Cheap cash register with a dead transformer
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    I'm currently working on a dead cash register - Sharp XE-A106. Absolutely no output from the transformer. The register powers up if I hook it to my 12v DC bench supply. I'm just a little confused at what I should buy as a replacement. The bench supply that I have provides up to 3a, and the register works fine off of that.
    The original transformer has the following markings:
    HKSP-041461
    Input: 120VAC 60Hz
    HEC-0910C
    I haven't been able to find out any other information using those numbers.
    Right next to where the lead plugs into the register itself, it's silkscreened - "UL/CSA/PSE T1.25A/125v"
    So, a little help picking out a replacement transformer would be great, if you please!
    Ludicrous gibs!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: Cheap cash register with a dead transformer
    The silkscreen likely talks about the fuse. Just hook an amp meter in series with your bench supply and see how much output it takes. Then get a laptop power brick or something... some LCD monitors use external 12v bricks, one of those will work nicely with it. Ebay time.
    A working TV? How boring!
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I'm seeing a peak draw of 0.02A when the receipt printer is running. Steady draw of 0.01. This is according to my clamp meter. Does this seem right?
      I was able to power it off of a 12v 1a power adaptor from an old set of speakers...
      Ludicrous gibs!
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        I'd expect a tad more, maybe your clamp meter isn't accurate at low voltages. But sure, one of those doesn't use much power. Sounds like any random wall wart could take care of it.
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Was there any possibility that the register was plugged into an outlet on a miswired circuit?
          208Y/120 is common for computers/recep/"small stuff" distribution in larger buildings. This will be supplied from a step down transformer if the building's service is 480Y/277 or 480D. Older areas may have 240D/120 service, with a 'high-leg' that is 208V above the grounded center tap on the 'lighting' pot.
          Once in a while, a '120V' ckt is tied in to the high leg, and things like radios, cash registers, clocks, computers, etc blow up before the error is found.
          Same thing can happen if the 120 ckt is put across two phases in a 208Y system, although the noodle will then be 120V above ground.
          Speaking of the neutral, any brightening lights when heavy loads picked up?
          It doesn't take much to kill those little transformers...
          Where was the clamp on? AC input to the power supply you tested with, or DC output to the register? Even if it was on the line side, 20mA at 120V is only 2.4VA. Use the 10A function in the meter instead- that's too little load for the clamp on.
          -Paul
          Edit- Does the primary of the dead wall-wart show continuity?
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            To answer your questions - this register comes from my local brewpub. These registers often see less than ideal conditions (beer spills etc). I found no evidence of liquid damage, even in the keys.
            I can't comment on the power situation there, as I'm not familiar with it. There may be 3 phase power coming in to the building, as this used to be a bread bakery. It may have also had new service run into it... I'm not sure.
            When I was measuring the draw, the clamp was on the DC output of my bench supply. It may not even be designed to measure DC draw.
            The transformer reads open on the primary side, closed on the secondary.
            Ludicrous gibs!
            • Evil Lurker
              Warranty Voider
              • Feb 2011
              • 454
              Go to your local goodwill store and pilfer thru their electronics section. Try and find a regulated 12v switch mode wall wart. Heck about anything out there should be able to power the register. I commonly see them rated at .5 to 1 amp for such things like routers and what not.
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                I would kind of like to replace the internal transformer, versus using an outboard wall wart or other supply. Keep that stock look, and not have to worry about careless employees ripping the smaller wire to shreds.
                Ludicrous gibs!
                • bluto
                  • Oct 2007
                  • 560
                  Post a picture. Someone may be able to cross it to one in digikey's catalog. I have had some success replacing a transformer in that manner before.
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    I'm going to talk to the owner tomorrow... he has several registers with misc problems (mostly bad keys due to beer spillage). He just gave me this one to start. He may just want me to scavenge a transformer from one of the other registers, vs buying a replacement xformer.
                    Ludicrous gibs!
                    • b700029
                      Banned
                      • Sep 2010
                      • 640
                      You can also buy an external supply of appropriate size, un-case it, and install it in place of the original transformer. As SMPS are smaller for a given power output compared to a linear supply, this should be easy to do.
