LCD Backlight harness 2 pin plastic connectors ?
  • infringer
    Badcaps Member
    • Sep 2009
    • 244
    • United Frickin States
    Hey folks,
    Just wondering if anyone knows where I can find the 2 pin backlight plastic connections or what they are called that plug into the power supply on the LCD normally Pink White Blue and Black wires are used.
    I am in dire need of these connectors but I want just the connectors and if needed the tool used to crimp the wire in place a name of the connector would be a great start.
    Please note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
  • Wrog
    • Oct 2009
    • 472
    Re: LCD Backlight harness 2 pin plastic connectors ?
    Many, many different types and styles. Can you provide a make/model of the LCD and/or a pic of the connector?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      http://www.ccflfactoryoutlet.com/accessories.html
      • infringer
        Badcaps Member
        • Sep 2009
        • 244
        http://www.ccflfactoryoutlet.com/2pinjstwiha.html
        This would be the 2 pin plastic that I need I do not want any wiring though just the plastics and pins if nessacary the tool as well to slap the wires in there. I have plenty of wire to use but no ends.
        Sweet deal I spent friggin 2hours searching last nite with no luck now I got a leg in the door.
        • infringer
          Badcaps Member
          • Sep 2009
          • 244
          Why do they make it so difficult to find connectors ...
          JST makes it near impossible to find what I need but the picture is on the top heading of one of there pages. There internet shopping page or whatever I would call it a 2pin JST connector but a search for it turns up nothing.
          • infringer
            Badcaps Member
            • Sep 2009
            • 244
            BHSR-02VS-1 is the part 2 pin jst plastic connector for many backlights.
            Wire is 3239 AWG 24 3KV wire WARNING!!!! Must use this high voltage wire as 12v gets converted to 500v !!!!!!
            Need to find pins for connector.
            • infringer
              Badcaps Member
              • Sep 2009
              • 244
              Anyone have the part number for these pins been looking all day to try to find the part number for the pins on the end of the wire. Thanks in advance what I want is the complete listing of parts required for the harness then I could easily
              • alexanna
                • Mar 2010
                • 1346
                A paper clip or the lead of a capacitor will remove the pin from the plastic housing.
                If it was me I would salvage the plastic pig tail from a broken monitor. If that's not a option
                You're looking for the female terminal; I think the pins should all be the same.
                Email ccfl warehouse and tell them what your needing.
                Al.
                • infringer
                  Badcaps Member
                  • Sep 2009
                  • 244
                  I'd like to make up a few of these harnesses to have them on hand seems to be a rash of ccfl backlight failures most of them involving one manufacturer of the screen itself and I would bet you could guess the manufacturer :P
                  • alexanna
                    • Mar 2010
                    • 1346
                    They also sell the wire in bulk.
                    Al.
                    • infringer
                      Badcaps Member
                      • Sep 2009
                      • 244
                      Yes correct I would like to find the part # for the right crimp tool to use so without the part # I refuse to purchase this item. I have emailed this outfit and it has been roughly 4 days and no response that spells trouble if you ask me why would I purchase something from somewhere that does not even answer your emails?
                      But thanks a million for the right direction I guess I will have to do more searching when I get time once I have everything here I will list all the part numbers and the crimp tool to use in the forum here in case anyone else is brave enough to do backlight repair I think it is a rather tedious process that not always pays off but heck when it does its sweet.
                      • worsel
                        • Mar 2014
                        • Ireland
                        Hi Infringer ..
                        I know this is an Old Post .. But .. I'm just wondering if you ever found these PIN JST connector and the crimping tool ..
                        I'm looking for something similar
                          Not sure if this will help:
                          http://www.cn-ovl.com/product.aspx?classId=123
                          JST BHS series:
                          http://www.jst-mfg.com/product/detail_e.php?series=22
                          BH
                          https://cdn.badcaps-static.com/pdfs/...229ea9a973.pdf
                          • redwire
                            • Dec 2010
                            • 3912
                            I get my JST connectors from eBay, lots there.
                            • corrize
                              Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                              by corrize
                              Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                              There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                              I have :
                              - hot air, and a
                              ll stuff around
                              - true kapton tape
                              - 140 and 180 degree soldering paste
                              - bismuth
                              - little hot plate 250 degree max
                              - the new BGA chip with probably
                              05-20-2025, 01:26 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • DanPoka
                              by DanPoka
                              02-15-2025, 05:05 AM
                            • Comp_Pro
                              No Backlight Macbook A1990 820-01041
                              by Comp_Pro
                              Hello all,
                              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                              Tests performed:
                              There is no backlight even with a good screen.
                              Backlight IC is receiving the correct support voltages.
                              Fuse F8400 ok
                              Current sense resistor R8400 ok
                              Backlight IC is receiving 3.3V on enable pin.
                              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                              Backlight IC receiving 5V from PP5V_G3S
                              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                              05-06-2024, 10:23 PM
                            • cheebster
                              iPad Pro 12.9 5th Gen Backlight Issue
                              by cheebster
                              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                              Anyone...
                              05-20-2025, 09:17 AM
