LCD Clock digit faded and partly missing
  • freakytiki4u
    Coolest Member
    • Aug 2009
    • 130
    Anyone know why this happens and how to fix it or where I may send the clock to be fixed? The #24 is what you see and part of the 2 is missing. Everything else works perfectly except that digit. New batteries are installed. Thank you sincerely for any reply and info
  • freakytiki4u
    Coolest Member
    • Aug 2009
    • 130
    Re: LCD Clock digit faded and partly missing
    I decided to just replace the clock but ty for looking
    • b700029
      Banned
      • Sep 2010
      • 640
      Good decision, that is caused by bad ITO which cannot be easily fixed.
      • kc8adu
        • Nov 2003
        • 8829
        • U.S.A!
        or a fouled zebra strip.clean it and the display edge as well as the board contact area.
        i used an alcohol prep on a fluke 73 a while back.was missing segments and faded looking.looks new now.
        • fichamba
          MBAir 13” A1466 missing SPI clock
          by fichamba
          Hello everybody:
          I have an A1466 (MoBo 820-00165-A) which is driving me crazy.
          It has all voltages, everything seems OK. It starts after connecting the Apple charger (fan spins normally; maybe a bit later than in a working board that I have side by side). The only (!!!) missing signal is the SPI clock.
          I have measured at pin 6 of U6100 (the SPI), and I have nothing in the scope. Neither in the data in/out pints I have data train in the scope (just a little bit sometimes).
          The working board is showing me fixed clock pulse at pin 6 of its SPI. I'm crazy about this....
          02-16-2022, 09:16 AM
        • shelby5041
          clock radio / radio lifespan?
          by shelby5041
          hi
          ive got a modern digital clock radio approx 15yrs old
          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
          it uses very little power just a few watts i would imagine that may have something...
          09-14-2024, 03:30 AM
        • ugamazing
          820-02020 PPBUS_AON missing
          by ugamazing
          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
          02-05-2025, 04:21 PM
        • jpreza
          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
          by jpreza
          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
          Looking at the card, it appears to be missing the following:
          1x 1.0uH inductor - orange square
          2x...
          11-01-2024, 10:54 PM
        • gurj1979
          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
          by gurj1979
          Hey guys.
          Need help with this one.
          Fan not spinning due to missing PWN Fan signal.
          Also 5 seconds from powering up it freezes, unless in BIOS.
          But as soon as Windows starts to load, it will freeze.
          CPU is COLD / Room temp when it freezes.
          I've replaced the CPU, same problem.
          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
          Replaced fan - same problem.
          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
          08-19-2024, 05:22 PM
