does size really matter?
  • gerg
    • Nov 2010
    • 278
    When replacing capacitors is the actual physical size of the capacitor somehow affect how it will work? Is there a higher failure rate with the smaller size or will they not work at all even to test if it's worth recapping? The reason I am asking is I have quite a few that are just not the same physical size and have been hesitant to even use them because everyone says it should be the same size.
  • steve2
    • Dec 2010
    • 121
    Re: does size really matter?
    the same size is because lots of the places for them is crowded and a larger size won't fit. As long as they have the same uf and voltage (or higher voltage), they are fine to use for troubleshooting. If it fits and works, leave it in. If it's in a low esr requirement, then use it to test. Keep the temperature the same or bump the 85c to 105c. They are all smaller now compared to the older caps with the same values. New technology, but seems more failures.
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • sikocan
      Lenovo X1 Carbon 9th Gen Black Screen
      by sikocan
      I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
      SN: PF3G1REP
      MODEL: 20KW-00J1AU
      PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
      Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
      06-24-2025, 09:01 PM
    • dragometin
      Hitachi 40HYC42
      by dragometin
      TV Model: Hitachi 40HYC42
      Power Supply: 17IPS71
      MainBoard: 17MB95M
      Panel: VES400UNDS-2D-NO3
      When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
      I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
      Is there any variants on 17IPS71 power supply's?
      UART output pins 10 and 12 on scart connector:
      Code:
      12:24:04.595
      08-08-2024, 05:53 AM
    • jdczerwin
      Physical Electrolytic Cap Size Question
      by jdczerwin
      My question has to do with through-hole Electrolytic Capacitor physical size and finding the correct specification in ordering a replacement.
      Example: I'm working on an old video arcade monitor. The parts list calls for two (2) 6800pF, 50V Electrolytic Capacitors (ECap). Based on that specification, you can go to Mouser, DigiKey, etc and get a through-hole ECap at that spec…and get a far smaller one (physical size-wise) than what was on the board.
      From my limited knowledge, I understand that size does matter in this application because of the stress that the circuit...
      01-15-2021, 09:08 AM
