How do I make this AC fan run?
  • redwire
    • Dec 2010
    • 3912
    Re: How do I make this AC fan run?
    You just want to lower the voltage for the main winding, but not so much the start-winding takes over, doing all the work.
    A series capacitor (with the main winding) can give lower voltage to the motor. But it's a big ugly cap found in larger induction motors start caps, which I am saying use one here as a series cap (not for starting).
    You don't want the start-winding doing all the work. I didn't mean change the start cap from the factory 4uF, although that value is "tuned" to the motor's operating speed and at lower speeds the larger phase shift I think needs a bit bigger cap? For best efficiency.
    An old transformer connected as an autotransformer would also work. Say giving 195VAC (using a 220V-25VAC sec. xfmr). This is what I use (or old UPS autotransformers) , or a variac. A 10% drop in voltage gives much more drop in speed.
    I hope this gives you some ideas but I am not an expert. It's great you are keeping an eye on PF and current draw, as you can slow the motor down but make a ton of heat if it's done poorly.
    • Behemot
      • 4845
      • CZ
      The problem is that capacitor in series seems to have to counter the phase shift of start capacitor and than move it further so it needs to be really huge. I think it is really wrong way to have the two battle themselves. And for me it means looking for huge capacitors. I may have some at home from old CCLF light, there may also be the transformer part. But than, you are right, maybe adding induction is more the way to go. I got passive PFC transformer here so if I just strip the cap from it and connect it, it may somewhat help.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8707
        Some of these induction motors you really can't slow down...well you can but you have to change the line frequency and I think that sort of is out of the question. Induction motors are more related to stepper motors than regular motors, if that makes it clear why it's frequency dependent.
        • Behemot
          • 4845
          • CZ
          Don't think it is so complicated. Every AC drives the speed from 0 to max so possibiltiy of driving it guaranteed, now the question is how…
            Well, the motor has to reach speed -- and you'll probably be able to get it to slow down at really low voltages, but it won't have any significant torque.
            • Behemot
              • 4845
              • CZ
              #26
              The problem is with getting voltage down, resistor is easy and will not interfere with the startup capacitor phase shift, but will also burn insane amount of power.
                Variac or VFD is probably the only way. You can get some low power VFDs for cheap, or if you don't need much power (10~15W max) you can build one using a timer circuit, MOSFETs and a mains transformer.
                • Behemot
                  • 4845
                  • CZ
                  #28
                  What about diac-triac regulator? It has some strange V-A characteristic but I think it would not interfere with phase shift, at least not much.
                  ADD// Seems that asynchronnous motors do not like triac reguation much. So only option for me is to lower amplitude or change frequency. So transformer with 150-170 V output?
                  ADD2// I got some old transformer with no use here, 3x5x6 cm iron core. Do you think it's worth trying to change the windings to 23:16 ratio?
                  • chopduel
                    Bad mains power causing TV malfunctions?
                    by chopduel
                    I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
                    Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
                    • TV would randomly turn off then back on.
                    • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
                    • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
                    12-29-2024, 03:20 AM
                  • SavaBogdan
                    Help disabling a vcore phase on a MSI X570 Carbon - I have schematics + boardview
                    by SavaBogdan
                    Hello.
                    Does anyone have any experience with disabling a power phase on the CPU vrm?
                    The controller is IR35201 6+2 phases. It only uses 5 phases and the pins for pwm and feedback on the 6'th phase are not populated (no traces).
                    I got the board with a burned mosfet which I removed along with a part of the pcb. I dremelled away the short as best I could and the board started up fine without the vrm heatsink.
                    I then put some sealant and left it for two days to completely dry. I suspect the pressure from the thermal pads on the heatsink compressed the layers so when I started...
                    10-21-2022, 10:05 AM
                  • Axis937
                    BQ 727 Chip 2.4V at Phase
                    by Axis937
                    HI folks 1 question on ablout BQ 727 IC. I believe that it is also meant to charge the battery based on the proximity to the battery pins. I have a strong feeling that the battery is dead but i will look at it later. My question is VCC on BQ is receiving the ADP voltage of 19V. However PHASE and HiDRV on BQ is only pushing out about 2.4V with or without battery attached. That 2.4 V is heading to the gate of the charging mosfet. Source is also pushing out the same 2.4V. Finally the battery voltage pin is receiving 2.2V. Do you see this as a issue or no issue. Battery is likely faulty as well as...
                    09-24-2024, 08:49 AM
                  • aysat
                    MSI GTX 970 Golden Edition phase restore problem
                    by aysat
                    I have the weirdest problem of a core phase restoring. I have replaced the doubler, driver and the drmos and checked all the resistors around the main inductor but still there is no switching on that phase. I even swapped these phase with another but still no go. I checked around the voltage regulator ncp81174 but could not find a culprit. i have board scheme but that did not help either. got oscillator and everything but it drives me crazy.
                    Has anyone observed such a behavior before ? I am out of ideas. any help would be appreciated. i will post some...
                    03-03-2023, 01:09 AM
                  • vincentedel
                    Samsung SyncMaster 740n Phase Control Issue
                    by vincentedel
                    I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                    I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                    04-22-2025, 12:33 AM
