USB External Hard Drive.. USB connector broken
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi friends,
    I have an external USB hard drive that isnt working any more. It belongs to a friend of mine. If I fix it back in place it seems to work but the whole connector comes off the board if I dont press it down...
    Can I just use regular glue to fix it in position?
    thanks,
  • 3d0
    • Jan 2014
    • 159
    • BiH
    Re: USB External Hard Drive.. USB connector broken
    I don't think regular glue would hold it in place for too long. Try and solder it a little better, and watch out, too much heat will damage the traces on the board.
    After soldering it, maybe hot glue is the best solution.
    • trebo
      • 514
      • Wales, UK
      it looks like a chunk of the board came off with it, is that correct???
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        I would get it to where it works then epoxy the whole thing down.
        Also suggest to your friend to get a usb extender cable that he can leave plugged in
        and just plug stuff in and out of the extension. Should take the pressure of it unless
        he trips over it of course!!
        • 13919
          • Jan 2014
          • 11
          Popping in with a quick question. With a power supply powered up will voltage be the same on both termanels of a capacitor ?? The glue will not conduct electricity so it will have to be soldered.Use as little heat as possible and work fast to prevent delamination on the board. I use a really hot iron and get in and out fast on this type of repair.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            ??? The glue is only to hold it in place AFTER it is soldered.
            Dont understand your question - voltage on a capacitor is usually taken across the legs or joints, not from ground.
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              yes,if you have the polarity the right way on your probes + to + -to- you would read say 16v if you reversed the probe leads you would read -16v. -to+-to+
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • JonathanAnon
                • Jul 2012
                • 457
                • Ireland
                Hi guys,
                thanks for the responses.. Just to clear up a few questions.. Below I have drawn a black line where the circuit is broken. .. That whole section pretty much lifts off the main circuit board.
                As you will see, the solder joints are all fully on the broken part of the board and as such cannot be used to fix the broken section back in place.
                I hot glued it back in position yesterday, and the blue led on the PCB came on. BUT it was not detected by the PC. The power pins seem to be making a connection but not the data pins (the two centre pins below)
                I'm gonna have one more go at glueing it in position and then throw it in the bin..
                • Uniballer
                  • Jul 2013
                  • 334
                  If you really want it to work, glue down the part that breaks off with epoxy, or something like that to provide real strength. Do not put the adhesive near the traces you need to fix. When your adhesive has cured, scrape the solder mask off the broken traces with an X-Acto knife or dental pick, and bridge the traces back together with solder. With skill and a little luck it will probably work.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    Are there components on the back of the board or can you put a thin plate on the back to help strengthen. Perhaps solder wires onto the data pins first if they are difficult to get to.
                    • JonathanAnon
                      • Jul 2012
                      • 457
                      • Ireland
                      Selldoor and Uniballer, both excellent suggestions guys..
                      I'm gonna try to solder the pins directly to the first component on the board, bypassing the broken tracks. I'll then fix the rest of the broken section in position with the glue..
                      It's a tough one cos it's so small, but I've never used the hot glue on a board before so it's good experience.
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        im not sure about hotglue- not sure it will give the "no movement "required.
                        Also - perhaps clean off any flux/ finger grease etc off the metal with Isopropyl
                        before trying to glue.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          the ground plane is torn away.
                          nothing you do now will last.i would hardwire a usb cable to it and call it good.
                          at least to recover the data.
                          then use for non critical work.
                          • federalhouse
                            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                            by federalhouse
                            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                            **Background:**
                            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                            **What I've Tried So Far:**
                            1. I accessed
                            08-01-2024, 07:03 PM
                            External hard drive/cd rom enclosure-printer port interface recap power supply board
                            I going to modify the enclosure to except the new USB 3 interface
                            The 3.5 enclosure do not have internal switching power supplies and use a small switching wall wart power supply really
                            I need a cd rom drive for my new computer and do not want to use a 2.5 cd rom drives
                            The switching power supply in the old enclosure has nice heat sinks and has a cooling fan in the enclosure that is the main reason why I want to repurpose for this project
                            https://www.ebay.com/itm/231205428647
                            I will post some pictures of it when I get the usb 3 to IDE...
                            04-08-2023, 05:42 PM
                          • ronaldopdias
                            Crucial X8 2TB Portable SSD External Hard drive
                            by ronaldopdias
                            Hi, everyone.
                            I'm trying to fix this portable external SSD.
                            It suddenly stopped working, according to the customer.
                            After diagnosing it, I found this IC in the picture shorted on pin 5.
                            It's a High Voltage Boost Converter (PS6117-40).
                            I can't find any datasheet for this specific IC.
                            I found a similar one, TPS61175-Q1, but the pins don't match.
                            Can you guys help me find where I can buy it?...
                            09-23-2023, 03:19 AM
                          • ChaosLegionnaire
                            bug of the month: write caching setting for the hard drive in device manager
                            by ChaosLegionnaire
                            i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                            so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                            10-06-2019, 01:39 PM
                          • karto95
                            Repairing a Seagate hard drive with damaged logic board
                            by karto95
                            I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                            I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                            If anyone has any suggestions or experience with this...
                            03-21-2023, 04:05 AM
