how do i test a schottky diode rectifier?
  • matthmal
    • Nov 2012
    • 306
    • Malta
    Hi Guys,
    I have a schottky diode rectifier SR1060 that looks a bit burnt. I tried to test it but I am not sure whether its good or not. The following are the results and datasheet of the component:
    1 - 2 -> 150 ohms
    2 - 1 -> 1660 ohms and keeps going up
    2 - 3 -> 1890 ohms and keeps going up
    3 - 2 -> 149
    1 - 3 -> 000
    3 - 1 -> 000
    Thanks,
    Matt
  • domas
    News Hater
    • May 2013
    • 323
    • Denmark
    Re: how do i test a schottky diode rectifier?
    if it is inside SMPS and it is soldered in the board, where pins 1 and 3 are connected by pc b traces, which is normal in lets say atx psu's, measurements are fine. If you testing it outside of board, it is dead with those resistances. But i am nearly sure it is okay.
    • matthmal
      • Nov 2012
      • 306
      • Malta
      Thanks for your reply. The component was on the board when I tested it. So it looks like we are still not 100% sure if 1 to 3 are shorted or meant to be like that.
        The diode is common Cathode and it is being used in parallel (pin1 and pin 3 are tied together and connected to one end of the transformer winding). It is always best to test the components off the board.
        • matthmal
          • Nov 2012
          • 306
          • Malta
          So should I test for the voltage and then remove from board and test the resistance?
            You will test the Diode off the board with the meter to see if it is shorted out or if it has open circuits in both directions. If it is tested out good, then you troubleshoot the circuits to find out why the circuit is not working, you will want to know if parts are good or bad first.
            • Kiriakos GR
              Banned
              • May 2012
              • 940
              • Greece
              Set the meter to Diode range.
              • Rome
                • Dec 2014
                • 18
                • Macomb
                I tested this diodes out of circuit with fluke DMM in diode range & the reading is 0.174 but I see in utube by NorCal its 0.4, so I think the 0.174 is bad
                  That Vf Voltage is depended on if it is the LOW Vf rating or not.
                  What is the P/N so you can look up the spec sheet?
                  0.174 Both ways? How about the resistance reading? I always use the Ohm mode (beside the Diode mode) also to test the semiconductor devices.
                  • Rome
                    • Dec 2014
                    • 18
                    • Macomb
                    0.174 one way reverse no reading OL from pin 2 to 1 & pin 2 to 3
                      So what is the P/N so we can verify the Vf spec?
                      To do the real test, you will need to at least do the Break down Voltage and current leakage test.
                      • Rome
                        • Dec 2014
                        • 18
                        • Macomb
                        It's FMW-24L dual diodes, thanks again budm
                          According to the spec, the Vf max at If of 5A is 0.55V Max. so at lower current the Vf will be less (Meter is has very low current drive). So to be safe you should replace it or get the new one and see what the Vf will be.
                          • Rome
                            • Dec 2014
                            • 18
                            • Macomb
                            Thanks budm
                            • cdrsteve
                              • Aug 2016
                              • 18
                              I have a similar issue with a Schottky bridge that I am trying to definitively determine if it is good or bad hopefully without sending off for a replacement/substitute for comparison. It is a D20XBS6 60V @ 20A thin in-line package unit. I am getting voltage drops in the range of .119 -.122. Attached data sheet shows Vf 0.63V max @ IF of 10A. The .119 that I am getting with a Fluke 73-III on diode test sounds a tad low. Not quite certain how to decipher readings I am getting on ohms function but they are very close to Matt's readings in all respects. Any ideas?
                                • 31283
                                volt drop changes with current.
                                • cdrsteve
                                  • Aug 2016
                                  • 18
                                  That part I do understand. I am just wondering how this device would be expected to react/perform in-circuit if I am seeing Vf's in this range doing a DMM diode test. Just how low of a Vf should one expect to see for a "low-Vf" Schottky bridge device during a DMM diode test? As you can tell - I have not had much experience dealing with these devices so be gentle !
                                    If you look at the graph of the Vf for the diode which affect by the amount of current flowing through the diode, then you need to know what the current the Fluke is putting out when you test the diode.
                                    Or you can hook 10V regulated power supply in series with 100 Ohms resistor, and the diode in forward bias mode, then measure the Vf of the diode, then measure the Vdrops on the resistor to calculate the current flowing through the diode.
                                    • cdrsteve
                                      • Aug 2016
                                      • 18
                                      Got it. Off to experiment. Thanks.
                                        Hands on experiment is one of the best way to learn.
                                        • howardc64
                                          QN75QN85BAFXZA no backlight
                                          by howardc64
                                          2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
                                          PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
                                          07-03-2025, 05:08 PM
                                        • Baste
                                          MBR3045CT and SR3045LCT Schottky diode testing help.
                                          by Baste
                                          Hello experts,
                                          Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                                          Aneng ST182 Meter.
                                          Diode mode.
                                          MBR3045CT:
                                          Diode mode
                                          Pin 2-1 - 0.150v
                                          Pin 2-3 - 0.150v ...
                                          10-21-2025, 06:14 AM
                                        • iyas132
                                          Corsair RM 750 blown schottky diode near ES1DF
                                          by iyas132
                                          Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                                          Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                                          My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                                          Can anyone help me identify the component...
                                          12-30-2024, 01:34 AM
                                        • bauto601
                                          KDM 480W PSU upgrade succes! (opinions?)
                                          by bauto601
                                          Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                          A "nice" YoungYear unit? - Badcaps
                                          The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                          12-26-2023, 03:05 PM
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
