Weight of a battery
  • barry wilkins
    • Aug 2009
    • 172
    Weight of a battery
    Does a battery increase in mass when it is charged?
    With a lead acid battery the specific gravity increases as it is charged (SG 1.1 to 1.25) .So the electrolyte must increase in mass ?
    Perhaps the the paste on the lead plates absorb the mass as the battery discharges ?
    Barry Wilkins
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Weight of a battery
    I''m not sure but I seen a video of a battery that bounced a different number of times when dropped charged and discharged.
    so i do think battery's do change mass depending on charge.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • berniedd
      • Mar 2007
      • 119
      Nope, mass didn't change. What did change was the acid became more concentrated as the charging current drove off the sulfate from the lead grids to change back to the original sulfuric acid in the electrolyte. In the process, the lead sulfate also changed back to lead. When you discharge the battery the sulfuric acid combines with the lead to form lead sulfate and hydrogen gas.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        I will give you an example with sea water.
        The sea water with low salt level works against the gravity effect because it is more water to it than salt.
        One small container which can hold 300grams of salt water it is always 300grams no matter how much salt/water ratio is in it.
        If factors as chemistry properties (activated by the charging) influences the composition of the liquid in salt which previously were attached on the battery plates this changes the gravity effect of the liquid, but not the total weight, the salt it just returned back in the water.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          At best, charging a battery will cause it to lose mass due to electrolysis or boiling/evaporation of the electrolyte.
          Discharging a battery should not cause any mass change either, unless you cause it to overheat and once again boil/evaporate the electrolyte.
          Matter cannot be destroyed unless it's converted to energy...and it should be an immense amount of energy according to Einstein.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i can tell you that a dead 8d weighs the same as a charged one.
            had a dead one on one shoulder and a fully charged one on the other.felt balanced to me!
            • cheapie
              null
              • Jul 2010
              • 849
              Anybody ever heard of the law of conservation of mass?
              • Kiriakos GR
                Banned
                • May 2012
                • 940
                • Greece
                People do not get confused , the actual title of this topic is Specific Gravity of Battery Electrolyte ..
                http://www.engineersedge.com/battery...ty_battery.htm
                My father was a Cars electrician therefore I did understand the question but I tried to simplify the answer a lot.
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • mkdj
                  by mkdj
                  Mark and model: ASUS X571
                  Tests already made:
                  - I have removed...
                  07-14-2025, 09:16 AM
                • clearchris
                  Auto Lead Acid Battery Charger
                  by clearchris
                  Hi!
                  I have a super basic schumacher 120v to 6/12v 2/5a auto battery charger. It's a metal box with a meter, switch that goes to the taps on the transformer, a rectifier attached to a sink and a thermal cutout switch. No electronics PCBs, or other circuitry.
                  When I attach the clamps to the battery, it charges properly for maybe 30 seconds, then I hear what I believe is the thermal fuse tripping, and it goes off. In a minute or so, it turns back on and the cycle repeats. This happens on 2a mode and 5a mode.
                  With no battery attached, I measure 14v DC at...
                  09-17-2023, 11:57 AM
                  FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                  https://www.ebay.com/itm/405035016711
                  I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                  I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                  04-13-2025, 08:17 PM
                • techfreak9356
                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                  by techfreak9356
                  09-14-2023, 11:10 PM
