a bent cap
  • egyteam
    • Jul 2005
    • 8
    a bent cap
    I got my new mobo but I found a cap is bent, it is not settled 90 degre on the mobo PCB, so this can cause problems ?
  • MD Willington
    • Sep 2004
    • 702
    Re: a bent cap
    As long as the solder joint is complete it will be fine.
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • Tom41
      • Oct 2005
      • 338
      • England
      Re: a bent cap
      The cap doesn't look bulged, but it possibly has blown out the bung at the bottom - hence the weird angle. Look closely for signs of failure, like spilling electrolyte. They look like Chemi-con caps though, so shouldn't fail prematurely.
      Like MD Willington said, as long as the cap is correctly soldered to the motherboard, it will work properly. I've seen recap jobs where the caps are pointing in all directions, yet the solder joints are fine and the board runs perfectly. The only problem you may encounter is when putting memory into the slot - the cap that's pointing at an angle will be slightly 'weaker', and could snap off if hit hard.
      You know there's something wrong when you open your PC and it has vented Rubycons...
      • egyteam
        • Jul 2005
        • 8
        Re: a bent cap
        can I gently puch it to the right position or it can be break while puching it ?
        • gonzo0815
          • Feb 2006
          • 1600
          Re: a bent cap
          Hm, gently may be, but at a point, you will harm the wirebonding in the cap itself. So i would only chek, if the wires are left fixed in the cap or may be somone has disrupt them.
          If anything else is fine, i would not care abouth it.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            Re: a bent cap
            probably was bumped .
            if it makes you feel better push it back into place.wont hurt it either way.
            • Spyke
              • Aug 2006
              • 13
              Re: a bent cap
              I tend to bend all slightly bent over caps straight up obsessively. (where pin alignment allows one to do so of course)
              Harmless. Often they do get bumped during shipment.
              • egyteam
                • Jul 2005
                • 8
                Re: a bent cap
                i tried to puch it back, but it can't be puched, it seems like it is strong at its position, I don't want to force it
                • Lance Thornton
                  • Jan 2005
                  • 84
                  Re: a bent cap
                  Leave it alone, it will be fine. Just follow what others suggested. If the bottom bung is blown or ruptured, it's failing or has failed, and needs to be replaced. If the solder joints on the bottom of the motherboard are fine, then it was just a fluke at the factory.
                  • 999999999
                    • Sep 2006
                    • 774
                    Re: a bent cap
                    There are two different, possible situations with a bent cap.
                    1) It wasn't sitting flush to the board when soldered in and by sticking up, it was more susceptible to being bent, or might have even had slightly bent leads originally. This is not a problem.
                    2) It was sitting flush originally and bumped hard enough that the terminals have pulled away from the foil. This is a potential problem, if not immediately then after some time the cap may have degraded function.
                    It is probably #1, and I'd go ahead and use the board, taking a wait-n-see approach but if you're REALLY curious, you could always take the cap off and examine the bottom to see if the larger portion of the terminal(s) is now exposed.
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • Cerberuska
                      Mobo MSI B550-A PRO password popup
                      by Cerberuska
                      Hello guys,
                      I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                      BIOS I updated to last one.
                      any suggestions?
                      And same thing for two different 5600G, and yes, MoBo supposed to support it.
                      Thank you...
                      11-10-2024, 01:23 PM
                    • mrsith
                      Dell G3 17 3779 - no display after mobo replacement
                      by mrsith
                      Hi guys,
                      I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                      Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                      04-30-2023, 05:11 AM
                    • spidertnt
                      820-02443 14" M1 angle sensor / keyboard / trackpad not working
                      by spidertnt
                      FYI.
                      I just had a 14" M1 MacBook Pro with liquid damage very small pretty much only angle sensor sustained any corrosion or damage.
                      But both keyboard and trackpad will not work at all ! Screen would flicker on and off all the time.
                      I ended up re-building the traces on the angle sensor cable using very small copper wire... this fixed both the flickering and the keyboard / trackpad.
                      I'm like WTF does the angle sensor have to do with keyboard / trackpad ?
                      04-29-2023, 11:03 AM
                    • Ibod
                      Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                      by Ibod
                      HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                      With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                      Not sure where to go from here ?
                      Is the PSU at fault or is the mobo causing the problem
                      Look forward to any help :-)
                      If I plug the 24...
                      02-08-2023, 11:00 AM
