Power-One solar Inverter driving me NUTS!!!
  • petehall347
    • Jan 2015
    • 4451
    • United Kingdom
    #181
    REF3033
    https://www.s-manuals.com/smd/r3
    https://allegro.pl/oferta/zrodlo-odniesienia-3-3v-ref3033-r30d-sot-23-4069-12780645910
    • petehall347
      • Jan 2015
      • 4451
      • United Kingdom
      #182
      something strange happening in my last reply .. second link again here .its just an example and not saying buy from there
      https://allegro.pl/oferta/zrodlo-odn...69-12780645910
      • mitsu2k
        • Aug 2013
        • 219
        the chinese translates to . You must report any pirated pictures. Any problems in pirated stores.
        L O L, I just snapped that picture off the web because it was exactly like my component and a better picture of it
        • mitsu2k
          • Aug 2013
          • 219
          No worries Pete, I got it on my shopping list. Thank you again!!
          • mitsu2k
            • Aug 2013
            • 219
            Is this an SB or S8?
            • petehall347
              petehall347 commented
              Editing a comment
              looks like a B and google agrees with me .
          • mitsu2k
            • Aug 2013
            • 219
            But this photo looks like 8. Can you send me a link to what you googled please?
            it is SOD-323
            • petehall347
              • Jan 2015
              • 4451
              • United Kingdom
              #187
              here but its not reading the text now
              https://lens.google.com/search?ep=cc...VsbCxbW11dXQ==
              • mitsu2k
                • Aug 2013
                • 219
                Pete, I ordered both anyway one is 50v and the other is 30v. That's the biggest diff I can see.
                Mouser order placed. Will arrive Tuesday. Never been so nervous. Lol
                • petehall347
                  • Jan 2015
                  • 4451
                  • United Kingdom
                  #189
                  2n might be RLSD32A361C tvs esd protection . might not as well . cant find any pics .
                  • mitsu2k
                    • Aug 2013
                    • 219
                    What is this component? Anyone know? I think it is a zener but it measures 1v. I cannot make sense whether that is a WI or W1
                    • mitsu2k
                      • Aug 2013
                      • 219
                      SUCCESS!!! Replaced those burned components and a few more that were shorted on the logic board and this is the result. I want to give a big shout out and THANK YOU to CapLeaker, SAM_SAM_SAM and Petehall347 for all your help and dedication. You guys are absolutely amazing and I could not have done this without you. THANK YOU!!
                      • ssrkh
                        ssrkh commented
                        Editing a comment
                        so sad u didnot mention me
                    • petehall347
                      • Jan 2015
                      • 4451
                      • United Kingdom
                      #192
                      glad you got it fixed .well done .
                        • Jul 2011
                        • 6070
                        I glad you got it fixed
                        So what were all of the bad parts did you have to replace that was either burnt out or bad when tested
                        I am very lazy to go back and read all the posts that were written about this issue with this inverter
                        • petehall347
                          • Jan 2015
                          • 4451
                          • United Kingdom
                          #194
                          the parts were in the area i suspected earlier on .i have never seen one of these units in front of me so i could only guess the general area like around an mcu. i should have said look for the clock crystal that's there in most cases next to them .would have been good to know what caused the damage whether it being bad design or bad quality parts etc etc . .
                            • Jul 2011
                            • 6070
                            I was wondering the same thing
                            • mitsu2k
                              • Aug 2013
                              • 219
                              They were right next to the crystals. The parts I replaced were:
                              3 mosfets (SOT-23) One was burned and the other two were shorted.
                              4 shorted diodes (One was burned) (SOD-323)
                              3 zener diodes (should have been SOD-323 but I used through hole wire leads instead)
                              I had trouble with the zener diodes trying to figure out the marking whether it was "WI" or "W1". neither of these made any sense because my research showed the WI is 12v and W1 is 2.7v but when I found some good ones on the board and tested them, they measured 3.4v and 3.7v. So I had some 3.6v through hole zeners so I just bent the leads and soldered them to the pads. Looks like it did the trick.
                              • mitsu2k
                                • Aug 2013
                                • 219
                                Yes Pete you kept asking for the model of the controller. I should have paid more attention but honestly that board intimidated me and I was too lazy to scrape off all the silicone they coated the board with. I should have listened to you earlier but I had tunnel vision and did not think the problem was on that board. Obviously I was wrong and I learned a lot from you and the other gentlemen. Next time I need to keep an open mind, get over my fear, and be more thorough with visual inspection.
                                • mitsu2k
                                  • Aug 2013
                                  • 219
                                  Here are some photos. One is before removal of the components and the other is after I removed them and cleaned up the pads.
                                    • Jul 2011
                                    • 6070
                                    That is a lot that went wrong with this inverter wow
                                    • mitsu2k
                                      • Aug 2013
                                      • 219
                                      Yes the two burned components (one diode & one mosfet) were open. The rest of the components in the other side were shorted). I suspect something shorted and went down the line and fried everything else. It ran all day yesterday with no problems and still running good now.
                                      • Cama
                                        Solar Inverter - SMH-II - 2 missing capacitors
                                        by Cama
                                        I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                                        My model is : EASUN SMH-II 7 KW
                                        Mother Board : P/N 18947-002401250250
                                        Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                                        Thank you...
                                        09-12-2025, 02:50 AM
                                      • Francesc V.
                                        Trying to repair a MPI5.5kW solar inverter
                                        by Francesc V.
                                        My parent's solar inverter died after 5 years of good service.
                                        It's a called hybrid inverter:
                                        - It can go with or without batteries
                                        - It has 2 MPPT (8 330W panels in 2 strings) -> 5280Wp
                                        - A 20kWh lithium battery previously used in a Nissan leaf (14S at 4.1V max) -> 57.4V
                                        Panel is showing error 17 and the battery connection has disappeared. On the other hand, is delivering load, MPPTs are working and it's exporting energy to the GRID. Not that "bad".
                                        Let's open it......
                                        I see that 150A fuse is gone and the...
                                        03-07-2023, 06:17 AM
                                        3000W 9000W 24V to 110V Pure Sine Wave Power Inverter UPS Solar Converter is this a good idea
                                        by sam_sam_sam
                                        I just seen this item is this a good idea if why and if not why not
                                        Here is the website link to it
                                        https://www.ebay.com/itm/40599879518....c101465.m3507
                                        08-24-2025, 10:55 AM
                                      • eccerr0r
                                        inverter H tree driver imbalance in an AC inverter
                                        by eccerr0r
                                        My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                        11-16-2025, 12:34 PM
                                      • x_orange90_x
                                        by x_orange90_x
                                        01-29-2025, 09:24 PM
