How do I make this AC fan run?
  • Behemot
    • 4845
    • CZ
    I got this huge fan from outter part of a splitted air conditioner unit. It is 60W mains fan with four wires (orange, red, blue, black)+ground.
    The problem is, I don't know how to make it run without the AC, just on mains. There is some schematic on it, I think it actually needs the capacitor to create phase difference (I can go and get it, that is no problem) but still, where do I connect what? I mean, for one phase (230 V) I got only neutral and phase (plus ground) and here are four connection points.
    I can experiment with safety balast (100 W lightbulb in series), in fact, I already did and failed to make it spin…
  • Mrx3750
    • Jul 2013
    • 311
    Re: How do I make this AC fan run?
    Three phase motor?
    • Behemot
      • 4845
      • CZ
      That would be 380 V labeled, no? This is labeled as 220 V which implies single phase if I am not mistaken…or not?
      This says single-phase (different power but basically the same motor).
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        where i live 220v is 2 phase hot to hot
        Follow the white rabbit.
        • Behemot
          • 4845
          • CZ
          It is phase to neutral here, 400 V 3-phase combined (triangle or star)
          I think I got it, there was another schematic hidden in the AC. The red and orange are purely for the capacitor, that leaves black and blue for phase and neutral.
          Works like charm now
          ADD// This is some ass kicking airflow! Now I just need to wire some grill on that as I would not want to stick anything into this thing while running
            Just Google that model number.
            This is what I get by searching using the model number on the fan as shown in the picture. See here:
            See page spec used in CSS-70H3A-W**ASA pgae77, 78. Hook up Diagram page 83
            • Behemot
              • 4845
              • CZ
              I did and found nothing, but anyway, I made it running already…in process of making grill cover for the fan now.
              Seems that the horrible thing has airflow of ~4000-5000 m^3/h. I think I'll ad some capacitor in series in time
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8696
                A bit late now but this seems like it's a typical induction motor, and the capacitor is necessary to get it spinning (and generate some torque).
                • Behemot
                  • 4845
                  • CZ
                  I thought it's there to bring the PF closer to 1…
                    • Jul 2011
                    • 6033
                    One real quick think if this motor in not being used in an AC unit and you are using as a fan you need to check the ampage on the black wire and it should not be higher than .70 amps or you will over heat this motor real fast
                    In a past life I use to be AC tech
                    • Behemot
                      • 4845
                      • CZ
                      I don't know but it is making incredible airflow, should not it be able to keep itself cool pretty easily? It is already mounted and plugged in…I can cut part of the original insulation and measure the wires with my clamp meter though. Or I may use wattmeter. Let's just see how noisy it is, I want to sleep while running it not far away, if it will be too much, I'll add an X capacitor in series to bring the speed down which will also limit the current little bit.
                        The capacitor is used to start and run the motor, to provide a phase shift, not for power factor. Power factor would have cap across live and neutral.
                          It is rated at 150W, fixed speed of 850 +/-20 RPM.
                          http://www.smartclima.com/air-conditioner-fan-motor.htm
                          • Behemot
                            • 4845
                            • CZ
                            Yes?
                            • redwire
                              • 3906
                              As you suggest, you can put a capacitor in series with the mains (not to be confused with the 4uF start winding phase-shift capacitor) to slow the fan down. I don't recommend it because you can get resonance with the motor and mains cap sometimes, and it also is pretty sparky on the power switch.
                              Chinese fans, since copper is expensive, will use the fewest turns on the windings...
                              • Behemot
                                • 4845
                                • CZ
                                I have actually cracked it open, seemed OK to me. I have seen much smaller 150W+ motors.
                                • Behemot
                                  • 4845
                                  • CZ
                                  I measured the current, it takes slightly over 0,8 A, meter shows 200 W or so. The motor does get somewhat hot when I turn it down and is only slightly warm under operation so I think it gets hot inside and cools itself down from outside when spinning. I think it also moves unneccesarilly much air for my use.
                                  What capacitance do you think I should use in series to reduce to aprox. 2/3 the speed?
                                  • redwire
                                    • 3906
                                    To slow down the fan using a series capacitor, it's really hard without knowing the reactance and even then some fans run the flux density really high.
                                    I guess 8-10uF as a starting point, at mains voltage.
                                    I would use a bigger motor starting-cap, like the oil-can types.
                                    It's important that they have a (internal) bleeder resistor as this size cap can bite.
                                    • Behemot
                                      • 4845
                                      • CZ
                                      Man that's huge Bigger starting cap, well, how much bigger?
                                      ADD// what about making the startup cap smaller? That may reduce the phase shift thus run it slower, no?
                                      ADD2// so using 2,2 uF as a startup cap makes it run slower enough…takes 190 watts than, same current but PF drops to 0,91
                                      • Behemot
                                        • 4845
                                        • CZ
                                        There is 50 °C on top of the motor while operational and 60 °C while trned off. So even if there was 65-70 °C inside when running, I don't about you, but I call that OK for 24/7 operation.
                                        • chopduel
                                          Bad mains power causing TV malfunctions?
                                          by chopduel
                                          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                                          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                                          • TV would randomly turn off then back on.
                                          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                                          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                                          12-29-2024, 03:20 AM
                                        • SavaBogdan
                                          Help disabling a vcore phase on a MSI X570 Carbon - I have schematics + boardview
                                          by SavaBogdan
                                          Hello.
                                          Does anyone have any experience with disabling a power phase on the CPU vrm?
                                          The controller is IR35201 6+2 phases. It only uses 5 phases and the pins for pwm and feedback on the 6'th phase are not populated (no traces).
                                          I got the board with a burned mosfet which I removed along with a part of the pcb. I dremelled away the short as best I could and the board started up fine without the vrm heatsink.
                                          I then put some sealant and left it for two days to completely dry. I suspect the pressure from the thermal pads on the heatsink compressed the layers so when I started...
                                          10-21-2022, 10:05 AM
                                        • Axis937
                                          BQ 727 Chip 2.4V at Phase
                                          by Axis937
                                          HI folks 1 question on ablout BQ 727 IC. I believe that it is also meant to charge the battery based on the proximity to the battery pins. I have a strong feeling that the battery is dead but i will look at it later. My question is VCC on BQ is receiving the ADP voltage of 19V. However PHASE and HiDRV on BQ is only pushing out about 2.4V with or without battery attached. That 2.4 V is heading to the gate of the charging mosfet. Source is also pushing out the same 2.4V. Finally the battery voltage pin is receiving 2.2V. Do you see this as a issue or no issue. Battery is likely faulty as well as...
                                          09-24-2024, 08:49 AM
                                        • aysat
                                          MSI GTX 970 Golden Edition phase restore problem
                                          by aysat
                                          I have the weirdest problem of a core phase restoring. I have replaced the doubler, driver and the drmos and checked all the resistors around the main inductor but still there is no switching on that phase. I even swapped these phase with another but still no go. I checked around the voltage regulator ncp81174 but could not find a culprit. i have board scheme but that did not help either. got oscillator and everything but it drives me crazy.
                                          Has anyone observed such a behavior before ? I am out of ideas. any help would be appreciated. i will post some...
                                          03-03-2023, 01:09 AM
                                        • vincentedel
                                          Samsung SyncMaster 740n Phase Control Issue
                                          by vincentedel
                                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                          04-22-2025, 12:33 AM
