3000W 9000W 24V to 110V Pure Sine Wave Power Inverter UPS Solar Converter is this a good idea
    • Jul 2011
    • 6093
    • Soldering Junkie
    I just seen this item is this a good idea if why and if not why not
    Here is the website link to it
    https://www.ebay.com/itm/40599879518....c101465.m3507
    • 31890
    slight translation error - to put it mildly.
    it's a 24v ups - a powerfull one, minimum charge current setting is 15AH
    but NOT solar,
    for solar you need a seperate solar powered 24v charger/source to put across the batteries.
    this unit has no input for any panel array.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8757
      9000w peak from a 3000w unit? Naaah!
      Well, I am tossed 50/50. But it has decent reviews,
        • Jul 2011
        • 6093
        • Soldering Junkie
        I have my doubts about what it’s actual output really is
        I have not read the reviews yet but I will definitely look at them and decide if this the rabbit hole I want to go down
          • 31890
          does it support different battery chemistrty's?
            • Jul 2011
            • 6093
            • Soldering Junkie
            Not a real big problem to charge lithium ion battery packs it would probably only charge it up 90 to 95%
            Usage:
            2.Connect it to the 24v battery, the inverter will works,
            3.Connect it to the Mains and 24v battery at the same time, the inverter will works,and the inverter will charge your battery,the max charge current is 10A,the charge voltage is 28.8V. and the inverter will not stop working if the Mains no power suddenly.”
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8757
              How much import tax does it have?
                • 31890
                the Trump-Tax? i think that keeps changing!