                      • Evil Lurker
                        Warranty Voider
                        • Feb 2011
                        • 454
                        Yup take a hacksaw to one corner till you just bareley get thru the casing an then finish the job by prying it open with a screwdriver.
                        Done many a wall wart like that.
                        • Toasty
                          • Jul 2007
                          • 4171
                          Single output or center tapped? I think I have a couple 1 or 2 amp ones in the "cabinet". lol
                          Pic and sizes.
                          veritas odium parit
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            Block plane blade between the case halves hit the end of it with a hammer cracks even the most stubborn cases open with very little damage and you can even glue it back shut if need be when you're done.
                            If you can't scavenge another transformer this is a site I go to they have tons of electronics stuff. The prices are pretty good too.
                            Here is their transformer page:
                            http://www.mpja.com/products.asp?dept=45
                            A 12V transformer at 1 amp is only $3.95. You just have to check if the original is center tapped or not if there is a bridge rectifier (4 diodes) it's not center tapped if it's a full wave rectifier (2 diodes) it's center tapped.
                            I get tons of open frame switchers at this site for projects dirt cheap we're talking under 8 dollars each. Some do require recaps due to crap caps but they're well designed on the input side and not gutless wonders.
                            • dood
                              Deputy dood
                              • Mar 2004
                              • 2462
                              It's a single output, not center tapped. The owner just gave me a 2nd register to scavenge the transformer out of. He has 4 total registers and wants two working out of the bunch. The one he gave me to scavenge has a few dead keys. We're on a short time schedule, as Oktoberfest begins on Thursday, and he needs as many registers up as possible. Otherwise, I'd be ordering a xformer to fix this one, and figure out the others. I may still do that, but for now, it's going to be pick-a-part central here
                              Ludicrous gibs!
                              • Toasty
                                • Jul 2007
                                • 4171
                                Aww, come on man. WE LIKE PICTURES!!
                                Electronics pron!
                                veritas odium parit
                                • dood
                                  Deputy dood
                                  • Mar 2004
                                  • 2462
                                  Electronics pron!
                                  Fine, fine...
                                  The register in question
                                  The xformer, as its mounted on the chassis.
                                  Input/output of the xformer. Obviously, I already clipped the output wires.
                                  The main board. Uses UCC Caps to filter.
                                  Ludicrous gibs!
                                  • Toasty
                                    • Jul 2007
                                    • 4171
                                    Ooooooo! Battery Backup!
                                    http://www.walmart.com/ip/Sharp-Elec...EA106/13728219
                                    This one doesn't *cough* work. *cough* *cough*
                                    Looks like you have plenty of room to work with, so size is not critical.
                                    Thanks for the pics!
                                    veritas odium parit
                                    • ReverendJones
                                      Resurgam
                                      • May 2010
                                      • 49
                                      There really should be a fuse between the power cord and the transformer. It would appear that the factory tried to save a few cents by omitting it.
                                      There is a possibility that the transformer has a blown internal fuse on the primary that can be bypassed. For an example of this see: http://www.geek-republic.com/2011/09...-hdr-1-repair/
                                      Machina improba! Vel mihi ede potum vel mihi redde nummos meos!
                                      • dood
                                        Deputy dood
                                        • Mar 2004
                                        • 2462
                                        Battery backup only holds up the memory of the register... the register will not continue to work without AC power. Useful so you don't lose preprogrammed tax rates, etc.
                                        Ludicrous gibs!
                                        • double_DD
                                          Transformer replacement for a dead coffee machine
                                          by double_DD
                                          Hi guys,
                                          I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
                                          Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
                                          If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
                                          My other ideas:
                                          - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
                                          - to buy...
                                          06-23-2025, 05:43 AM
                                        • Wolf1977
                                          dead transformer on ceramic oven
                                          by Wolf1977
                                          hi in ceramic oven the transformer is damaged
                                          and writes
                                          2x115v/2x12v/6VA 50-60hz ta105/f
                                          can you suggest me a compatible transformer ;
                                          i have found in 70 degrees celsius do you think is suitable for ceramic oven ;
                                          09-02-2023, 03:43 PM
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
