Capacitor bank on vehicle battery
  • senz_90
    • Aug 2013
    • 328
    • Indonesia
    #41
    Re: Capacitor bank on vehicle battery
    thank you for video suggestion, I will see that.
    Originally posted by domas
    Just do the math like i did, calculate the needed energy for starting the engine, measure the current or something. Check the starter motor, or at least its fuse if it has one, to find out how powerful it is. Or please state the model of your motorcycle, somebody will be able to find it in the internets.
    Just an idea: it sounds that there is some problem with fuel/air mixture, timing, carb/injection system, compression.. I mean, if it takes long time to start the motorcycle, 4-6 starter cycles is a lot, then it might be that the battery is not a core problem, it is more a victim of a problem.
    How does it start if you charge you battery with mains charger and try to start it just instantly after that?
    That's good idea, i will find my model and data of motorcycle. I think the battery were defective because it has white chemical oxidation looks like a salt(I don't know how to call this) on battery connector, makes the connector rusty (but still strong enough and hard to remove it with screwdriver), so I just using warm water to clean it and wipe with WD40, after 2-3 months that chemical reaction appear again.
    "There is no shortcut to be successful. No pain, no gain."
    Best Regards
    Rudi
    Thank You
    • senz_90
      • Aug 2013
      • 328
      • Indonesia
      #42
      Ok. I just try to search any specifications on internet and find this, hope this give some idea for help me domas
      I can't see any pdf file to upload so please forgive me if you have to takes a time to open and read the site. the bottom site is my country site so it needed to translate. thank you very much for your attention.
      http://spinningblueorb.blogspot.com/...tails-and.html
      http://motorspec.blogspot.com/2009/0...isc-brake.html
      Best Regards
      Rudi
      Thank You
      • Logistics
        • Apr 2007
        • 721
        Typical remedy is water and baking soda. I don't know what you imagine when someone says to clean the connectors, but when I (being someone who's restored/wrenched on cars for almost 20 years) tell someone to clean their connectors, what I mean is to disconnect them, get all the corrosion (white stuff) off with a wire brush if need be, then use a battery terminal cleaner to scratch the contact surfaces of both the post and the connector... of if all you have is a steel-bristle brush or the like then use that to scratch the contact surfaces. It makes a big difference! Don't put WD-40 on the surfaces. Make sure that the GROUND cable has a very solid, very clean connection at the other end--should be the frame of the bike.
        Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
        • senz_90
          • Aug 2013
          • 328
          • Indonesia
          #44
          Thank you for your reply
          I don't have experience before so I don't know how to clean it well, btw hot water or just cold water from pipe? this knowledge is very useful. So we just clean it with wire brush and mix it with water and baking soda if hard to remove the connector?
          Best Regards
          Rudi
          Thank You
          • SeanB
            • Jun 2013
            • 41
            • South Africa
            #45
            Hot water dissolves the baking soda better, and you use a stiff brush you no longer like to brush clean the whole top of the battery. Then rinse well with cold water and wipe dry with a clean paper towel.Battery posts clean to bright lead and same with terminals and leads. When attached use a can of battery terminal protector to coat them with a thin coat to keep them from corroding again. If you do not have this then wipe with a thin coat of vaseline over the outside of the terminal, though this will attract dust like magic. While you are there check battery water level and refill if needed with distilled water. If it is a "maintenance free" battery with a sticker on top pull the sticker off and then you will find the caps under to check water level, and it is likely to be low.
            • Turtlewax
              • Dec 2013
              • 4
              There are some specialty batteries available that have high current and deep cycle but you pay a heft premium for them. Try the coiled cell lead acid batteries for best of both worlds.
              • senz_90
                • Aug 2013
                • 328
                • Indonesia
                #47
                maintenance free battery couldn't refill as I thought, I have ever did it and no luck, battery still dead.
                Hey, this circuit and cleaning trick gives me a good starter engine again, yesterday I was trying makes this caps and clean the battery (measured 12v on my meter) so I think this worth to try. and guess what? my engine didn't hard to start anymore. it just needed 1 times to start !! thank you for advicing.
                Btw how it looks when you mean thin coat? veseline like skin beauty care veseline? correct me if wrong I don't know how it looks, I want to prevent this corotion again because this is annoyed me to have to clean it every 2-3 months.
                Best Regards
                Rudi
                Thank You
                • rhomanski
                  nowhere man
                  • 5157
                  • U S of A
                  #48
                  Yes the beauty stuff. It's just petroleum jelly. It's clear and thin and melts to spread over the terminal. Anything that forms a seal will work. You just have to keep air water and everything else off the metal. Even grease will work but it's black and messy. A thin coat would mean about 1 or 2mm, the heat of the engine will make it spread out.
                  sigpicThe Sky Is Falling
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    Permatex sells a protectant for battery terminals that becomes rubbery and purple when dried. It's meant to be applied over 100% clean terminals, after they're tightened. OTOH if grease is used instead, it should be applied before assembly so it seals the gaps. The grease won't block current flow because the asperites on the posts and terminals pierce through the film.
                    • senz_90
                      • Aug 2013
                      • 328
                      • Indonesia
                      #50
                      Thank you for new knowledge !!
                      I haven't know much about engine before, this thread makes me learn many things
                      Since this circuit and cleaning tricks doing well, I'll be attach some veseline likes you'all suggest to prevent any future corrode.
                      Best Regards
                      Rudi
                      Thank You
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • techfreak9356
                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                        by techfreak9356
                        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                        09-14-2023, 11:10 PM
                        NVDC charger configuration...
                        11-05-2024, 03:28 PM
                      • ferah831208
                        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                        by ferah831208
                        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                        03-18-2025, 01:18 AM
                      • huzo
                        HP ELITE X2 1013 G3 weird battery issue
                        by huzo
                        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                        01-31-2025, 12:09 AM
