller
                                        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                        02-02-2022, 11:46 PM
