Soldering Station
  • ShadowReaper
    • Aug 2008
    • 6
    Soldering Station
    I am thinking of buying the Hakko FX888 soldering station http://www.hakko.com/english/products/hakko_fx888.html
    What is your opinion about it?
    The problem is that the one I found requires input voltage of 110V, but I am in Europe and the input voltage is 220V...
    If I buy a transformer will it be fine?
  • mariushm
    • May 2011
    • 3799
    Re: Soldering Station
    Hakko stations are good, expensive but good.
    You would have to get a 230v to 110v converter capable of about 100-150 watts.
    Like these:
    http://www.amazon.co.uk/240v-120v-St...ref=pd_cp_ce_3
    http://www.amazon.co.uk/500-Watt-Tra...358063&sr=1-23
    The ones in the links above are with UK style plug but you can use 1-2 euro adapters to convert it to the regular european plug... or you could just change the cable.
    I guess you could also just change the transformer but these don't use 5$ transformers and a converter may be more useful for other things as well.
    • popeye
      • May 2011
      • 155
      check out ebay they do 220v version
      • ShadowReaper
        • Aug 2008
        • 6
        Sure they do, but it's about $100+ more expensive
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          How much does a 100 watt transformer cost?
          You'll need one about that big for a safety margin.
          Mann-Made Global Warming.
          - Dr Seuss
          • ShadowReaper
            • Aug 2008
            • 6
            There are transformers like this
            which cost about 12-13 $
            and like this:
            which cost about 25 $, both rated at 100w
            What's the difference between those two?
            • mariushm
              • May 2011
              • 3799
              The first one can do about 45-60 watts... which is kinda small for your needs.
              Here's one like the first picture but for 100 watts:
              http://www.amazon.co.uk/gp/product/B...pf_rd_i=468294
              • ShadowReaper
                • Aug 2008
                • 6
                In the item description of the first states that it is for 100w...
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  On AC VA usually does not equal Watts.
                  Must adjust for the Power Factor [PF] of the device.
                  The watts will always be lower than or equal to the volt-amperes.
                  To be equal the PF would have to be 1, which isn't going to happen with a cheap transformer.
                  You need one that is at least 100 -watts-.
                  - Dr Seuss
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    eevblog has a discussion with pics on this very topic
                    http://www.eevblog.com/forum/index.php?topic=4137.0
                    --- begin sig file ---
                    --- end sig file ---
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5012
                      • New Zealand
                      I wouldn't bother with the stepdown transformer, unless you really need to save money and it does help you get the thing cheaper.
                      Getting the correct voltage for your country is a good idea, because it's possible that you (or more likely someone else) will one day forget to use the transformer, and plug the iron straight into the wrong voltage, at which point the money you saved will have been for nothing.
                      Shop around, don't just look on eBay.
                      It took me a lot of looking before I bought my 230v Proxxon tool eventually from a shop in Singapore, which turned out to be the cheapest overall and most convenient. I could probably have stuffed around with a stepdown transformer for a 110v eBay deal but in the end I decided it just made sense to get the right one to start with.
                      -David VanHorn
                      • t4796
                        Fender Mustang non valve guitar amp - owner connected 110v amp to 220v.
                        by t4796
                        I recently picked up this amp as not working. I took it as is. Didn't notice until I got home it had foreign power plug and was marked 110v and our local voltage is 220v so then I knew what had happened to it.
                        Opened it up and was able to find the schematic online. In the schematic I have uploaded I have erased the parts for 220v operation to make it easier for me to visualise however I have since added the two additional diodes and remove the wire link from the power supply so I can test it easier on 220v
                        From the FAQ I learnt that for 110v the power...
                        10-25-2024, 06:59 PM
                        07-01-2024, 06:34 AM
                      • chth96
                        What soldering station should I purchase for 900M-TJ-I tip?
                        by chth96
                        hello.
                        A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                        https://ko.aliexpress.com/item/4001275635593.html
                        Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                        Any reply would be appreciated.
                        11-24-2023, 05:08 PM
                      • caprider
                        Recommendations of quality soldering station and (separate) hot air station
                        by caprider
                        Hey,
                        I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                        I now have a TS100 and some soldering irons and looking for some better tools.
                        1. Soldering station, budget around 200-240€
                        JBC BT-2BWA seems to be a good product in the budget.
                        2. Hot air station, budget around 200€
                        Up to now I've found ATTEN ST-862D to be a good option....
                        01-15-2022, 02:05 AM
                      • Peter_1402
                        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                        by Peter_1402
                        Hi Everyone,
                        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                        1. Soldering iron works great
                        2. There is a burnt mark on the hot air gun handle.
                        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                        Reed switch tested ok with a magnet.
                        From the above test, I can conclude...
                        07-12-2025, 11:50 AM
