Why did they tweak the voltage?
  • larrymoencurly
    • Oct 2004
    • 960
    I have several USB 3.0 to SATA adapters based on the ASMedia ASM1051 bridge chip, and on some of the boards the LM1117 ADJ type voltage regulator is tweaked with the addition of a couple of resistors to raise its output from its normal 1.25V to 1.30-1.33V. The resistors were tacked on to the pins; the boards weren't laid out for them:
    There doesn't seem to be any relationship between the dates of the boards and chips and whether the voltage was tweaked, but why would a digital circuit like this need its supply voltage tweaked?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Why did they tweak the voltage?
    Ouch. I've seen bad but not quite that bad of "last minute tweaking."
    sigpic
    (Insert witty quote here)
      It sounds like bad circuits design that it cannot handle 5% voltage tolerance.
      • mariushm
        • May 2011
        • 3799
        The description says the IC has a 3.3v to 1.2v regulator.
        Maybe they accidentally wired 1.25v to that pin instead of 3.3v... which is obviously not enough, but 1.3v could be just enough to cover the ldo's voltage drop (100mV sounds reasonable for 100-200mA consumption)
        I can't really think of something else... yeah, it doesn't look nice.
        • larrymoencurly
          • Oct 2004
          • 960
          Each of these boards also has an "AMS1117 3.3" regulator, next to the regulator marked AMS1117 ADJ. I tried shorting the 1200 ohm resistor of the latter to ground, and the voltage dropped to 1.25V, and the hard drive worked fine with it that way.
          At least this construction doesn't look as bad as what I saw on a board where somebody blobbed solder on one copper pad and somehow pulled hot solder up and over to a pad about 3-4mm away -- solder snot jumper wire!
          • rddube
            Lenovo L490 Ram voltage circuit malfunction
            by rddube
            Hello friends,
            Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
            I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
            07-15-2025, 04:41 PM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
            Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
            by sam_sam_sam
            I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
            The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
            Now...
            06-09-2024, 10:57 AM
            ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
            3+1 Voltage Regulator for IMVP-7/VR12 CPUs
            Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
            core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
            configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
            serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
            Based on Intersil's Robust Ripple Regulator...
            11-05-2024, 03:24 PM
