What does "RV" stand for?
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    What does "RV" on a pcb stand for? I want to say resistor voltage? I got a bunch of them on this Logitech mouse that's dead (no power, person plug wrong power brick into usb hub and fried everything that was plugged in.) When measured they only work one way and come out to 182k ohms.
    So what are they?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: What does "RV" stand for?
    One-way sounds like it's a rectifier. (AC-to-DC)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Hondaman
      • Sep 2008
      • 1060
      Is this "RU"? Are both letters capitals? Is it printed with a backwards slant? I thought there was an "RU" that was an industry group, like "CE" for the consumer electronics industry association.
      I could be wrong though.
        That's the UL component symbol
        http://en.wikipedia.org/wiki/File:UL...onent_Mark.png
        • selldoor
          Slow Learner
          • 7870
          RV is usually board designator for Varistor
          http://en.wikipedia.org/wiki/Electronic_symbol
            Can we the pictures?
            • Mad_Professor
              A Mech Warrior
              • Feb 2011
              • 1587
              sorry it took so long, picture below.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                They look like typical SMD caps, which are seen often on graphics cards.
                Arc A770 16 GB
                  the capacitor uses Cxx for the capacitor designator on this board. Rxx for the resistor, RV (Varistor for peotection) it is proably connected between Ground and the junction that needs to be protected.
                  • PeteS in CA
                    • Aug 2005
                    • 3579
                    • USA, Unsure of Planet
                    Concur with budm, probably surge protection diodes. Another possibility might be temperature compensation thermistors.
                    PeteS in CA
                    • popeye
                      • May 2011
                      • 155
                      If you are talking about the items in bottom right hand corner they are sm resisters
                        LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                        This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                        09-12-2024, 01:58 PM
                      • DXseekerMO
                        Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                        by DXseekerMO
                        Hello everyone!
                        Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                        Symptoms:
                        1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                        2) TV does not appear to turn on
                        3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                        4) "Power on" terminal on Power Supply has 3.26v
                        5) "A13V" terminals have 12.9v
                        6) Stand-by test jumper on Power Supply has 12.9V
                        7) Optical audio jack on Main Board illuminates
                        8) With stand-by...
                        06-09-2021, 12:19 AM
                      • FriedFred
                        Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
                        by FriedFred
                        Hello, everyone!
                        I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
                        I took out the memory and the battery and the SSD.
                        So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
                        After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
                        After several seconds, the fans switch-off and the board keeps powered...
                        03-08-2025, 04:45 AM
                      • Titus6
                        LG OLE65C1 Stand-By issue
                        by Titus6
                        I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                        However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                        I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                        01-31-2025, 04:01 PM
                      • Widget
                        Logitech R20 speakers - Replacing one of the speakers.
                        by Widget
                        Hi guys,
                        I have a set of Logitech R20 speakers, one of the speakers wasn't working, so I took it apart & there was no continuity or Resistance when probing the Tinsel Wires. Plus looks like the speaker was exposed to liquid as there's rust on the metal speaker frame.
                        Just in case, I removed the other speaker and installed it in place of the damaged speaker to make sure the PCB of the damaged speaker was ok & it seemed to work fine, so it looks like it's just the speaker for now.
                        Printed on the back of the Logitech speaker is;
                        LOGITECH...
                        05-29-2024, 07:07 AM
