? on turning a tv back-light into a sighn
  • slee95
    • Jan 2014
    • 14
    • usa
    I was wondering what voltage would turn on the florescent tubes, there's 8 of them.
    I found a tv on the curb and it worked but the lcd screen was cracked so I thought to use the back-light as a sign.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: ? on turning a tv back-light into a sighn
    its very dependent of the TV, but i have done it before! well it wasnt for a sign, it was for something that became legal this year in Colorado.
    anyway, with the one i did it with you had to have a load resistor on the 12v rail, 5vstby to the PSU on wire, the BL_ON wire and the DIM wire on the 5v rail just to upstart the backlight.
    it is hard, but not impossible.
    so, what make and model is this tv?
    Follow the white rabbit.
    • slee95
      • Jan 2014
      • 14
      • usa
      Forgot model tv it was but it was a insignia tv.
      • tron
        • Apr 2009
        • 47
        http://www.youtube.com/watch?v=gPpy-HX9wFg
        • slee95
          • Jan 2014
          • 14
          • usa
          I didn't think to keep the boards in the tv and recycled them oops There is a board in the back light and kept that. Does the back light run on ac or dc?
            It typically runs on about 1000VAC at around 50 to 60kHz.
            Did you keep the little board that drives the backlights?
            Why would you scrap the boards anyway - they are valuable!
            • multimeter
              • Jan 2011
              • 739
              • united kingdom
              i knocked one up out of an old 19"hp monitor,ripped most of the screen out.
              i use it for putting boards on,not only can you see the traces for testing without flipping the board,it shows up any cracks in the traces also.
              fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
              please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
              • slee95
                • Jan 2014
                • 14
                • usa
                The board to the tubes i have it's attached to the the tubes. There 8 tubes and on the board appears to be 8 transformers .
                  Sounds like you have the inverter board but not the power supply board to run it.
                  • slee95
                    • Jan 2014
                    • 14
                    • usa
                    How much power do I apply to the inverter board to power the lights? Could I take out the board and apply power straight to the tubes?
                    • DanPoka
                      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                      by DanPoka
                      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                      02-15-2025, 05:05 AM
                    • Comp_Pro
                      No Backlight Macbook A1990 820-01041
                      by Comp_Pro
                      Hello all,
                      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                      Tests performed:
                      There is no backlight even with a good screen.
                      Backlight IC is receiving the correct support voltages.
                      Fuse F8400 ok
                      Current sense resistor R8400 ok
                      Backlight IC is receiving 3.3V on enable pin.
                      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                      Backlight IC receiving 5V from PP5V_G3S
                      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                      05-06-2024, 10:23 PM
                    • cheebster
                      iPad Pro 12.9 5th Gen Backlight Issue
                      by cheebster
                      Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                      Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                      Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                      The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                      Anyone...
                      05-20-2025, 09:17 AM
                    • canadaboy25
                      LG Flatron 24EN33TA No Backlight When Cold
                      by canadaboy25
                      I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                      I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                      03-07-2023, 12:23 AM
                    • gabrielA7
                      Macbook pro A1706 / Backlight flex cable compatibility
                      by gabrielA7
                      Hey guys!!
                      I’ve got a question here!
                      I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
                      Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
                      Here’s what the bot told me:
                      I said to him: “I’m going to install the 821-01229-A.”
                      ChatGPT replied:
                      Understood — but before you solder or install the 821-01229-A,
                      11-11-2025, 03:26 PM
