dead mb
  • hfl12
    • May 2011
    • 12
    dead mb
    Guys,
    I have a question for you. Let say I have a motherboard that is completely dead. There is no sign of bad caps,burned diodes or cables. I try to remove the cmos battery, hold down power button, do bios recovery, look at bios log which shows no known problem, change different rams and mouth pad. Try everything that is possible without doing hardware soldering. I find that the power jack is good with a multimeter. Also, there is voltage on the mb. I have seen this type of problem in the past, and most of the time I replace the mb. However, I have seen motherboard manufactures and some experts bring the dead mb back to life. Alright, maybe they solder a new bios chip or some other chips? But how did they know which chip is corrupted? is there an equipment that can look for every single chip on the board for corruption? What do you do in this case? Thanks.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: dead mb
    I'm guessing this is a laptop because you said power jack.
    What kind of laptop is it?
      Re: dead mb
      They have what its called 'bed of nails' for board testing which is ran by computer that is programmed to look at the reading from each test points on the board.
      http://en.wikipedia.org/wiki/In-circuit_test
      • hfl12
        • May 2011
        • 12
        Re: dead mb
        I have had a couples in the past that I don't remember the name. The one most recently was the asus g73j. Another one was a desktop emachine, this one turns on but stuck at post.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5044
          • US
          Re: dead mb
          is any hard drive hooked up?
          • hfl12
            • May 2011
            • 12
            Re: dead mb
            Yes, but your question surprised me. In general, mb should boot up fine without anything but a processor connected to them. Maybe, there is something that I don't know?
            • 999999999
              • Sep 2006
              • 774
              Re: dead mb
              It will need processor, at least one memory module and possibly that in a certain slot, "sometimes" a viable CMOS battery, and either integrated video or a video card.
              What exactly does it do? Does it turn the PSU on and the fans spin or nothing? Does it generate any beep codes, or does it beep with no memory installed?
              Usually when a non-manufacturer brings a board back it is because they had a strong suspicion of what the problem was from past history of board failures or subcomponent problems, otherwise people with the skills and the test equipment to do the work, are worth more in the time to do the work than the board would be worth if working again so you might say those that are successful are often just lucky and bragging when there is no evidence to go on and all the more common problems were ruled out.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5044
                • US
                Re: dead mb
                actually my implication was about the one you previously said that 'booted up but froze during post'. Sometimes bad hard drives will cause a bios freeze
                • hfl12
                  • May 2011
                  • 12
                  Re: dead mb
                  I see. I changed everything. Memory, hd, cmos batter, psu, graphic card, everything except processor.
                  • hfl12
                    • May 2011
                    • 12
                    Re: dead mb
                    @999999999
                    Good point.
                    Like I said, there is nothing. Completely dead- no beep code. You mentioned non-manufacturer,do you know what a manufacturer would do in this case? I guess they have a special equipment for this board?
                    • 999999999
                      • Sep 2006
                      • 774
                      Re: dead mb
                      ^ Manufacturers have to have equipment set up to test boards when they're made, and sent in for repair. I've read a few articles over the years that showed pictures of manufacturer employees doing testing but unfortunately I don't remember where I saw them.
                      • hfl12
                        • May 2011
                        • 12
                        Re: dead mb
                        That's cool. Thanks. I'm surprised topcat hasn't said anything.
                          master hoarder
                          • May 2008
                          • 12175
                          Re: dead mb
                          Could be a Northbridge/Southbridge or GPU (if integrated) BGA issue. A reflow might bring it back. When in doubt, do a full board reflow in the oven.
                          • Spitz
                            • Oct 2010
                            • 95
                            Re: dead mb
                            Originally posted by hfl12
                            Guys,
                            You need a bios post board to show what is happening before the video card is started. It shows the numbers as things progress and the numbers tell how far the cpu and chipsets got. I have used them many times for desktop boards but have not had any that work on laptops. Here is what i found:
                            http://www.amazon.com/laptop-motherb...ef=pd_sim_pc_5
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              Re: dead mb
                              @999999999
                              Good point.
                              Has the PSU been tested and confirmed working? If it is, check to see of the power switch is working correctly.
                              Muh-soggy-knee
                              • hfl12
                                • May 2011
                                • 12
                                Re: dead mb
                                thanks, I have never tried try one one of those. But I mostly work on laptops.
                                • hfl12
                                  • May 2011
                                  • 12
                                  Re: dead mb
                                  I work mostly on laptops. Sometimes, I test the connection with a multimeter on the mb.
                                  • double_DD
                                    How can I be sure that my EC chip is dead?
                                    by double_DD
                                    As the title suggests, how can I be sure that my EC chip is really dead?
                                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                    03-12-2025, 07:47 AM
                                  • disorder
                                    ps5 edm-033 dead after hdmi/usb ports destroyed
                                    by disorder
                                    hello guys,
                                    i need help to repair a edm-033 ps2
                                    history : as always hdmi port and usb ports destroyed after unplugged
                                    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                    so i changed it
                                    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                    i don't see any projection of liquid metal on pcb.
                                    01-14-2025, 12:48 PM
                                  • zunasthegreat
                                    Chieftec GPS-450-AA with dead 20N60C3
                                    by zunasthegreat
                                    Hello everyone hope all doing well!
                                    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                    09-01-2024, 07:12 PM
                                  • Beton
                                    Finding a dead short component
                                    by Beton
                                    Hi guys!
                                    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                    I have a bench PSU and if I try to inject voltage the voltage...
                                    12-10-2021, 01:05 PM
                                  • FiguringITout
                                    MSI Raider GE75 - Not posting, probable dead CPU
                                    by FiguringITout
                                    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                    07-25-2024, 07:27 AM
