simple power help.
  • WeStSiDePLaYa
    • Mar 2006
    • 63
    simple power help.
    ok this is a very noobish question, but i was wondering what the best way to connect a switch like this. here is my idea. anyone else have any better ideas? the plan is to be able to switch all of my fans from 12v to 5v via a pci bracket switch. the draw of all fans combined will be about 5amps.
    Specs
    DFI AM2 LANPARTY UT NF590 SLI-M2R/G
    X2 3800+EE AM2
    2x1GB OCZ PC2-6400 Platinum XTC
    XFX 7900GS
    Maxtor 6L250S0
    Maxtor 6V300F0
    Western Digital WD2500JS
    Mushkin HP-550(Cap/Filter Modded)
    Cooling
    Swiftech Apogee
    Swiftech MCW-60
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
  • tiresias
    • Feb 2006
    • 489
    Re: simple power help.
    Hang on a minute - why does the common ground wire go to the switch?
    All you have to do is to connect the ground directly to the fan(s) in question, connect a line from the 12vdc and 5vdc to either pole of the SPDT switch and the center pin (assuming a standard config) wired to the positive terminal of your fans.
    That way the switch will close either the circuit involving 12v input or that for 5v, depending on its position.
    Or is the heat messing me up so I'm missing something?
    Edit: cleared a silly typo.
    • Rainbow
      • Aug 2005
      • 1375
      This is the right way. And make sure that the switch can never ever connect both ends together!
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yea, as Rainbow said... I'd be very careful in selecting a switch that has a long "gap" or whatever you wanna call it between the two points..
        Also there is no short circuit fuse between 5v and 12v so I would add a (in your case 5A) fuse for protection....
        • Galvanized
          • Mar 2006
          • 468
          tiresias is spot on with the ground wire comment. Just use the 5 & 12 to a SPDT switch.
          Never thought of fusing inorder to protect the PSU, good point Per. That's something I'll remember.
          PlaYa, go to silentpcreview.com, on the left you'll find fans&controlls. They show a 5 or 12 controll using a DPDT switch.(Note: All ATX PSU grounds are common). Radio Shack wants $5 for a switch. allelectronics.com or BGMicro they are $1.25 each or 10 for $10. BGMicro has a very good selection of ballasts,atm, if your interested. allelectronics carries some good cheap heat shrink.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            It's generally completely unnecessary but a little added protection never hurts...
            Plus that if you run fans on +7v (Red and Yellow on Molex connectors) you are without shortcircuit protection, therefore if you make a switch like this it is good to have a fuse, if you make an error in the assembly, the switch fails ot a wire just comes loose and shorts it out...
            And also as I found out it would be good to have a fuse on the fans themselves, as I totally fried the fan voltage controller (according to CPU die temp) on a new Asus board; a strand of the +12v cable came loose and touched ground...
            • tiresias
              • Feb 2006
              • 489
              I guess that could be the case with some nasty generic PSUs - but surely in a decent unit with overload protection, it would trip due to overcurrent (essentially a short) on the 12vdc out?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Maybe, this is what I have read in every guide describing the +7v mod, so not from personal experience...
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  why not just use a pot/rheostat on the 12v. imho the sweet spot is between 12v and 5v
                  • tiresias
                    • Feb 2006
                    • 489
                    Indeed - or even use the PWM-controlled motherboard fan headers together with some software such as Speedfan... of course, this only is an option if your motherboard is capable in that respect. And if you don't have more fans than headers, of course.
                    • Rainbow
                      • Aug 2005
                      • 1375
                      Some PSUs don't like this - they will not turn on at all or the protection turns it off after a while. And I don't like it too.
                      • Galvanized
                        • Mar 2006
                        • 468
                        PLaYa, 12Vx5A=60W. That is alot of cfm and wattage.
                        If you have an open 5.25" bay, a Sunbeam Rheobus will handle 20W per each of it's four channels. I have two in use, they are linear (not PWM) and cause no fan clicking. They cost $10 here State side. Guys in the UK don't have'em. The only draw back is the uber-bright 5mm LEDs. These can be cured with several coats of dark nail polish. SPCR has a good review of it. The LEDs change from red to blue at about 7V. A buddy gave me one he burnt up. The Molex can be installed up-side-down if one is not careful. The Molex is opposite what most opticals are.
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          dont rely on the ocp to save your stuff if you get a short.
                          the light gauge wire on fans wont pull enough to trip the psu.
                          short=smoke and fire!
                          • WeStSiDePLaYa
                            • Mar 2006
                            • 63
                            got the figured out a few minutes after i posted it.
                            and i didnt have the cash for fan controllers, so i used a pci bracket switch from a ccfl inverter.
                            and yes i know im using alot of power for my fans. i got some big fans, and lots of 80mm.
                            but this is running off a secondary psu.
                            and to the person who suggest running them off the mobo headers. are you f'ing nuts?! please dont ever recomemend that to others again. running the fans i am using off a header will fry them. i even stated i had high draw.
                            Specs
                            X2 3800+EE AM2
                            XFX 7900GS
                            Maxtor 6L250S0
                            Maxtor 6V300F0
                            Cooling
                            Swiftech Apogee
                            Swiftech MCW-60
                            Swiftech MCP-600
                              Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                              This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-06-2024, 05:30 AM
                            • JayPoorJay
                              Hot Water Rad - A Few ECU Fans and a Timer Switch
                              by JayPoorJay
                              Good Afternoon, Good People.
                              I know this will be an elementary little project for most if not all of you, but I thought I would write a post and get put on track, rather than bumbling my way through it with all kinds of trials and errors.
                              I REALLY would appreciate y'alls help.
                              This is the problem - My wife and I purchased a big ol Victorian/Colonial House in NYC two years ago. The kitchen is surrounded on 3 sides by exterior walls, there is also a 1/4 of the kitchen floor (ceramic tiles) that has a crawl space underneath, and the kitchen gets FREEZING cold...
                              10-29-2024, 12:54 PM
                            • emil_t
                              RTX3090 working fine but fans not spinning
                              by emil_t
                              Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                              04-12-2024, 06:54 AM
                            • grimacelord
                              NEC TurboExpress On/Off Power Switch Replacement Help
                              by grimacelord
                              I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                              I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                              I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                              11-09-2023, 09:49 AM
                            • SluggerB
                              Help making a switch work the opposite way with a relay
                              by SluggerB
                              I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                              I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                              It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                              02-07-2025, 07:57 PM
