Auto Lead Acid Battery Charger
  • clearchris
    • Dec 2013
    • 687
    Hi!
    I have a super basic schumacher 120v to 6/12v 2/5a auto battery charger. It's a metal box with a meter, switch that goes to the taps on the transformer, a rectifier attached to a sink and a thermal cutout switch. No electronics PCBs, or other circuitry.
    When I attach the clamps to the battery, it charges properly for maybe 30 seconds, then I hear what I believe is the thermal fuse tripping, and it goes off. In a minute or so, it turns back on and the cycle repeats. This happens on 2a mode and 5a mode.
    With no battery attached, I measure 14v DC at the clamps. At the secondary taps on the transformer, I measure 14v AC.
    The thermal fuse is sealed in plastic, I can't check the points without destroying it. I don't see much rust in the unit, but it's not pristine.
    Does anyone have a suggestions on what to check next? Could a bad battery cause this (suspected) overheating?
    Thanks!
  • petehall347
    • Jan 2015
    • 4427
    Re: Auto Lead Acid Battery Charger
    could be the battery .. try measuring voltage whilst its charging .
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Is that a automatic resetting circuit breaker or PTC resistor thermal fuse?
      Is the ammeter getting pegged?
      Agreed, a shorted battery could also cause this behavior and is the more likely cause. How many volts is the battery? Call it suspicious if it's less than 10 volts.
      • redwire
        • Dec 2010
        • 3910
        What model #?
        The thermal circuit breaker is usually glass so post a pic of what you've got.
        I think the charger is legit and likely being overloaded by a bad battery?
        The only other thing that causes the CB to trip is if the charger is outputting AC due to a shorted rectifier diode. Some can still sort of regulate even with a bad diode and fool a multimeter.
        I would try run it with a i.e .#1157 tail light load and see what the output looks like if you think it's the charger and not the battery.
        Schumacher Electric SE 5212A battery charger, it uses an SCR and a TL431, few transistors for control. Schematic.
        Weakness is the pellet rectifier diodes overheat esp. if someone was cranking the engine with it connected.
          ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
          Highly Integrated Narrow VDC Battery Charger for Notebook Computers
          The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
          for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
          Narrow VDC applications where the system power source is
          either the battery pack or the regulated output of the charger.
          This makes the max voltage to the system equal to the max
          battery voltage instead of the max adapter voltage. Operating
          at lower system voltage can improve...
          11-05-2024, 04:43 PM
        • flat-earther
          how to prevent a connected charger from draining battery when not charging?
          by flat-earther
          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
          So the battery is backfeeding the charger and being drained.
          How can I prevent...
          08-07-2025, 01:04 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          Bauer tool battery pack charging with a HERCULES charger modification
          The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
          Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
          05-06-2023, 12:17 PM
          Milwaukee M18 HD12.0 (12 amp hour battery pack) unbalanced failure charger refusing
          I have two Milwaukee 12 amp hours battery packs that have an issue with battery cells very unbalanced these are probably over 4 years old and been heavily used in the past but now get occasionally used heavily and when I went to use the grinder tool the battery lost battery battery power very quickly so I decided to open it up and found some battery cells voltage from 3.6 to 4.1 no wonder the battery charger was not fully charging them 3 out of 4 LEDs were on meaning that it was only 75% charged
          So I have put them on the battery testing machine to drain each battery cell down to...
          09-04-2022, 04:45 PM
